comment_45442
Här kommer en lista på aktuella bulletiner gällande mustang 95. Detta är alltså serviceinformation som ford gett ut och som kan handla om garantiåtaganden och andra serviceproblem på den aktuella bilmodellen.
Observera att detta endast är rubrikerna. om du vill läsa innehållet i en specifik TSB, maila så lägger jag ut den.
06-26-1
MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS
03-23-2
BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS
03-18-1
ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS
03-14-8
TRANSMISSION - NEW TRANSMISSION COOLER FLUSHER - SERVICE TIPS
02-17-6
LAMP - BRAKE - INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK
02-16-4
FUEL SYSTEM - FUEL PUMP "WHINING"/"BUZZING" NOISE COMES THROUGH ENTERTAINMENT OR TWO-WAY RADIO SPEAKER
RADIO - ENTERTAINMENT OR TWO-WAY COMMUNICATION - "WHINING"/"BUZZING" NOISE IN SPEAKERS CAUSED BY FUEL PUMP
NOISE - "WHINING"/"BUZZING" - COMES THROUGH SPEAKERS OF ENTERTAINMENT OR TWO-WAY RADIO
02-11-4
ENGINE - NEW GASKET REMOVER/CLEANER AND SERVICE TIPS FOR ALUMINUM HEADS AND BLOCKS
02-1-9
ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY
01-23-6
ENGINE COOLANT - PROPYLENE GLYCOL - FORD MOTOR COMPANY POSITION ON ENGINE COOLANTS MADE FROM PROPYLENE GLYCOL
ENGINE COOLANT - PROPYLENE GLYCOL-BASED - FORD MOTOR COMPANY POSITION ON PROPYLENE GLYCOL-BASED ENGINE COOLANTS
01-21-6
ELECTRICAL - REVISED MECHANICAL HOOD LAMP SWITCH TO REPLACE OLD STYLE MERCURY HOOD LAMP SWITCH
01-10-12
WIRING - WIRE HARNESS TERMINAL REPAIR KIT AND WIRE SPLICE PROCEDURE
01-9-7
DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY
00-23-10
TRANSMISSION - FLUID IN-LINE FILTER KIT - REPEAT REPAIRS OF TRANSMISSION - SERVICE TIPS
00-21-2
HOOD - HOOD REQUIRES EXCESSIVE EFFORT TO CLOSE - SERVICE TIPS
99-22-5
CONVERTIBLE TOP - IMPROPER FIT OF CONVERTIBLE TOP BOOT
99-11-1
NOISE - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS
VIBRATION - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS
99-8-15
INTERIOR TRIM - DOOR TRIM PANEL REPLACEMENT - SERVICE TIP
99-4-3
REPROGRAMMING POWERTRAIN CONTROL MODULES (PCMS) - OUT-OF-VEHICLE - EEC V VEHICLES ONLY
99-2-3
WATER LEAKS - WINDSHIELD SEALING - SERVICE TIP
WINDSHIELD - SEALING - SERVICE TIP
98-5A-13
BRAKES - DISC BRAKE CALIPER SLIDE GREASE - NEW SPECIFICATION - SILICONE BRAKE CALIPER GREASE AND DIELECTRIC COMPOUND ONLY TO BE USED
BRAKES - DRUM - SHOE-TO-BACKING PLATE LUBRICATION - NEW LUBRICANT MATERIAL
BRAKES - PETROLEUM-BASED LUBRICANT MAY CAUSE SWELLING OF RUBBER PARTS - SERVICE TIP
