April 19, 20187 yr comment_161055 Här kommer bullelistan för Mustang 2018. OBS: DETTA ÄR INGA ÅTERKALLELSER. DESSA GÅR BARA ATT FÅ FRAM PÅ CHASSIENUMRET. GSB G0000175 - Effective Apr 19 2018 Ambient Air Temperature (AAT) Sensor TSB 18-2119 - Effective Apr 17 2018 2018 Expedition/F-150/Mustang/Navigator – 10R80 - Illuminated MIL – DTC P0721 – Built On Or Before 30-Nov-2017 SSM 47229 - Effective Apr 11 2018 2018 Various Vehicles Equipped With Telematics Control Unit (TCU) - Various FordPass/LincolnWay Mobile App Concerns SSM 47225 - Effective Apr 10 2018 2015-2018 Mustang - Equipped With Sync 3 - Inoperative Universal Serial Bus (USB) Ports With DTC B1252:13 - Built On Or Before 1-Jan-2018 SSM 47219 - Effective Apr 6 2018 2018 Various Vehicles Equipped With Sync Or Sync 3 - Unable To Connect To Vehicles Internal 4G WI-FI Hotspot For Automatic Updates GSB G0000174 - Effective Apr 6 2018 2013-2018 Various Vehicles - Instrument Panel Cluster Mask / Lens Warranty TSB 18-2107 - Effective Mar 30 2018 2015-2018 Mustang GT350 - Excessive Panel Gap Between Rear Bumper Cover And Rear Quarter Panels - Built On Or Before 26-Feb-2018 SSM 47200 - Effective Mar 30 2018 2015-2018 Mustang - No Horizontal Adjustment Of Front Power Seats - Power Seat Track Motor Inoperative GSB G0000172 - Effective Mar 30 2018 2010-2018 Various Vehicles - Ear Clamp Removal Procedure SSM 47201 - Effective Mar 30 2018 2008-2018 Various Ford/Lincoln/Mercury Vehicles - Replacing/Upgrading Original Equipment SYNC/Navigation System Components Is Not Supported SSM 47170 - Effective Mar 21 2018 2017- 2018 Multiple Vehicles - Illuminated Malfunction Indicator Lamp (MIL) With Variable Cam Timing (VCT) DTCs - Diagnostic Information TSB 18-2083 - Effective Mar 21 2018 2018 Mustang - 5.0L - Manual Transmission - Inability Or Difficulty To Shift Into Second Gear - Built On Or Before 15-Nov-2017 SSM 47172 - Effective Mar 21 2018 2018 Mustang and F-150 2.7L, 3.3L, 3.5L and 5.0L, Expedition, Navigator with 3.5L GTDI Engines- Illuminated Malfunction Indicator Lamp (MIL) With DTC P0181 SSM 47171 - Effective Mar 21 2018 2016-2018 Various Vehicles - SYNC 3 - iPhone USB Audio Playback And App Link Functionality Issues GSB G0000171 - Effective Feb 27 2018 Laminated/Tempered/Heated Glass Damage General Service Bulletin SSM 47093 - Effective Feb 19 2018 2017-2018 F-150/Raptor, 2018 Expedition/Navigator/Mustang - 10R80 - New Transmission Fluid MERCON ULV XT-12-QULV SSM 47082 - Effective Feb 15 2018 2018 Mustang - Convertible - Slow Or No Retraction Of The Front Seat Shoulder Belts. SSM 47080 - Effective Feb 14 2018 2010-2018 Various Vehicles - Spotify Not Found Or Not Functioning On AppLink SSM 47070 - Effective Feb 9 2018 Various Vehicles - Data Link Connector (DLC) Connection - Vehicles Equipped With Gateway Module (GWM) TSB 18-2036 - Effective Feb 7 2018 2015-2018 Mustang Convertible - Roof Sagging At The Rear Glass SSM 47057 - Effective Feb 5 2018 2018 Mustang 5.0L/F-150 3.3L - Illuminated Malfunction Indicator Lamp (MIL) With Diagnostic Trouble Code (DTC) P0111 GSB G0000168 - Effective Feb 2 2018 Tire Vibration – Equipment Based Diagnostics and Requirements For Warranty Claim Submission SSM 47049 - Effective Jan 31 2018 2018 Various Vehicles - SYNC 3 - SYNC WiFi Update Message Displayed Every Key Cycle GSB G0000166 - Effective Jan 22 2018 Multiple Vehicles - Surface Preparation For