comment_161053
Här kommer bullelistan för Mustang 2016 (många är säkert samma som för 2015). Om du vill ha mer detaljer om en viss bulle så svara här.
OBS: DETTA ÄR INGA ÅTERKALLELSER!!!!!!!!!!!!!!!!!!!!!!!
GSB G0000175 - Effective Apr 19 2018
Ambient Air Temperature (AAT) Sensor
SSM 47240 - Effective Apr 16 2018
2016-2017 Various Vehicles - SYNC 3 Navigation Map Updates
SSM 47225 - Effective Apr 10 2018
2015-2018 Mustang - Equipped With Sync 3 - Inoperative Universal Serial Bus (USB) Ports With DTC B1252:13 - Built On Or Before 1-Jan-2018
GSB G0000174 - Effective Apr 6 2018
2013-2018 Various Vehicles - Instrument Panel Cluster Mask / Lens Warranty
SSM 47211 - Effective Apr 4 2018
2016-2017 Various Vehicles - SYNC 3 - Blank Screen After Exiting Valet Mode
GSB G0000172 - Effective Mar 30 2018
2010-2018 Various Vehicles - Ear Clamp Removal Procedure
TSB 18-2107 - Effective Mar 30 2018
2015-2018 Mustang GT350 - Excessive Panel Gap Between Rear Bumper Cover And Rear Quarter Panels - Built On Or Before 26-Feb-2018
SSM 47200 - Effective Mar 30 2018
2015-2018 Mustang - No Horizontal Adjustment Of Front Power Seats - Power Seat Track Motor Inoperative
SSM 47201 - Effective Mar 30 2018
2008-2018 Various Ford/Lincoln/Mercury Vehicles - Replacing/Upgrading Original Equipment SYNC/Navigation System Components Is Not Supported
SSM 47171 - Effective Mar 21 2018
2016-2018 Various Vehicles - SYNC 3 - iPhone USB Audio Playback And App Link Functionality Issues
SSM 47167 - Effective Mar 19 2018
2016-2017 Ford And Lincoln Vehicles Equipped With SYNC 3 - Touchscreen Unresponsive
SSM 47149 - Effective Mar 13 2018
2015-2017 Mustang - Poor Air Conditioning (A/C) Performance, Low Refrigerant Charge - Built On Or Before 2-Sep-2016
GSB G0000171 - Effective Feb 27 2018
Laminated/Tempered/Heated Glass Damage General Service Bulletin
SSM 47080 - Effective Feb 14 2018
2010-2018 Various Vehicles - Spotify Not Found Or Not Functioning On AppLink
SSM 47070 - Effective Feb 9 2018
Various Vehicles - Data Link Connector (DLC) Connection - Vehicles Equipped With Gateway Module (GWM)
TSB 18-2036 - Effective Feb 7 2018
2015-2018 Mustang Convertible - Roof Sagging At The Rear Glass
GSB G0000168 - Effective Feb 2 2018
Tire Vibration – Equipment Based Diagnostics and Requirements For Warranty Claim Submission
GSB G0000166 - Effective Jan 22 2018
Multiple Vehicles - Surface Preparation For Oil Leaks
GSB G0000167 - Effective Jan 22 2018
Multiple Vehicles - Engine Oil White Fluorescent Dye Usage General Service Bulletin (GSB)
GSB G0000165 - Effective Jan 18 2018
Multiple Vehicles - Lower End Engine Noise Diagnostic Aid - Inspecting the Oil Filter Element General Service Bulletin (GSB)
GSB G0000162 - Effective Jan 17 2018
Multiple Vehicles - Gas Engine Performance Modifications
SSM 47012 - Effective Jan 11 2018
2015-2018 F-150, Mustang, Transit - No Airflow From Climate Control Vents - Air Conditioning (A/C) Clutch Seized And/Or Stuck - Built On Or Before 01-Dec-2017
SSM 46995 - Effective Jan 3 2018
2015-2017 Mustang - Convertible Top Wear Or Damage On Outer Front Edges - Built On Or Before 1-Feb-2017