LUBRICANT - SILICONE DIELECTRIC COMPOUND - NEW APPLICATION - SILICONE BRAKE CALIPER GREASE AND DIELECTRIC COMPOUND
98-5A-11
BRAKES - ELIMINATION OF SANDING ROTORS AND DRUMS - SERVICE TIP
98-5A-10
BRAKES - REAR BRAKE "SQUEAK" - VEHICLES BUILT THROUGH 11/20/94
NOISE - "SQUEAKING" FROM REAR BRAKES - VEHICLES BUILT THROUGH 11/20/94
98-5A-8
BRAKES - "RUBBING" NOISE FROM UNDERNEATH VEHICLE - PARKING BRAKE CABLE CONDUIT CONTACTING DRIVESHAFT
NOISE - "RUBBING" NOISE FROM UNDERNEATH VEHICLE - PARKING BRAKE CABLE CONDUIT CONTACTING DRIVESHAFT
98-5A-5
BRAKES - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT
BRAKE ROTOR MACHINING - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT
98-5A-4
BRAKES - PREVENTING BRAKE VIBRATION - SERVICE TIP
WHEELS - PROPER LUG TORQUE PROCEDURES - SERVICE TIP
98-26-2
FUEL - INFORMATION ON GASOLINE - TIPS TO RESOLVE VOLATILITY RELATED DRIVEABILITY CONCERNS
98-25-3
GLASS - FRONT WINDOW MAY TRAVEL BEYOND THE UPSTOP AND OUT OF THE GLASS RUN
98-24-6
ELECTRICAL - NEW TERMINAL GREASE RELEASED FOR SERVICE
98-23-10
MASS AIR FLOW (MAF) - SENSOR CONTAMINATION - SERVICE TIP
98-22-2
CLUTCH - VIBRATION/NOISE FELT IN CLUTCH PEDAL WHEN LIGHTLY TOUCHING CLUTCH PEDAL
98-20-10
EXHAUST SYSTEM - LOOSE CATALYST OR MUFFLER HEAT SHIELDS
NOISE - "BUZZING" OR "RATTLING" - LOOSE CATALYST OR MUFFLER HEAT SHIELDS
98-17-18
MOULDINGS - ROCKER PANEL - LOOSE
98-12-5
AIR CONDITIONING - FILTERING REFRIGERANT AFTER A/C COMPRESSOR REPLACEMENT - SERVICE TIPS
98-10-8
TRANSMISSION - AODE/4R70W - FORWARD CLUTCH - SERVICE TIP
98-9-9
FUEL INJECTORS - NON-WARRANTY REIMBURSEMENT TESTING INFORMATION
98-8-7
VIBRATION - SHUDDER OR VIBRATION UNDER LIGHT TO MODERATE ACCELERATION ABOVE 56 KM/H (35 MPH) WHILE IN 3RD OR 4TH GEAR - VEHICLES EQUIPPED WITH AODE OR 4R70W TRANSMISSION
TRANSMISSION - AODE - 4R70W - SHUDDER OR VIBRATION UNDER LIGHT TO MODERATE ACCELERATION ABOVE 56 KM/H (35 MPH) WHILE IN 3RD OR 4TH GEAR
98-7-4
LEAKS - OIL - AVAILABILITY OF NEW SILICONE GASKET AND SEALANT
98-5-2
TIRE - TIRE COMPANY TELEPHONE NUMBERS FOR CUSTOMER ASSISTANCE
97-25-5
BLOWER MOTOR - "CHIRPING" OR "SQUEAKING" FROM BLOWER MOTOR AT LOW SPEEDS
NOISE - "CHIRPING" OR "SQUEAKING" FROM BLOWER MOTOR AT LOW SPEEDS
97-24-13
REMOTE KEYLESS ENTRY (RKE) - DIAGNOSTIC SERVICE TIPS
97-24-1
LEAKS WATER - DURING HEAVY RAIN AND/OR WHEN GOING THROUGH CAR WASH - CONVERTIBLE TOP VEHICLES ONLY
97-22-1
DELTA PRESSURE FEEDBACK EGR (DPFE) - DIAGNOSTIC TIPS
97-19-13
TRANSMISSION - AODE - EXTENSION HOUSING BUSHING "WALKOUT"/SPIN - VEHICLES BUILT THROUGH 7/30/95
97-19-11
