April 19, 20187 yr comment_161052 Som att läsa läkarboken... Här kommer listan med USA-bulletiner Om ni vill ha mer detaljer om en viss bulle så svara på denna tråd OBS: DETTA ÄR INGA ÅTERKALLELSER!!!!!!!!!!!!!!!!! GSB G0000175 - Effective Apr 19 2018 Ambient Air Temperature (AAT) Sensor SSM 47225 - Effective Apr 10 2018 2015-2018 Mustang - Equipped With Sync 3 - Inoperative Universal Serial Bus (USB) Ports With DTC B1252:13 - Built On Or Before 1-Jan-2018 GSB G0000174 - Effective Apr 6 2018 2013-2018 Various Vehicles - Instrument Panel Cluster Mask / Lens Warranty SSM 47201 - Effective Mar 30 2018 2008-2018 Various Ford/Lincoln/Mercury Vehicles - Replacing/Upgrading Original Equipment SYNC/Navigation System Components Is Not Supported GSB G0000172 - Effective Mar 30 2018 2010-2018 Various Vehicles - Ear Clamp Removal Procedure SSM 47200 - Effective Mar 30 2018 2015-2018 Mustang - No Horizontal Adjustment Of Front Power Seats - Power Seat Track Motor Inoperative TSB 18-2107 - Effective Mar 30 2018 2015-2018 Mustang GT350 - Excessive Panel Gap Between Rear Bumper Cover And Rear Quarter Panels - Built On Or Before 26-Feb-2018 SSM 47149 - Effective Mar 13 2018 2015-2017 Mustang - Poor Air Conditioning (A/C) Performance, Low Refrigerant Charge - Built On Or Before 2-Sep-2016 GSB G0000171 - Effective Feb 27 2018 Laminated/Tempered/Heated Glass Damage General Service Bulletin SSM 47080 - Effective Feb 14 2018 2010-2018 Various Vehicles - Spotify Not Found Or Not Functioning On AppLink SSM 47070 - Effective Feb 9 2018 Various Vehicles - Data Link Connector (DLC) Connection - Vehicles Equipped With Gateway Module (GWM) TSB 18-2036 - Effective Feb 7 2018 2015-2018 Mustang Convertible - Roof Sagging At The Rear Glass GSB G0000168 - Effective Feb 2 2018 Tire Vibration – Equipment Based Diagnostics and Requirements For Warranty Claim Submission GSB G0000167 - Effective Jan 22 2018 Multiple Vehicles - Engine Oil White Fluorescent Dye Usage General Service Bulletin (GSB) GSB G0000166 - Effective Jan 22 2018 Multiple Vehicles - Surface Preparation For Oil Leaks GSB G0000165 - Effective Jan 18 2018 Multiple Vehicles - Lower End Engine Noise Diagnostic Aid - Inspecting the Oil Filter Element General Service Bulletin (GSB) GSB G0000162 - Effective Jan 17 2018 Multiple Vehicles - Gas Engine Performance Modifications SSM 47012 - Effective Jan 11 2018 2015-2018 F-150, Mustang, Transit - No Airflow From Climate Control Vents - Air Conditioning (A/C) Clutch Seized And/Or Stuck - Built On Or Before 01-Dec-2017 SSM 46995 - Effective Jan 3 2018 2015-2017 Mustang - Convertible Top Wear Or Damage On Outer Front Edges - Built On Or Before 1-Feb-2017 TSB 17-2271 - Effective Dec 25 2017 Various Vehicles - 2.0L/2.3L/2.7L EcoBoost, 5.0L, 5.2L - Engine Oil Pressure (EOP) Sensor Oil Leak SSM 46973 - Effective Dec 11 2017 2015 - 2018 GT350 R Spring And Shock Spacer Removal Required At Pre-Delivery Inspection GSB G0000156 - Effective Nov 8 2017 Passive Anti Theft System (PATS) Key Programming SSM 46900 - Effective Nov 2 2017 2009-2018 Various Vehicles - No Start - Illuminated MIL And Diagnostic Trouble Code (DTC) P161A After Powertrain Control Module (PCM) Replacement GSB G0000154 - Effective Oct 18 2017 Multiple Vehicles - Touch Screen Warranty GSB GSB G0000150 - Effective Sep 27 2017 Various Vehicles - Module Programming and Reprogramming Procedures GSB G0000149 - Effective Aug 23 2017 Engine Oil Maintenance Inspection TSB 17-0062 - Effective Aug 23 2017 2000 And Newer Ford, Lincoln And Mercury Vehicles - Aluminum Panel Corrosion SSM 46767 - Effective Aug 17 2017 2015-2017 Mustang – 3.7L/5.0L – 6R80 - Clunk/Ping Noise When Shifting From Park To Reverse And/Or Park To Drive Engagement SSM 46727 - Effective Jul 31 2017 Setting Correct Tire Pressure GSB G0000145 - Effective Jul 27 2017 Various 2013 and Newer Vehicles - Splice Block General Service Bulletin (GSB) GSB G0000144 - Effective Jul 17 2017 12 Volt Battery Charging and Testing Quick Reference Guide- GSB G0000142 - Effective Jun 29 2017 Multiple Vehicles - Wiring Repair / Harness Replacement - Best Practices for Warranty Claiming GSB G0000141 - Effective Jun 29 2017 Multiple Vehicles - Front Controls Interface Module (FCIM) Warrantable VS Non-warrantable Conditions General Service Bulletin (GSB) SSM 46659 - Effective Jun 20 2017 2015 - 2016 Mustang - Convertible - Power Door Window One Touch Up And Bounce Back Features GSB G0000136 - Effective May 3 2017 Adaptive Cruise Control & Collision Warning Radar Alignment Process SSM 46451 - Effective Mar 14 2017 2009-2017 Multiple Vehicles Equipped With 6R80,6R100,6R140 Automatic Transmission - Updated Workshop Manual (WSM) Main Control Valve Body Overhaul Procedure GSB G0000129 - Effective Mar 14 2017 Multiple Vehicles - Leather/Vinyl Seat Cover General Service Bulletin (GSB) GSB G0000130 - Effective Mar 14 2017 Multiple Vehicles- Interior Mirror General Service Bulletin (GSB) GSB G0000126 - Effective Mar 6 2017 Multiple Vehicles - Instrument Panel Cluster Mask / Lens Warrantable Versus Non-Warrantable Conditions GSB G0000125 - Effective Feb 27 2017 Multiple Vehicles- Body Interior Trim and Steering Wheel Damage vs. Defect General Service Bulletin (GSB) GSB G0000123 - Effective Feb 7 2017 Multiple Vehicles- Wiper Blade Warrantable Vs. Non-Warrantable General Service Bulletin (GSB) SSM 46353 - Effective Jan 31 2017 2013-2017 Various Vehicles - Ambient Air Temperature Sensor (AAT) Pinpoint Test Update In Workshop Manual (WSM) Section 413-01 SSM 46344 - Effective Jan 27 2017 2015 Edge,Mustang, And F150 - 24 Hour Clock Display Resets To 12 Hour Display SSM 46332 - Effective Jan 24 2017 2008-2017 Various Ford/Lincoln/Mercury Vehicles - Replacing/Upgrading Original Equipment SYNC/Navigation System Components Is Not Supported SSM 46295 - Effective Jan 10 2017 Multiple Vehicle Lines - Revised Engine Oil Leak Diagnostic Procedure Using New White Fluorescent Dye SSM 46152 - Effective Oct 26 2016 2015-2016 Mustang - Inoperative Park Aid Camera, Luggage Compartment Lamp, Deck Lid Release And/Or Poor Satellite Radio Reception SSM 46132 - Effective Oct 17 2016 2008-2017 Ford/Mercury/Lincoln - Vehicle Health Report (VHR) Generates Service Required Message SSM 46123 - Effective Oct 12 2016 2015-2016 Mustang 5.0L 32V Ti-VCT Engine And Oil Pan Replacement GSB G0000112 - Effective Oct 10 2016 Multiple Vehicles - SYNC Software Programming v1.1 SSM 46102 - Effective Sep 30 2016 Multiple Vehicles - Safety Belt Retractor Webbing Does Not Extract From Stowed Position Or Exhibits Excessive Pressure On The Occupant During Use. GSB G0000108 - Effective Sep 23 2016 Multiple Vehicles- Paint Defects / Damage General Service Bulletin (GSB) TSB 16-0121 - Effective Sep 14 2016 2015-2016 Mustang - 2.3L Gasoline Turbocharged Direct