TSB 17-2271 - Effective Dec 25 2017
Various Vehicles - 2.0L/2.3L/2.7L EcoBoost, 5.0L, 5.2L - Engine Oil Pressure (EOP) Sensor Oil Leak
SSM 46973 - Effective Dec 11 2017
2015 - 2018 GT350 R Spring And Shock Spacer Removal Required At Pre-Delivery Inspection
SSM 46948 - Effective Nov 29 2017
2016-2017 Various Vehicles - SYNC 3 - Mobile Device Inoperative Navigation Applications
SSM 46947 - Effective Nov 29 2017
2016-2017 Ford/Lincoln – SYNC 3 – Intermittent Display Of A Vehicle Image On SYNC Screen
SSM 46930 - Effective Nov 22 2017
2016-2018 Various Ford And Lincoln Vehicles - SYNC 3 Issues With Vehicle In Transport Mode
GSB G0000156 - Effective Nov 8 2017
Passive Anti Theft System (PATS) Key Programming
SSM 46900 - Effective Nov 2 2017
2009-2018 Various Vehicles - No Start - Illuminated MIL And Diagnostic Trouble Code (DTC) P161A After Powertrain Control Module (PCM) Replacement
GSB G0000154 - Effective Oct 18 2017
Multiple Vehicles - Touch Screen Warranty GSB
GSB G0000150 - Effective Sep 27 2017
Various Vehicles - Module Programming and Reprogramming Procedures
SSM 46834 - Effective Sep 21 2017
2016-2017 Various Vehicles - SYNC 3 - Intermittent Blue Or Black Screen
GSB G0000149 - Effective Aug 23 2017
Engine Oil Maintenance Inspection
TSB 17-0062 - Effective Aug 23 2017
2000 And Newer Ford, Lincoln And Mercury Vehicles - Aluminum Panel Corrosion
SSM 46767 - Effective Aug 17 2017
2015-2017 Mustang – 3.7L/5.0L – 6R80 - Clunk/Ping Noise When Shifting From Park To Reverse And/Or Park To Drive Engagement
SSM 46727 - Effective Jul 31 2017
Setting Correct Tire Pressure
GSB G0000145 - Effective Jul 27 2017
Various 2013 and Newer Vehicles - Splice Block General Service Bulletin (GSB)
GSB G0000144 - Effective Jul 17 2017
12 Volt Battery Charging and Testing Quick Reference Guide-
GSB G0000142 - Effective Jun 29 2017
Multiple Vehicles - Wiring Repair / Harness Replacement - Best Practices for Warranty Claiming
GSB G0000141 - Effective Jun 29 2017
Multiple Vehicles - Front Controls Interface Module (FCIM) Warrantable VS Non-warrantable Conditions General Service Bulletin (GSB)
SSM 46659 - Effective Jun 20 2017
2015 - 2016 Mustang - Convertible - Power Door Window One Touch Up And Bounce Back Features
TSB 17-0047 - Effective Jun 1 2017
2016 Mustang - 2.3L GTDI - Illuminated Malfunction Indicator Lamp (MIL) - Diagnostic Trouble Code (DTC) P0456, P1450 And/Or P144C
SSM 46620 - Effective May 23 2017
2016-2017 Multiple Vehicles - 2.0L/2.3L GTDI - Illuminated Malfunction Indicator Lamp (MIL) With Diagnostic Trouble Code (DTC) P0001
SSM 46571 - Effective May 4 2017
2016-2017 Various Ford And Lincoln - SYNC 3 And Navigation – SiriusXM Traffic Listing Not Loading - Software Update
SSM 46561 - Effective May 3 2017
2016 Ford And Lincoln MKX - SYNC 3 And Navigation - Apple CarPlay And/Or Android Auto - Customer Pay Upgrade Available
GSB G0000135 - Effective May 3 2017
2016 Ford And Lincoln - SYNC 3 - Adding Apple CarPlay And/Or Android Auto - Customer Pay Upgrade
GSB G0000136 - Effective May 3 2017
Adaptive Cruise Control & Collision Warning Radar Alignment Process
