  Tommy persson said:
Har kollat säkringar. Där är allt ok .
Får dock inte inte fart på bensin/temp/varv/hastighet. Allt funkar i Databoxen inga fel enligt felsökningen.
Kan allt ha slutat fungera
Alle 05 instrumenter vil før eller siden bli ødelagt har jeg hørt, "stepper gears"/"steppe rmotor" som er særdeles dårlig. Kan byttes ut.
http://www.ratstangrestoration.com/Stepper%20Motor%20Replacement%20for%20the%20S197%20Instrument%20Pack.htm
Med litt flaks kanskje dette hjelper:
Try the gauge test.
If it doesn't work then chances are it's some how mechanically not working... tho a soft reset (battery disconnect) could work? dunno.gif
Quote:
[TABLE=width: 100%]
[TR]
[TD=class: alt2](From the vehicle completely off--ignition off, key out, door open and closed to kill the accessory delay)
1.) Press and hold the 'Setup' and 'Reset' buttons for the message center
2.) While keeping these buttons pressed, start the vehicle.
3.) When the message center displays 'ENGINEERING TEST MODE', release the buttons. (the first test will be a gauge test, so don't freak out when the gauge needles go nuts and make weird noise)
4.) You can scroll through the different engineering readout displays and tests by pressing the Reset button.
5.) To end Engineering Test Mode, turn off the vehicle ignition, and open the door (to kill the accessory delay).
The vehicle will start up on 'regular' mode next time, unless you do the button press-and-hold again.[/TD]
[/TR]
[/TABLE]