Oil Leaks GSB G0000167 - Effective Jan 22 2018 Multiple Vehicles - Engine Oil White Fluorescent Dye Usage General Service Bulletin (GSB) GSB G0000165 - Effective Jan 18 2018 Multiple Vehicles - Lower End Engine Noise Diagnostic Aid - Inspecting the Oil Filter Element General Service Bulletin (GSB) GSB G0000162 - Effective Jan 17 2018 Multiple Vehicles - Gas Engine Performance Modifications SSM 47012 - Effective Jan 11 2018 2015-2018 F-150, Mustang, Transit - No Airflow From Climate Control Vents - Air Conditioning (A/C) Clutch Seized And/Or Stuck - Built On Or Before 01-Dec-2017 SSM 47008 - Effective Jan 10 2018 2018 Mustang – Service Tire Mobility Kit Message In Instrument Panel Cluster (IPC) SSM 46997 - Effective Jan 5 2018 2018 Mustang – Lack Of On Center Feel And Overall Power Steering Feel Performance SSM 46973 - Effective Dec 11 2017 2015 - 2018 GT350 R Spring And Shock Spacer Removal Required At Pre-Delivery Inspection SSM 46930 - Effective Nov 22 2017 2016-2018 Various Ford And Lincoln Vehicles - SYNC 3 Issues With Vehicle In Transport Mode GSB G0000156 - Effective Nov 8 2017 Passive Anti Theft System (PATS) Key Programming SSM 46900 - Effective Nov 2 2017 2009-2018 Various Vehicles - No Start - Illuminated MIL And Diagnostic Trouble Code (DTC) P161A After Powertrain Control Module (PCM) Replacement GSB G0000154 - Effective Oct 18 2017 Multiple Vehicles - Touch Screen Warranty GSB GSB G0000150 - Effective Sep 27 2017 Various Vehicles - Module Programming and Reprogramming Procedures GSB G0000145 - Effective Jul 27 2017 Various 2013 and Newer Vehicles - Splice Block General Service Bulletin (GSB) GSB G0000144 - Effective Jul 17 2017 12 Volt Battery Charging and Testing Quick Reference Guide- GSB G0000142 - Effective Jun 29 2017 Multiple Vehicles - Wiring Repair / Harness Replacement - Best Practices for Warranty Claiming GSB G0000141 - Effective Jun 29 2017 Multiple Vehicles - Front Controls Interface Module (FCIM) Warrantable VS Non-warrantable Conditions General Service Bulletin (GSB) GSB G0000130 - Effective Mar 14 2017 Multiple Vehicles- Interior Mirror General Service Bulletin (GSB) GSB G0000125 - Effective Feb 27 2017 Multiple Vehicles- Body Interior Trim and Steering Wheel Damage vs. Defect General Service Bulletin (GSB) GSB G0000108 - Effective Sep 23 2016 Multiple Vehicles- Paint Defects / Damage General Service Bulletin (GSB) GSB G0000094 - Effective Apr 29 2016 Multiple Vehicles - No PCM/Network Communication GSB G0000092 - Effective Apr 5 2016 Multiple Vehicles- Exterior Mirror General Service Bulletin (GSB) GSB G0000076 - Effective Jan 27 2016 Multiple Vehicles- Exterior Lighting Condensation Warranty Coverage General Service Bulletin (GSB) GSB G0000036 - Effective Nov 16 2015 Multiple Vehicles - Wheel Concern Analysis General Service Bulletin (GSB) GSB G0000006 - Effective Aug 25 2015 Multiple Vehicles - Cloth Seat Cover General Service Bulletin (GSB) No applicable TSBs found. No applicable GSBs found. No applicable SSMs found. GSB G0000175 - Effective Apr 19 2018 Ambient Air Temperature (AAT) Sensor TSB 18-2119 - Effective Apr 17 2018 2018 Expedition/F-150/Mustang/Navigator – 10R80 - Illuminated MIL – DTC P0721 – Built On Or Before 30-Nov-2017 SSM 47229 - Effective Apr 11 2018 2018 Various Vehicles Equipped With Telematics Control Unit (TCU) - Various FordPass/LincolnWay Mobile App Concerns SSM 47225 - Effective Apr 10 2018 2015-2018 Mustang - Equipped With Sync 3 - Inoperative Universal Serial Bus (USB) Ports With DTC B1252:13 - Built On Or Before 1-Jan-2018 SSM 47219 - Effective Apr 6 2018 2018 Various Vehicles Equipped With Sync Or Sync 3 - Unable To Connect To Vehicles Internal 4G WI-FI Hotspot For Automatic Updates GSB G0000174 - Effective Apr 6 2018 2013-2018 Various Vehicles - Instrument Panel Cluster Mask / Lens Warranty TSB 18-2107 - Effective Mar 30 2018 2015-2018 Mustang GT350 - Excessive Panel Gap Between Rear Bumper Cover And Rear Quarter Panels - Built On Or Before 26-Feb-2018 SSM 47200 - Effective Mar 30 2018 2015-2018 Mustang - No Horizontal Adjustment Of Front Power Seats - Power Seat Track Motor Inoperative GSB G0000172 - Effective Mar 30 2018 2010-2018 Various Vehicles - Ear Clamp Removal Procedure SSM 47201 - Effective Mar 30 2018 2008-2018 Various Ford/Lincoln/Mercury Vehicles - Replacing/Upgrading Original Equipment SYNC/Navigation System Components Is Not Supported SSM 47170 - Effective Mar 21 2018 2017- 2018 Multiple Vehicles - Illuminated Malfunction Indicator Lamp (MIL) With Variable Cam Timing (VCT) DTCs - Diagnostic Information TSB 18-2083 - Effective Mar 21 2018 2018 Mustang - 5.0L - Manual Transmission - Inability Or Difficulty To Shift Into Second Gear - Built On Or Before 15-Nov-2017 SSM 47172 - Effective Mar 21 2018 2018 Mustang and F-150 2.7L, 3.3L, 3.5L and 5.0L, Expedition, Navigator with 3.5L GTDI Engines- Illuminated Malfunction Indicator Lamp (MIL) With DTC P0181 SSM 47171 - Effective Mar 21 2018 2016-2018 Various Vehicles - SYNC 3 - iPhone USB Audio Playback And App Link Functionality Issues GSB G0000171 - Effective Feb 27 2018 Laminated/Tempered/Heated Glass Damage General Service Bulletin SSM 47093 - Effective Feb 19 2018 2017-2018 F-150/Raptor, 2018 Expedition/Navigator/Mustang - 10R80 - New Transmission Fluid MERCON ULV XT-12-QULV SSM 47082 - Effective Feb 15 2018 2018 Mustang - Convertible - Slow Or No Retraction Of The Front Seat Shoulder Belts. SSM 47080 - Effective Feb 14 2018 2010-2018 Various Vehicles - Spotify Not Found Or Not Functioning On AppLink SSM 47070 - Effective Feb 9 2018 Various Vehicles - Data Link Connector (DLC) Connection - Vehicles Equipped With Gateway Module (GWM) TSB 18-2036 - Effective Feb 7 2018 2015-2018 Mustang Convertible - Roof Sagging At The Rear Glass SSM 47057 - Effective Feb 5 2018 2018 Mustang 5.0L/F-150 3.3L - Illuminated Malfunction Indicator Lamp (MIL) With Diagnostic Trouble Code (DTC) P0111 GSB G0000168 - Effective Feb 2 2018 Tire Vibration – Equipment Based Diagnostics and Requirements For Warranty Claim Submission SSM 47049 - Effective Jan 31 2018 2018 Various Vehicles - SYNC 3 - SYNC WiFi Update Message Displayed Every Key Cycle GSB G0000166 - Effective Jan 22 2018 Multiple Vehicles - Surface Preparation For Oil Leaks GSB G0000167 - Effective Jan 22 2018 Multiple Vehicles - Engine Oil White Fluorescent Dye Usage General Service Bulletin (GSB) GSB G0000165 - Effective Jan 18 2018 Multiple Vehicles - Lower End Engine Noise Diagnostic Aid - Inspecting the Oil Filter Element General Service Bulletin (GSB) GSB G0000162 - Effective Jan 17 2018 Multiple Vehicles - Gas Engine Performance Modifications SSM 47012 - Effective Jan 11 2018 2015-2018 F-150, Mustang, Transit - No Airflow From Climate Control Vents - Air Conditioning (A/C) Clutch Seized