SSM 46559 - Effective May 3 2017
2016-2017 Various Ford And Lincoln - SYNC 3 And Navigation – Inaccurate GPS And Travel Link Fuel Prices Not Displaying - Software Update
SSM 46560 - Effective May 3 2017
2016 Ford And Lincoln MKX - SYNC 3 Non-Navigation - Apple CarPlay And/Or Android Auto - Customer Pay Upgrade Available
SSM 46465 - Effective Apr 26 2017
2016 - Edge/Explorer/F-150/Mustang - Front Control/Display Interface Module (FCDIM) Blank Screen With 4.2-Inch Display - Built On Or Before 01-Nov-2016
TSB 17-2068 - Effective Apr 18 2017
2016-2017 Various Ford/Lincoln – SYNC 3 – No Rear View Camera Image At Freezing Ambient Temperatures - Built On 01-Jul-2015 And Through 31-Dec-2016
SSM 46486 - Effective Mar 23 2017
2016-2017 Various Ford And Lincoln Vehicles - SYNC 3 Issues With Vehicle In Transport Mode
GSB G0000129 - Effective Mar 14 2017
Multiple Vehicles - Leather/Vinyl Seat Cover General Service Bulletin (GSB)
SSM 46451 - Effective Mar 14 2017
2009-2017 Multiple Vehicles Equipped With 6R80,6R100,6R140 Automatic Transmission - Updated Workshop Manual (WSM) Main Control Valve Body Overhaul Procedure
GSB G0000130 - Effective Mar 14 2017
Multiple Vehicles- Interior Mirror General Service Bulletin (GSB)
GSB G0000126 - Effective Mar 6 2017
Multiple Vehicles - Instrument Panel Cluster Mask / Lens Warrantable Versus Non-Warrantable Conditions
GSB G0000125 - Effective Feb 27 2017
Multiple Vehicles- Body Interior Trim and Steering Wheel Damage vs. Defect General Service Bulletin (GSB)
GSB G0000123 - Effective Feb 7 2017
Multiple Vehicles- Wiper Blade Warrantable Vs. Non-Warrantable General Service Bulletin (GSB)
SSM 46353 - Effective Jan 31 2017
2013-2017 Various Vehicles - Ambient Air Temperature Sensor (AAT) Pinpoint Test Update In Workshop Manual (WSM) Section 413-01
SSM 46332 - Effective Jan 24 2017
2008-2017 Various Ford/Lincoln/Mercury Vehicles - Replacing/Upgrading Original Equipment SYNC/Navigation System Components Is Not Supported
SSM 46295 - Effective Jan 10 2017
Multiple Vehicle Lines - Revised Engine Oil Leak Diagnostic Procedure Using New White Fluorescent Dye
SSM 46173 - Effective Nov 2 2016
Some 2016-2017 GT350 Mustangs Might Exhibit Piston Rattle From Idle To 3000 RPM
SSM 46152 - Effective Oct 26 2016
2015-2016 Mustang - Inoperative Park Aid Camera, Luggage Compartment Lamp, Deck Lid Release And/Or Poor Satellite Radio Reception
SSM 46132 - Effective Oct 17 2016
2008-2017 Ford/Mercury/Lincoln - Vehicle Health Report (VHR) Generates Service Required Message
SSM 46123 - Effective Oct 12 2016
2015-2016 Mustang 5.0L 32V Ti-VCT Engine And Oil Pan Replacement
GSB G0000112 - Effective Oct 10 2016
Multiple Vehicles - SYNC Software Programming v1.1
TSB 16-0139 - Effective Oct 10 2016
2015-2016 - 2.0L/2.5L/3.5L/3.7L - Illuminated Wrench Lamp With Intermittent Loss Of Power - DTCs P2111, P2112 And/Or P2119 - Built On Or Before 31-May-2016
SSM 46102 - Effective Sep 30 2016
Multiple Vehicles - Safety Belt Retractor Webbing Does Not Extract From Stowed Position Or Exhibits Excessive Pressure On The Occupant During Use.