Injection (GTDI) - Lack Of Power With DTC P0299 - Built On Or Before 1/1/2016 GSB G0000107 - Effective Aug 23 2016 Multiple Vehicles- Grille Defects / Damage General Service Bulletin (GSB) GSB G0000106 - Effective Aug 10 2016 Multiple Vehicles - Historical Powertrain Diagnostic Trouble Codes (DTC) General Service Bulletin (GSB) TSB 16-0103 - Effective Aug 10 2016 2015-2017 Mustang - Manual Transmission - No Crank - Built On Or Before 6/15/2016 SSM 45943 - Effective Jul 20 2016 2011-2016 Various Vehicles - Ambient Air Temperature Sensor (AAT) Pinpoint Test FA And FB Updated SSM 45938 - Effective Jul 18 2016 2015-2017 Mustang Driveline Vibration At Highway Speeds SSM 45903 - Effective Jun 28 2016 2015-2017 Shelby GT350 And GT350R Brake Service SSM 45861 - Effective Jun 2 2016 2013-2015 Fusion/MKZ And 2015 Mustang - Steering Column Controls Inoperative With Possible U0212 - Built On Or Before 3/20/2015 TSB 16-0085 - Effective May 24 2016 2015-2016 Mustang 5.2L Ti-VCT - Illuminated Malfunction Indicator Lamp (MIL) With Diagnostic Trouble Codes (DTCs) P0720 And P0722 - Built On Or Before 2/26/2016 GSB G0000094 - Effective Apr 29 2016 Multiple Vehicles - No PCM/Network Communication SSM 45788 - Effective Apr 29 2016 Some Vehicles Could Exhibit Misfire Codes After Certain Repairs - Multiple Vehicle Lines SSM 45781 - Effective Apr 27 2016 2015-2016 Mustang GT350 - Extended High Speed Or Track Usage - Diagnostic Trouble Codes (DTCs) P0218 and P1783 SSM 45775 - Effective Apr 26 2016 Various Vehicles - Adaptive Cruise Control Equipped - Unexpected Brief Reduction In Speed GSB G0000093 - Effective Apr 19 2016 Multiple Vehicles - Automatic Transmission Main Control Inspection - General Service Bulletin (GSB) GSB G0000092 - Effective Apr 5 2016 Multiple Vehicles- Exterior Mirror General Service Bulletin (GSB) GSB G0000091 - Effective Mar 31 2016 Multiple Vehicles- Glass Panel Build Date Decoder General Service Bulletin (GSB) GSB G0000087 - Effective Feb 26 2016 Multiple Vehicles - Engine Failure Analysis General Service Bulletin (GSB) GSB G0000083 - Effective Feb 25 2016 Multiple Vehicles - Coolant Pump Inspection - General Service Bulletin (GSB) TSB 16-0019 - Effective Feb 23 2016 2015 F-150 / Mustang - 5.0L DOHC Engines - Coolant Leak SSM 45646 - Effective Feb 17 2016 2015-2016 Various Ford Vehicles - SYNC Gen 1 With 4.2 Inch Display - Bluetooth Pairing And Connection Concerns - Built On Or Before 1/24/2016 GSB G0000082 - Effective Feb 9 2016 Multiple Vehicles- Bumper Warrantable / Non-Warrantable General Service Bulletin (GSB) GSB G0000081 - Effective Feb 3 2016 Multiple Vehicles - Driver On Coil Ignition Test - 3 Wire Coils - General Service Bulletin (GSB) GSB G0000080 - Effective Feb 3 2016 Multiple Vehicles - PCM Ignition Coil Driver Test - 2 Wire Coil - General Service Bulletin (GSB) GSB G0000078 - Effective Jan 29 2016 Multiple Vehicles - Environmental Fallout Paint Damage General Service Bulletin (GSB) GSB G0000077 - Effective Jan 27 2016 Multiple Vehicles- Head Lamp Aim Warranty Coverage General Service Bulletin (GSB) GSB G0000076 - Effective Jan 27 2016 Multiple Vehicles- Exterior Lighting Condensation Warranty Coverage General Service Bulletin (GSB) GSB G0000075 - Effective Jan 25 2016 Multiple Vehicles - Electric Power Assist System (EPAS) Pull Drift Compensation General Service Bulletin (GSB) GSB G0000070 - Effective Dec 21 2015 