And/Or Stuck - Built On Or Before 01-Dec-2017 SSM 47008 - Effective Jan 10 2018 2018 Mustang – Service Tire Mobility Kit Message In Instrument Panel Cluster (IPC) SSM 46997 - Effective Jan 5 2018 2018 Mustang – Lack Of On Center Feel And Overall Power Steering Feel Performance SSM 46973 - Effective Dec 11 2017 2015 - 2018 GT350 R Spring And Shock Spacer Removal Required At Pre-Delivery Inspection SSM 46930 - Effective Nov 22 2017 2016-2018 Various Ford And Lincoln Vehicles - SYNC 3 Issues With Vehicle In Transport Mode GSB G0000156 - Effective Nov 8 2017 Passive Anti Theft System (PATS) Key Programming SSM 46900 - Effective Nov 2 2017 2009-2018 Various Vehicles - No Start - Illuminated MIL And Diagnostic Trouble Code (DTC) P161A After Powertrain Control Module (PCM) Replacement GSB G0000154 - Effective Oct 18 2017 Multiple Vehicles - Touch Screen Warranty GSB GSB G0000150 - Effective Sep 27 2017 Various Vehicles - Module Programming and Reprogramming Procedures GSB G0000145 - Effective Jul 27 2017 Various 2013 and Newer Vehicles - Splice Block General Service Bulletin (GSB) GSB G0000144 - Effective Jul 17 2017 12 Volt Battery Charging and Testing Quick Reference Guide- GSB G0000142 - Effective Jun 29 2017 Multiple Vehicles - Wiring Repair / Harness Replacement - Best Practices for Warranty Claiming GSB G0000141 - Effective Jun 29 2017 Multiple Vehicles - Front Controls Interface Module (FCIM) Warrantable VS Non-warrantable Conditions General Service Bulletin (GSB) GSB G0000130 - Effective Mar 14 2017 Multiple Vehicles- Interior Mirror General Service Bulletin (GSB) GSB G0000125 - Effective Feb 27 2017 Multiple Vehicles- Body Interior Trim and Steering Wheel Damage vs. Defect General Service Bulletin (GSB) GSB G0000108 - Effective Sep 23 2016 Multiple Vehicles- Paint Defects / Damage General Service Bulletin (GSB) GSB G0000094 - Effective Apr 29 2016 Multiple Vehicles - No PCM/Network Communication GSB G0000092 - Effective Apr 5 2016 Multiple Vehicles- Exterior Mirror General Service Bulletin (GSB) GSB G0000076 - Effective Jan 27 2016 Multiple Vehicles- Exterior Lighting Condensation Warranty Coverage General Service Bulletin (GSB) GSB G0000036 - Effective Nov 16 2015 Multiple Vehicles - Wheel Concern Analysis General Service Bulletin (GSB) GSB G0000006 - Effective Aug 25 2015 Multiple Vehicles - Cloth Seat Cover General Service Bulletin (GSB) Back Ändrade %s av %s (%s)
April 19, 20187 yr comment_161058 Tack Bör man få något av ovanstående åtgärdat? Exv 2017-2018 F-150/Raptor, 2018 Expedition/Navigator/Mustang - 10R80 - New Transmission Fluid MERCON ULV XT-12-QUL
April 19, 20187 yr Author comment_161063 5 timmar sedan, RRS550 said: Tack Bör man få något av ovanstående åtgärdat? Exv 2017-2018 F-150/Raptor, 2018 Expedition/Navigator/Mustang - 10R80 - New Transmission Fluid MERCON ULV XT-12-QUL Texten ovan beskriver att ford har en ny växellådsolja som heter ULV. Texten förklarar även vilka bilar den är till. När din servicebok föreskriver att växellådsoljan skall bytas så skall den bytas med Mercon ULV, precis samma olja som du har idag. 5 timmar sedan, RRS550 said:
April 20, 20187 yr comment_161076 14 timmar sedan, grufman said: Tack för klargörandet. Är det någon av punkterna som ni ser bör åtgärdas på en 2018?
September 1, 20187 yr comment_163405 Hej Lyfter tråden. Har det kommit några nya tsb/bulletiner för 2018 modellen