GSB G0000108 - Effective Sep 23 2016
Multiple Vehicles- Paint Defects / Damage General Service Bulletin (GSB)
TSB 16-0121 - Effective Sep 14 2016
2015-2016 Mustang - 2.3L Gasoline Turbocharged Direct Injection (GTDI) - Lack Of Power With DTC P0299 - Built On Or Before 1/1/2016
SSM 46048 - Effective Sep 2 2016
2016-2017 Various Ford and Lincoln Vehicles – SYNC 3 Accessory Protocol Interface Module (APIM) DTCs U3000 Or B108E Or U1A00
GSB G0000107 - Effective Aug 23 2016
Multiple Vehicles- Grille Defects / Damage General Service Bulletin (GSB)
TSB 16-0103 - Effective Aug 10 2016
2015-2017 Mustang - Manual Transmission - No Crank - Built On Or Before 6/15/2016
GSB G0000106 - Effective Aug 10 2016
Multiple Vehicles - Historical Powertrain Diagnostic Trouble Codes (DTC) General Service Bulletin (GSB)
SSM 45945 - Effective Jul 21 2016
2016 F150, Mustang And Explorer - No Audio After Starting The Engine - Screen Displays Loading Or Audio Off Message - Built On Or Before 4/15/2016
SSM 45943 - Effective Jul 20 2016
2011-2016 Various Vehicles - Ambient Air Temperature Sensor (AAT) Pinpoint Test FA And FB Updated
SSM 45938 - Effective Jul 18 2016
2015-2017 Mustang Driveline Vibration At Highway Speeds
SSM 45903 - Effective Jun 28 2016
2015-2017 Shelby GT350 And GT350R Brake Service
TSB 16-0085 - Effective May 24 2016
2015-2016 Mustang 5.2L Ti-VCT - Illuminated Malfunction Indicator Lamp (MIL) With Diagnostic Trouble Codes (DTCs) P0720 And P0722 - Built On Or Before 2/26/2016
GSB G0000097 - Effective May 24 2016
SYNC 3 Intermittent Blank/Black Screen Diagnostic Tips & Flowchart General Service Bulletin (GSB)
SSM 45788 - Effective Apr 29 2016
Some Vehicles Could Exhibit Misfire Codes After Certain Repairs - Multiple Vehicle Lines
GSB G0000094 - Effective Apr 29 2016
Multiple Vehicles - No PCM/Network Communication
SSM 45781 - Effective Apr 27 2016
2015-2016 Mustang GT350 - Extended High Speed Or Track Usage - Diagnostic Trouble Codes (DTCs) P0218 and P1783
GSB G0000093 - Effective Apr 19 2016
Multiple Vehicles - Automatic Transmission Main Control Inspection - General Service Bulletin (GSB)
GSB G0000092 - Effective Apr 5 2016
Multiple Vehicles- Exterior Mirror General Service Bulletin (GSB)
GSB G0000091 - Effective Mar 31 2016
Multiple Vehicles- Glass Panel Build Date Decoder General Service Bulletin (GSB)
SSM 45698 - Effective Mar 15 2016
2016 Various Vehicles - Equipped With SYNC 3 And Navigation - French/Spanish Navigation Guidance Voice Prompts Incorrect
TSB 16-0040 - Effective Mar 4 2016
2016 Mustang GT350-R - Driver Selectable Suspension Malfunction Service Required Message With DTC C103E - Built On 11/1/2015 And Through 12/21/2015
GSB G0000087 - Effective Feb 26 2016
Multiple Vehicles - Engine Failure Analysis General Service Bulletin (GSB)
GSB G0000083 - Effective Feb 25 2016
Multiple Vehicles - Coolant Pump Inspection - General Service Bulletin (GSB)
TSB 16-0017 - Effective Feb 22 2016
2.0 AND 2.3L GTDI - Illuminated MIL - DTC P0011, P0016, P0015 And/Or P0017 - Under 3200 Km (2000 Miles)
SSM 45646 - Effective Feb 17 2016
2015-2016 Various Ford Vehicles - SYNC Gen 1 With 4.2 Inch Display - Bluetooth Pairing And Connection Concerns - Built On Or Before 1/24/2016
GSB G0000082 - Effective Feb 9 2016
Multiple Vehicles- Bumper Warrantable / Non-Warrantable General Service Bulletin (GSB)
SSM 45637 - Effective Feb 8 2016
