grufman November 12, 2007 Report November 12, 2007 Här kommer en lista på aktuella bulletiner gällande mustang 98. Detta är alltså serviceinformation som ford gett ut och som kan handla om garantiåtaganden och andra serviceproblem på den aktuella bilmodellen. Observera att detta endast är rubrikerna. om du vill läsa innehållet i en specifik TSB, maila så lägger jag ut den. 07-21-24.6L 2V, 5.4L 2V, OR 6.8L 2V - SPARK PLUG THREAD REPAIR PROCEDURE - NOT COVERED UNDER NEW VEHICLE LIMITED WARRANTY07-1-7MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS06-26-1MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS06-21-19HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY)05-22-8WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING03-23-2BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS03-20-3DRIVEABILITY - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DTC'S P0442, P0455, P0456, P0457, P1442 OR CHECK FUEL CAP LAMP ILLUMINATED WITH DTC P045703-18-1ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS03-14-8TRANSMISSION - NEW TRANSMISSION COOLER FLUSHER - SERVICE TIPS02-22-1DRIVEABILITY - SURGE/ROLLING IDLE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATIONENGINE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION02-21-13ENGINE - STRAIGHTEDGE PROCEDURE FOR CHECKING CYLINDER HEAD AND BLOCK FLATNESS02-17-6LAMP - BRAKE - INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK02-16-4FUEL SYSTEM - FUEL PUMP "WHINING"/"BUZZING" NOISE COMES THROUGH ENTERTAINMENT OR TWO-WAY RADIO SPEAKERRADIO - ENTERTAINMENT OR TWO-WAY COMMUNICATION - "WHINING"/"BUZZING" NOISE IN SPEAKERS CAUSED BY FUEL PUMPNOISE - "WHINING"/"BUZZING" - COMES THROUGH SPEAKERS OF ENTERTAINMENT OR TWO-WAY RADIO02-11-4ENGINE - NEW GASKET REMOVER/CLEANER AND SERVICE TIPS FOR ALUMINUM HEADS AND BLOCKS02-2-2COOLANT - COOLANT SEEPAGE AT INTAKE MANIFOLD CROSS-OVER - VEHICLES EQUIPPED WITH 4.6L 2V ENGINE ONLYENGINE - 4.6L 2V - COOLANT SEEPAGE AT INTAKE MANIFOLD CROSS-OVER02-1-9ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY01-23-6ENGINE COOLANT - PROPYLENE GLYCOL - FORD MOTOR COMPANY POSITION ON ENGINE COOLANTS MADE FROM PROPYLENE GLYCOLENGINE COOLANT - PROPYLENE GLYCOL-BASED - FORD MOTOR COMPANY POSITION ON PROPYLENE GLYCOL-BASED ENGINE COOLANTS01-23-5TRANSMISSION - T-45 MANUAL TRANSMISSION - STUCK IN REVERSE - DIFFICULT TO SHIFT INTO REVERSE - POPS OUT OF REVERSE01-21-13DRIVEABILITY - DIAGNOSTIC TROUBLE CODES (DTC) P0500, P1502 AND/OR U1039 CONTINENTAL MODELS ONLY - STICKING OR BINDING IGNITION LOCK CYLINDER - HIGH EFFORT WHEN TURNING IGNITION SWITCHELECTRICAL - STICKING OR BINDING IGNITION LOCK CYLINDER - HIGH EFFORT WHEN TURNING IGNITION SWITCH01-21-10ENGINE - 4.6L - OIL LEAK FROM HEAD GASKET AREA - ROMEO BUILT ENGINES ONLY01-10-12WIRING - WIRE HARNESS TERMINAL REPAIR KIT AND WIRE SPLICE PROCEDURE01-9-7DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY01-6-2PASSIVE ANTI THEFT SYSTEM (PATS) - DIAGNOSTIC SERVICE TIPS00-23-10TRANSMISSION - FLUID IN-LINE FILTER KIT - REPEAT REPAIRS OF TRANSMISSION - SERVICE TIPS00-21-2HOOD - HOOD REQUIRES EXCESSIVE EFFORT TO CLOSE - SERVICE TIPS00-9-7VIBRATION/SHAKE - AT STEADY SPEED APPROXIMATELY 100 KM/H (62 MPH) - VEHICLES WITH 4.6L ENGINE AND CONVERTIBLE TOP00-9-1LEAK - TRANSMISSION FLUID LEAKS AT RADIATOR - VEHICLES EQUIPPED WITH AUTOMATIC TRANSMISSION AND TRANSMISSION OIL COOLER IN RADIATOR END TANK00-4-2VIBRATION/SHAKE - AT STEADY SPEED APPROXIMATELY 100 KM/H (62 MPH) - VEHICLES WITH 3.8L ENGINE AND CONVERTIBLE TOP99-24-2LOCKS - REPLACE AND/OR REPAIR ANY LOCK COMPONENT - AVAILABILITY OF INDIVIDUAL LOCKS99-23-4MALFUNCTION INDICATOR LAMP (MIL) - DIAGNOSTIC TROUBLE CODES (DTCS) P0442 AND P0455 - NO DRIVEABILITY