Multiple Vehicles - How To Upload An IDS Session File - General Service Bulletin (GSB) GSB G0000065 - Effective Dec 16 2015 Various 2013 and newer vehicles - Supplemental Restraints System (SRS) Air Bag Squib Connector GSB GSB G0000066 - Effective Dec 16 2015 Multiple Vehicles - Transmission Cooler Flush General Service Bulletin (GSB) TSB 15-0192 - Effective Dec 15 2015 2015-2016 Mustang - 2.3L Gasoline Turbocharged Direct Injection (GTDI) - Excessive Exhaust Smoke After Extended Idle GSB G0000053 - Effective Dec 11 2015 Multiple Vehicles - Tire Pressure Monitor System (TPMS) General Service Bulletin (GSB) GSB G0000048 - Effective Dec 7 2015 Multiple Vehicles - PSCM Wiring Harness Inspection Checklist General Service Bulletin (GSB) SSM 45500 - Effective Dec 4 2015 Alarm Activation During Remote Start, 2015 And 2016 Mustang Convertible With Remote Start Produced On Or Before 10/21/2015 SSM 45493 - Effective Dec 1 2015 2015-2016 Mustang/Focus - With 4.2\" SYNC Display - SYNC Accessory Protocol Interface Module (APIM) Programming Using Front SYNC Universal Serial Bus (USB) Port GSB G0000045 - Effective Nov 26 2015 Multiple Vehicles- Body Gap Flushness Measurement Tools General Service Bulletin (GSB) GSB G0000043 - Effective Nov 26 2015 Various Vehicles - Live Network Monitor Test Usage GSB G0000036 - Effective Nov 16 2015 Multiple Vehicles - Wheel Concern Analysis General Service Bulletin (GSB) SSM 45418 - Effective Oct 23 2015 Dealer Installed Audio Upgrades SSM 45412 - Effective Oct 22 2015 2011-2016 Multiple Vehicles – Universal Garage Door Programming Concerns SSM 45411 - Effective Oct 22 2015 2009-2015 Vehicles Equipped With 6R80 Transmission - New Foam Seal Available - Lead Frame To Shift Solenoid Connection GSB G0000033 - Effective Oct 21 2015 Multple Vehicles - Wiring Repair General Service Bulletin (GSB) GSB G0000031 - Effective Oct 14 2015 Multiple Vehicles- Tape Stripe General Service Bulletin (GSB) GSB G0000029 - Effective Oct 14 2015 Multiple Vehicles - Brake Disc Service Tips General Service Bulletin (GSB) TSB 15-0144 - Effective Sep 22 2015 2015-2016 Mustang - Climate Controlled Seats - Lack of Cooling - Front Seat Backrest SSM 45367 - Effective Sep 22 2015 2015 Edge, F150, Mustang and 2016 Explorer and MKX - Tire Pressure Monitoring System (TPMS) Sensors Difficult To Train GSB G0000017 - Effective Sep 16 2015 2013 And Newer Vehicles - Gasoline Engine - Adaptive Fuel Viewer GSB GSB G0000010 - Effective Aug 26 2015 2015-2016 Multiple Vehicles- New SYNC Accessory Protocol Interface Module (APIM) System Reset General Service Bulletin (GSB) GSB G0000006 - Effective Aug 25 2015 Multiple Vehicles - Cloth Seat Cover General Service Bulletin (GSB) TSB 15-0128 - Effective Aug 11 2015 2015 Mustang - 5.0L Ti-VCT With Manual Transmission - RPM Loss On Deceleration When Coming To A Stop With No DTCs Present - Built On Or Before 12/5/2014 TSB 15-0127 - Effective Aug 11 2015 2015 Mustang 5.0L Ti-VCT - Malfunction Indicator Lamp (MIL) Illuminated - Diagnostic Trouble Code (DTC) P0454 SSM 45218 - Effective Jul 13 2015 2015 Mustang - Convertible Top Cleaning Procedure SSM 45215 - Effective Jul 10 2015 SYNC/MyFord And MyLincoln Touch - Navigation Displays Incorrect - Unable To Locate Vehicle - Built On Or Before 9/30/2014 TSB 15-0109 - Effective Jul 1 2015 2015 Mustang 3.7L Duratec - Automatic Transmission - Hard Brake Pedal - Built On Or