2016 Various Ford And Lincoln Vehicles Equipped With SYNC 3 - Gen 1 Multi-Media Interface Tester (MIT) Not Compatible With SYNC 3
GSB G0000081 - Effective Feb 3 2016
Multiple Vehicles - Driver On Coil Ignition Test - 3 Wire Coils - General Service Bulletin (GSB)
GSB G0000080 - Effective Feb 3 2016
Multiple Vehicles - PCM Ignition Coil Driver Test - 2 Wire Coil - General Service Bulletin (GSB)
GSB G0000078 - Effective Jan 29 2016
Multiple Vehicles - Environmental Fallout Paint Damage General Service Bulletin (GSB)
GSB G0000076 - Effective Jan 27 2016
Multiple Vehicles- Exterior Lighting Condensation Warranty Coverage General Service Bulletin (GSB)
GSB G0000077 - Effective Jan 27 2016
Multiple Vehicles- Head Lamp Aim Warranty Coverage General Service Bulletin (GSB)
GSB G0000075 - Effective Jan 25 2016
Multiple Vehicles - Electric Power Assist System (EPAS) Pull Drift Compensation General Service Bulletin (GSB)
GSB G0000070 - Effective Dec 21 2015
Multiple Vehicles - How To Upload An IDS Session File - General Service Bulletin (GSB)
GSB G0000066 - Effective Dec 16 2015
Multiple Vehicles - Transmission Cooler Flush General Service Bulletin (GSB)
GSB G0000065 - Effective Dec 16 2015
Various 2013 and newer vehicles - Supplemental Restraints System (SRS) Air Bag Squib Connector GSB
TSB 15-0192 - Effective Dec 15 2015
2015-2016 Mustang - 2.3L Gasoline Turbocharged Direct Injection (GTDI) - Excessive Exhaust Smoke After Extended Idle
GSB G0000053 - Effective Dec 11 2015
Multiple Vehicles - Tire Pressure Monitor System (TPMS) General Service Bulletin (GSB)
GSB G0000048 - Effective Dec 7 2015
Multiple Vehicles - PSCM Wiring Harness Inspection Checklist General Service Bulletin (GSB)
SSM 45500 - Effective Dec 4 2015
Alarm Activation During Remote Start, 2015 And 2016 Mustang Convertible With Remote Start Produced On Or Before 10/21/2015
SSM 45493 - Effective Dec 1 2015
2015-2016 Mustang/Focus - With 4.2\" SYNC Display - SYNC Accessory Protocol Interface Module (APIM) Programming Using Front SYNC Universal Serial Bus (USB) Port
GSB G0000045 - Effective Nov 26 2015
Multiple Vehicles- Body Gap Flushness Measurement Tools General Service Bulletin (GSB)
GSB G0000043 - Effective Nov 26 2015
Various Vehicles - Live Network Monitor Test Usage
GSB G0000036 - Effective Nov 16 2015
Multiple Vehicles - Wheel Concern Analysis General Service Bulletin (GSB)
SSM 45418 - Effective Oct 23 2015
Dealer Installed Audio Upgrades
SSM 45412 - Effective Oct 22 2015
2011-2016 Multiple Vehicles – Universal Garage Door Programming Concerns
GSB G0000033 - Effective Oct 21 2015
Multple Vehicles - Wiring Repair General Service Bulletin (GSB)
GSB G0000029 - Effective Oct 14 2015
Multiple Vehicles - Brake Disc Service Tips General Service Bulletin (GSB)
GSB G0000031 - Effective Oct 14 2015
Multiple Vehicles- Tape Stripe General Service Bulletin (GSB)
TSB 15-0144 - Effective Sep 22 2015
2015-2016 Mustang - Climate Controlled Seats - Lack of Cooling - Front Seat Backrest
GSB G0000017 - Effective Sep 16 2015
2013 And Newer Vehicles - Gasoline Engine - Adaptive Fuel Viewer GSB
GSB G0000010 - Effective Aug 26 2015
2015-2016 Multiple Vehicles- New SYNC Accessory Protocol Interface Module (APIM) System Reset General Service Bulletin (GSB)
GSB G0000006 - Effective Aug 25 2015
Multiple Vehicles - Cloth Seat Cover General Service Bulletin (GSB)
SSM 45180 - Effective Jun 23 2015
Integrated Diagnostic System (IDS) Session File Upload Request When Replacing A Powertrain Control Module (PCM)