CONCERNS99-22-5CONVERTIBLE TOP - IMPROPER FIT OF CONVERTIBLE TOP BOOT99-20-7COOLING SYSTEM - 3.8L - UNDETERMINED LOSS OF COOLANTCOOLING SYSTEM - 4.2L - UNDETERMINED LOSS OF COOLANTENGINE - 3.8L - ENGINE OIL CONTAMINATED WITH COOLANTENGINE - 4.2L - ENGINE OIL CONTAMINATED WITH COOLANT99-18-5TRANSMISSION CONTROL INDICATOR LAMP (TCIL) - TCIL ILLUMINATED WITH DIAGNOSTIC TROUBLE CODE (DTC) P0782 STORED IN MEMORY - VEHICLES BUILT BETWEEN 3/15/1997 AND 12/31/1998 AND WITH 4R70W TRANSMISSIONTRANSMISSION - 4R70W - DELAYED OR NO 2-3 UPSHIFT - VEHICLES BUILT BETWEEN 3/15/1997 AND 12/31/199899-11-1NOISE - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESSVIBRATION - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS99-10-1BODY - DUST INTRUSION INTO LUGGAGE COMPARTMENTWATER LEAK - EVIDENCE OF WATER LEAK INTO LUGGAGE COMPARTMENTNOISE - EXCESSIVE ROAD NOISE HEARD FROM REAR WHEEL AREA99-8-15INTERIOR TRIM - DOOR TRIM PANEL REPLACEMENT - SERVICE TIP99-5-3TRANSMISSION - CHECKING TRANSMISSION FLUID LEVEL COLD - SERVICE TIP99-4-3REPROGRAMMING POWERTRAIN CONTROL MODULES (PCMS) - OUT-OF-VEHICLE - EEC V VEHICLES ONLY99-2-3WATER LEAKS - WINDSHIELD SEALING - SERVICE TIPWINDSHIELD - SEALING - SERVICE TIP98-5A-5BRAKES - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENTBRAKE ROTOR MACHINING - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT98-26-2FUEL - INFORMATION ON GASOLINE - TIPS TO RESOLVE VOLATILITY RELATED DRIVEABILITY CONCERNS98-25-9INTERIOR TRIM - REPAIRS TO VINYL COVERED SURFACES - SERVICE TIP98-25-3GLASS - FRONT WINDOW MAY TRAVEL BEYOND THE UPSTOP AND OUT OF THE GLASS RUN98-24-6ELECTRICAL - NEW TERMINAL GREASE RELEASED FOR SERVICE98-23-12TRANSMISSION - 4R44E - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORYTRANSMISSION - 4R55E - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORYTRANSMISSION - 4R70W - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORYTRANSMISSION - 5R55E - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORYTRANSMISSION - AX4N - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORYTRANSMISSION - AX4S - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORYTRANSMISSION - E4OD - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY98-23-10MASS AIR FLOW (MAF) - SENSOR CONTAMINATION - SERVICE TIP98-22-2CLUTCH - VIBRATION/NOISE FELT IN CLUTCH PEDAL WHEN LIGHTLY TOUCHING CLUTCH PEDAL98-20-18FRONT END ACCESSORY DRIVE (FEAD) BELT - BELT NOISE, DAMAGE, AND/OR BELT COMES OFF - VEHICLES WITH 4.6L ENGINE AND MANUAL TRANSMISSION98-20-10EXHAUST SYSTEM - LOOSE CATALYST OR MUFFLER HEAT SHIELDSNOISE - "BUZZING" OR "RATTLING" - LOOSE CATALYST OR MUFFLER HEAT SHIELDS98-20-3BODY - ADHESIVES NOT RECOMMENDED FOR BODY PANEL REPAIRS - SERVICE TIP98-18-2PAINT - EXTERIOR - WORLDWIDE RECOMMENDED PAINT MATERIALS FOR WARRANTY AND AFTER WARRANTY REPAIRS98-17-18MOULDINGS - ROCKER PANEL - LOOSE98-12-5AIR CONDITIONING - FILTERING REFRIGERANT AFTER A/C COMPRESSOR REPLACEMENT - SERVICE TIPS98-9-9FUEL INJECTORS - NON-WARRANTY REIMBURSEMENT TESTING INFORMATION98-7-4LEAKS - OIL - AVAILABILITY OF NEW SILICONE GASKET AND SEALANT98-5-2TIRE - TIRE COMPANY TELEPHONE NUMBERS FOR CUSTOMER ASSISTANCE98-4-12TRANSMISSION - 4R70W - SERVICE PROCEDURE FOR ORANGE SERVICE TAGGED TRANSMISSIONS98-4-4PAINT - ANTI-CHIP STONE ABRASION UNDERCOAT - SERVICE TIP97-25A-1EVAPORATIVE EMISSIONS SUPPLEMENT97-24-13REMOTE KEYLESS ENTRY (RKE) - DIAGNOSTIC SERVICE TIPS97-21-10TRANSMISSION - 4R70W - NEW DESIGN ENHANCEMENTS FOR 1998 VEHICLESTRANSMISSION - 4R70W - NEW ONE-WAY CLUTCH (OWC) TO SERVICE AT THE INTERMEDIATE POSITION97-19-11COOLING SYSTEM - "ON-VEHICLE" HEATER CORE PRESSURE TEST REQUIRED FOR WARRANTY CLAIM97-15-5AIR CONDITIONING - OIL REFILL CAPACITY CHART - SERVICE TIP Citera