COOLING SYSTEM - "ON-VEHICLE" HEATER CORE PRESSURE TEST REQUIRED FOR WARRANTY CLAIM
97-19-4
BRAKES - BRAKE AND ROTOR SERVICE TIPS
97-17-2
REAR VIEW MIRROR - NEW PROCEDURE FOR PREFERRED REATTACHMENT METHOD
97-17-1
BODY - SHEET MOLDING COMPOSITE (SMC) - HOOD/FENDER/DECKLID/LIFTGATE - SMALL COSMETIC DAMAGE REPAIR SERVICE TIP
97-16-7
TRANSMISSION - AODE/4R70W - MAIN CONTROL AND CASE USAGE FOR PRIOR MODELS - SERVICE TIP
97-15-5
AIR CONDITIONING - OIL REFILL CAPACITY CHART - SERVICE TIP
97-11-11
TRANSMISSION - 4R70W - ERRATIC OR PROLONGED 1-2 SHIFT
TRANSMISSION - AODE - ERRATIC OR PROLONGED 1-2 SHIFT
97-10-5
AIR CONDITIONING - COMPRESSOR FAILURE - INSUFFICIENT AMOUNT OF REFRIGERANT OIL
AIR CONDITIONING - LACK OF COOLING - INSUFFICIENT AMOUNT OF REFRIGERANT OIL MAY CAUSE COMPRESSOR FAILURE
97-10-4
ENGINE COOLING FAN - MODULE COMPONENT SERVICE INFORMATION
97-9-8
POWERTRAIN CONTROL MODULE - REPROGRAM POWERTRAIN CONTROL MODULE (PCM) - SERVICE PROCEDURES - SERVICE TIP
96-26-12
TRANSAXLE - TORQUE CONVERTER REPLACEMENT GUIDELINES AND TORQUE CONVERTER/TRANSAXLE COOLING SYSTEM CLEANING PROCEDURES - SERVICE TIP
TRANSMISSION - TORQUE CONVERTER REPLACEMENT GUIDELINES AND TORQUE CONVERTER/TRANSMISSION COOLING SYSTEM CLEANING PROCEDURES - SERVICE TIP
96-26-8
BLOWER MOTOR - INTERMITTENT OR INOPERATIVE - TEMPERATURES AT OR BELOW 0 DEGREES C (32 DEGREES F)
96-25-17
96-24-9
TORQUE CONVERTER - LEAK TEST PROCEDURE - SERVICE TIP
96-24-6
WIRING - ELECTRICAL DIODE IDENTIFICATION AND SERVICE REPLACEMENTS
96-22-5
MASS AIR FLOW SENSOR - REPLACEMENT AS AN ASSEMBLY - SERVICE TIP
96-22-1
WINDSHIELD AND INTERIOR GLASS - FOG/FILM
96-20-8
AIR CONDITIONING - NEW O-RING APPLICATIONS - THICKER O-RINGS FOR SPRING LOCK FITTINGS - SERVICE TIP
AIR CONDITIONING - SPRING LOCK COUPLING CLEANING PROCEDURE - SERVICE TIP
96-20-7
AIR CONDITIONING - NEW O-RING AVAILABILITY AND APPLICATIONS - SERVICE TIP
96-15-9
ACCESSORY DRIVE BELT - BELT EDGE WEAR AND/OR MISTRACKING - MISALIGNED FRONT END ACCESSORY DRIVE (FEAD) BELT - VEHICLES BUILT THROUGH 7/95 WITH 5.0L HO ENGINE ONLY
96-15-6
AIR CONDITIONING - FILTERING REFRIGERANT - SYSTEM FLUSHING - TRACER DYE - LEAK TESTING - O-RING TOOL - TSB REPUBLICATION TO INCLUDE LATEST MODEL YEAR
96-14-9
FRONT END ACCESSORY DRIVE (FEAD) "SQUEAL/HOOT" - DURING COLD START-UP AFTER COLD SOAK BELOW -18 DEGREES C (0 DEGREES F)
NOISE - "SQUEAL/HOOT" FROM FRONT END ACCESSORY DRIVE (FEAD) AREA - DURING COLD START-UP AFTER COLD SOAK BELOW -18 DEGREES C (0 DEGREES F)
96-14-8
ENGINE - NOISE - "SQUEAL" NOISE COMING FROM FEAD DURING COLD START AT TEMPERATURES BELOW -7 DEGREES C (20 DEGREES F) - 4.6L VEHICLES
