comment_187493
Gör såhär:
To program a key fob for a 2005 Ford Mustang, you'll need to cycle the ignition key from OFF to RUN eight times within 10 seconds, leaving it in the RUN position on the eighth cycle. The door locks will cycle to indicate programming mode. Then, press any button on the remote to be programmed, and the door locks will cycle again to confirm. Repeat this process for any additional remotes.