After 9/29/2014 SSM 45196 - Effective Jun 29 2015 Various Vehicles - Perimeter Alarm Armed And Original Vehicle Keys Cannot Be Accessed to Enter Vehicle - CAN Protection Strategy SSM 45189 - Effective Jun 24 2015 2015 Mustang Headlamp Switch Bezel Buzz Or Tick Noise Built On Or Before 4/30/2015 SSM 45180 - Effective Jun 23 2015 Integrated Diagnostic System (IDS) Session File Upload Request When Replacing A Powertrain Control Module (PCM) SSM 45172 - Effective Jun 17 2015 2015 3.7L And 5.0L Mustang- Exhaust Rattle, Knock Noise TSB 15-0097 - Effective Jun 16 2015 2015 Mustang 2.3L EcoBoost - Manual Transmission - Illuminated MIL, DTCs P0300 And/Or P0316 - Built On Or After 12/20/2014 And Through 5/21/2015 SSM 45159 - Effective Jun 8 2015 2011-2015 F-150, Expedition, Navigator, Mustang and 2011-2016 F-Super Duty - Multifunction Indicator Lamp (MIL) On Diagnostic Trouble Code (DTC) P1636 TSB 15-0078 - Effective May 18 2015 2015 Mustang 2.3L EcoBoost - Illuminated Malfunction Indicator Lamp (MIL) With DTCs P0036, P0054, P0137 And/Or P0141 - Built On Or Before 12/19/2014 SSM 45081 - Effective Apr 29 2015 2013-2015 Fusion/MKZ, 2015 F-150, 2015 Mustang, and MKC-Reverse Park Aid Camera Active Gridlines Inoperative After Battery Disconnect Or Component Service SSM 45080 - Effective Apr 28 2015 2013 - 2015 Fusion, 2014 - 2015 Fiesta, MKC, MKZ, and 2015 Mustang, F150 Vehicles May Be Put Into Dynamometer Mode (Dyno Mode) Inadvertently SSM 45075 - Effective Apr 28 2015 2015 Mustang – Genuine Ford Accessories (GFA) Remote Start Kits - Incompatible With Enhanced Security Package TSB 15-0059 - Effective Apr 22 2015 2015 Mustang - 5.0L - Malfunction Indicator Lamp (MIL) Illuminated - Misfire Diagnostic Trouble Codes (DTCs) SSM 45065 - Effective Apr 21 2015 Various Vehicles Equipped With 6F35, 6R80, Or Torqshift6 - Erratic Shifts - Transmission Solenoid DTC'S - Workshop Manual Updates SSM 45016 - Effective Mar 25 2015 2011-2015 Vehicles Equipped With The 6R80 Transmission - Misc Solenoid DTC Codes - Pinpoint Diagnostic Routine - Solenoid Contamination Inspection TSB 15-0030 - Effective Mar 10 2015 2015 Mustang GT 5.0L And 2.3L EcoBoost With Performance Package Front Brake Noise - Built On Or Before 2/11/2015 TSB 15-0025 - Effective Mar 2 2015 2015 Mustang, Wind Noise From Windshield Area - Built On Or Before 11/10/2014 TSB 15-0022 - Effective Feb 25 2015 2015 Mustang - Exhaust Leak - 5.0L Ti-VCT Built On Or Before 1/22/2015 SSM 44863 - Effective Dec 11 2014 2010-2015 Multiple Vehicles - Flutter/Turbulance Noise At Highway Speeds With Rear Windows Or Moon/Sun Roof Open SSM 44847 - Effective Dec 2 2014 2015 - F-150 and Mustang - Diagnostic Trouble Code (DTC) P062B Stored in Powertrain Control Module(PCM) Memory SSM 44763 - Effective Oct 15 2014 New Wiring Repair Job Aid is available on PTS under the Service Tips tab SSM 44746 - Effective Oct 1 2014 2001-2015 - Vehicles With Modular 4.6L, 5.4L Or 6.8L Engines - Determining Root Cause Of Engine Damage Due To Oil Pressure Loss. SSM 44707 - Effective Sep 11 2014 2009-2015 Vehicles Exhibiting Diagnostic Trouble Code (DTC) P06B8, P068A And/Or P2610 After Powertrain Control Module Reprogramming Ändrade %s av %s (%s)
24 JuniJun 24 comment_187508 Olje lekage vintilkåpa mustang GT 2015 , vad göra och garanti 😵💫 eller ungefärlig kostnad .Bilen har gott 4400 mil ca , började märkas för vid 3800mil MvhPeter Gävle
