grufman November 12, 2007 Report November 12, 2007 Här kommer en lista på aktuella bulletiner gällande mustang 04. Detta är alltså serviceinformation som ford gett ut och som kan handla om garantiåtaganden och andra serviceproblem på den aktuella bilmodellen. Observera att detta endast är rubrikerna. om du vill läsa innehållet i en specifik TSB, maila så lägger jag ut den.07-21-24.6L 2V, 5.4L 2V, OR 6.8L 2V - SPARK PLUG THREAD REPAIR PROCEDURE - NOT COVERED UNDER NEW VEHICLE LIMITED WARRANTY07-16-17SPARK KNOCK UNDER LIGHT LOAD AND ACCELERATION - 3.8L, 3.9L, AND 4.2L - SPLIT PORT INTAKE MANIFOLD RUNNER CONTROL (IMRC)07-5-8BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS07-4-3LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE07-1-7MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS06-26-1MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS06-21-19HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY)06-18-16IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES - SERVICE TIP06-15-8KEYPAD DIAGNOSTICS - DEALER INSTALLED ACCESSORY06-8-5SPEED CONTROL DIAGNOSTICS - W/O SCP06-5-13ENGINE MISFIRE WITH DIAGNOSTIC TROUBLE CODE (DTC) P0301, P0302, P0303, P0304, P0305, P0306, P0307, P0308, AND P0316.06-4-9A/C COMPRESSOR NOT OPERATIONAL / LOW FREON - SHAFT SEAL LEAKS06-4-4LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS05-22-8WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING05-18-7WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS05-14-3SQUEAK/CREAK NOISE FROM STEERING RACK WHEN TURNING05-9-3INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS05-3-10SAFETY BELT WEB STOP BUTTON SERVICE04-26-131-2 SHIFT CLASH, GRIND OR HARD TO SHIFT - TR3650 5 SPEED MANUAL TRANSMISSION04-24-5REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR04-21-6EXHAUST LEAK - CRACKED OR SEPARATED RIGHT SIDE EXHAUST PIPE - 3.8L AND 3.9L ENGINES04-19-8MANUAL TRANSMISSION HARD TO SHIFT INTO FIRST/REVERSE FROM A STOP04-17-4MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - SYSTEM LEAN DIAGNOSTIC TROUBLE CODES (DTC'S) - SERVICE TIPS04-13-4TRANSMISSION RATTLE NOISE OR DIFFICULT TO SHIFT - TREMEC T56 6 SPEED MANUAL04-9-6BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION04-5-3CLIMATE CONTROL - RATTLE NOISE FROM INSTRUMENT PANEL VENTS - DIFFICULT TO ADJUSTNOISE - CLIMATE CONTROL - RATTLE NOISE FROM INSTRUMENT PANEL VENTS - DIFFICULT TO ADJUST03-25-6ENGINE - ROMEO BUILT 4.6L 2V - TICK NOISE FROM ENGINE - ENGINES BUILT BEFORE 9/17/200303-23-2BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS03-22-1BODY - NOISE - HOOD SCOOP (SHAKER) RATTLE NOISEENGINE - NOISE - HOOD SCOOP (SHAKER) RATTLE NOISENOISE - HOOD SCOOP (SHAKER) RATTLE NOISE03-18-1ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS Citera