NOISE - "SQUEAL" DURING COLD START AT TEMPERATURES BELOW -7 DEGREES C (20 DEGREES F) - FEAD IDLER PULLEY AND/OR FEAD TENSIONER ASSEMBLY - 4.6L VEHICLES
96-12-9
NOISE - "CHATTER" DURING TIGHT TURNS OR TURNS AFTER AN EXTENDED PERIOD OF HIGHWAY DRIVING - TRACTION-LOK DIFFERENTIAL - 7.5 AND 8.8 INCH RING GEAR REAR AXLES
AXLE - NEW SERVICE KIT AVAILABLE FOR TRACTION-LOK DIFFERENTIAL - 7.5 AND 8.8 INCH RING GEAR
AXLE - TRACTION-LOK DIFFERENTIAL - 7.5 AND 8.8 INCH RING GEAR - "CHATTER" NOISE DURING TIGHT TURNS OR TURNS AFTER AN EXTENDED PERIOD OF HIGHWAY DRIVING
96-10-7
FUEL - CALIFORNIA REFORMULATED GASOLINE (CARFG) - SERVICE TIP
96-10-6
NEW GENERATION STAR (NGS) TESTER - INCORRECT INFORMATION DISPLAYED DURING DIAGNOSTIC MONITORING TEST RESULTS - VEHICLES WITH ON-BOARD DIAGNOSTICS (OBD) II
96-4-1
CONVERTIBLE TOP - SERVICE REPLACEMENT PARTS DIFFERENT FROM ORIGINAL - SERVICE TIP
96-1-1
STEERING - POWER RACK AND PINION - REVISED TORQUE REQUIREMENT FOR INSTALLING NEW DESIGN TIE RODS
95-24-3
ROCKER ARM - 3.8L ENGINE - LOW PITCHED "SQUEAK", "CHIRP" OR "KNOCK" NOISE
NOISE - 3.8L ENGINE - LOW PITCHED "SQUEAK", "CHIRP" OR "KNOCK" FROM ROCKER ARM
95-23-4
VIBRATION/SHUDDER - UNDER LIGHT ACCELERATION ABOVE 56 KM/H (35 MPH) IN 3RD OR 4TH GEAR
TRANSMISSION - AODE/4R70W - SHUDDER/VIBRATION UNDER LIGHT ACCELERATION ABOVE 56 KM/H (35 MPH) IN 3RD OR 4TH GEAR
95-22-8
AIR BAG WARNING LAMP - INCORRECT DIAGNOSIS OF AIR BAG CODE 24 - SERVICE TIP
95-21-1
SUPPLEMENTAL RESTRAINT SYSTEM - AIR BAG MODULES - DISCOLORED OR MARRED COVERS - PAINTING RESTRICTIONS
95-18-4
AIR CONDITIONING - FORD APPROVED FLUSHING PROCEDURES - SERVICE TIP
95-18-2
COOLANT - USE OF RECYCLED ENGINE COOLANT - SERVICE TIP
COOLING SYSTEM - USE OF RECYCLED ENGINE COOLANT - SERVICE TIP
95-17-3
INTERIOR TRIM - CONSOLE - INTERFERENCE BETWEEN PARKING BRAKE HANDLE AND CONSOLE GAP HIDER
95-16-10
FLUID - NEW ROTUNDA FLUID CHANGER - SERVICE TIP
95-14-4
BALL JOINT - REPLACEMENT PROCEDURE - SERVICE TIP
95-13-2
GAUGE - TEMPERATURE - READS IN LOW RANGE - ERRATIC READINGS
SERVICE PARTS - RETURN OF OBSOLETE TEMPERATURE SENDERS
95-13-1
AIR CONDITIONING - EVAPORATOR CORE - "ON-VEHICLE" LEAK TEST REQUIRED FOR WARRANTY CLAIM
AIR CONDITIONING - "ON-VEHICLE" EVAPORATOR CORE LEAK TEST REQUIRED FOR WARRANTY CLAIM
95-12-1
GLASS - WINDSHIELD - URETHANE MOUNTED GLASS MATERIAL USAGE PROCEDURE - SERVICE TIP
95-9-3
RADIO - "DISTORTION" - "POOR RECEPTION" - RELATED TO THE IGNITION SYSTEM - 5.0L ENGINE
NOISE - "WHINE, POP, DISTORTION OR POOR RECEPTION" IN THE RADIO - IGNITION SYSTEM RELATED - 5.0L ENGINE
95-8-4
LEAKS - AODE/4R70W - REUSABLE PAN GASKET AND FILTER
TRANSMISSION - AODE/4R70W - REUSABLE PAN GASKET AND FILTER - SERVICE TIP
95-6-8
ENGINE - 5.0L - REVISED OIL PAN GASKET REPLACEMENT PROCEDURE - SERVICE TIP
95-6-2
BRAKES - ROUGHNESS CONCERN DURING BRAKE APPLICATION
95-6-1
PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
PAINT - ROUGH TEXTURE/FERROUS METAL CONTAMINATION - ACID RAIN DISCOLORATION OR ETCHING
95-5-15
TRANSMISSION - AODE/4R70W - INTERMITTENT LOSS OF TORQUE DURING OR JUST AFTER 3-4 UPSHIFT - MAY BE INTERMITTENT
95-5-14
ENGINE - OIL - REVISED OIL FILL PROCEDURES FOR 5.0L/5.8L VEHICLES - SERVICE TIP
95-5-12
AIR CONDITIONING - ADDING REFRIGERANT OIL - SERVICE TIP
95-3-13
TRANSMISSION - AODE/4R70W - DIAGNOSTIC TROUBLE CODES - WATER INTRUSION OF THE MLP/TR SENSOR
TRANSMISSION - AODE/4R70W - POSSIBLE WATER INTRUSION INTO THE MLP/TR SENSOR CAUSING SHIFT CONCERNS AND/OR ENGAGEMENT CONCERNS
TRANSMISSION - AODE/4R70W - SHIFT CONCERNS AND/OR ENGAGEMENT CONCERNS DUE TO WATER INTRUSION OF THE MLP/TR SENSOR
95-3-10
ENGINE - 5.0L - NEW TORQUE-TO-YIELD CYLINDER HEAD BOLT KIT AND NEW PROCEDURES - SERVICE TIP
95-2-4
COOLING SYSTEM - RADIATOR - NEW MANUFACTURING PROCESS ("CUTS" IN UPPER AND LOWER SUPPORTS)
95-2-2
AIR CONDITIONING - O-RING REMOVAL FROM SPRING LOCK COUPLER - SERVICE TIP
95-1-2
ACCELERATOR CABLE - DIAGNOSTIC PROCEDURE
94-26-6
AIR CONDITIONING - RELEASE OF R-134A FLUORESCENT TRACER DYE - FOR 1992 TAURUS, R-134A VEHICLES ONLY - SERVICE TIP
94-26-5
LAMPS - HEADLAMPS - REMOVAL PROCEDURE - SERVICE TIP
94-26-4
THROTTLE POSITION SENSOR (TPS) - FUNCTION AND DIAGNOSTIC TIPS RECAP - TPS APPLICATION CHART
94-26-2
AIR BAG - DIAGNOSTIC TROUBLE CODE RETRIEVAL - PROGRAMMING CHANGE
94-25-2
BRAKES - AVAILABILITY OF ON-VEHICLE CALIPER-MOUNTED BRAKE ROTOR MACHINING EQUIPMENT AND WARRANTY COVERAGE INFORMATION
BRAKE ROTOR MACHINING - AVAILABILITY OF ON-VEHICLE CALIPER-MOUNTED BRAKE ROTOR MACHINING EQUIPMENT AND WARRANTY COVERAGE INFORMATION
94-23-9
AIR CONDITIONING - LITTLE OR NO COOLING - FS-10 COMPRESSORS - EXCESSIVE CLUTCH AIR GAP - ALL ENGINES EXCEPT 1.8L ESCORT/TRACER AND 3.0L, 3.2L SHO - VEHICLES BUILT THROUGH 9/19/94
94-23-5
BRAKES - FRONT DISC - "THUMPING/CLACKING" NOISE WHILE BRAKING
NOISE - "THUMPING/CLACKING" WHILE BRAKING - FRONT DISC BRAKES
94-22-6
AIR CONDITIONING/HEATING - TEMPERATURE CONTROL KNOB DOES NOT REACH FULL COOL POSITION
94-20-6
AIR CONDITIONING - OIL VISIBLE AT SPRING LOCK COUPLERS - SERVICE TIP
94-17-2
REAR VIEW MIRROR - DETACHES FROM WINDSHIELD - SERVICE TIP
