Chili January 20, 2009 Report January 20, 2009 TROUBLE CODESP0102- Mass Air Flow circuit Low Input.P0103- Mass Air Flow circuit High Input.P0106- EGR Barometric Pressure Sensor Input Signal is out of Self-Test Range.P0107- EGR/BARO Signal circuit is Less Than Self-Test minimum.P0108- EGR Barometric Pressure Sensor Input Signal is out of Self-Test Range.P0112- Intake Air Temperature circuit Low Input.P0121- In-Range Operating Throttle Position Sensor circuit failure.P0122- Throttle Position Sensor circuit Low Input.P0123- Throttle Position Sensor circuit High Input.P0125- Insufficient Coolant Temperature to enter Closed Loop.P0126- Insufficient Coolant Temperature for Stable Operation.P0113- Intake Air Temperature circuit High Input.P0117- Engine Coolant Temperature circuit Low Input.P0118- Engine Coolant Temperature circuit High Input.P0121- In-Range Operating Throttle Position Sensor circuit failure.P0122- Throttle Position Sensor circuit Low Input.P0123- Throttle Position Sensor circuit High Input.P0125- Insufficient Coolant Temperature to enter Closed Loop.P0126- Insufficient Coolant Temperature for Stable Operation.P0131- Upstream Heated Oxygen Sensor circuit out of range - Bank No. 1.P0132- Upstream Heated Oxygen Sensor circuit Voltage High - Bank No. 1.P0133- Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 1.P0135- Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.P0136- Downstream Heated Oxygen Sensor circuit fault - Bank No. 1.P0138- Downstream Heated Oxygen Sensor circuit Voltage High - Bank No. 1.P0140- Downstream Heated Oxygen Sensor circuit Faulty - Bank No. 1.P0141- Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.P0151- Upstream Heated Oxygen Sensor circuit out of range - Bank No. 2.P0152- Upstream Heated Oxygen Sensor circuit Voltage High - Bank No. 2.P0153- Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 2.P0155- Upstream Heated Oxygen Sensor circuit fault - Bank No. 2.P0156- Downstream Heated Oxygen Sensor circuit fault - Bank No. 2.P0158- Downstream Heated Oxygen Sensor circuit Voltage High - Bank No. 2.P0160- Downstream Heated Oxygen Sensor circuit fault - Bank No. 2.P0161- Downstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2.P0171- System Too Lean - Bank No. 1.P0172- System Too Rich - Bank No. 1.P0174- System Too Lean - Bank No. 2.P0175- System Too Rich - Bank No. 2.P0176- Flexible Fuel Sensor.P0180- Engine Fuel Temperature Sensor circuit - Electrical fault.P0181- Engine Fuel Temperature Sensor circuit - Electrical fault.P0182- Engine Fuel Temperature Sensor circuit - Electrical fault.P0183- Engine Fuel Temperature Sensor circuit - Electrical fault.P0187- Engine Fuel Temperature Sensor circuit.P0188- Engine Fuel Temperature Sensor circuit.P0190- FRP Sensor Signal Low.P0191- Engine Fuel Temperature Sensor circuit.P0192- Engine Fuel Temperature Sensor circuit .P0193- Engine Fuel Temperature Sensor circuit.P0222- Throttle Position Sensor B circuit Input Low.P0223- Throttle Position Sensor B circuit Input High.P0230- Fuel Pump Primary circuit fault.P0231- Fuel Pump Secondary circuit Low.P0232- Fuel Pump Secondary circuit High.P0300- Random Misfire Detected.P0301- Misfire Detected - Cylinders 1-10.P0302- Misfire Detected - Cylinders 1-10.P0303- Misfire Detected - Cylinders 1-10.P0304- Misfire Detected - Cylinders 1-10.P0305- Misfire Detected - Cylinders 1-10.P0306- Misfire Detected - Cylinders 1-10.P0307- Misfire Detected - Cylinders 1-10.P0308- Misfire Detected - Cylinders 1-10.P0309- Misfire Detected - Cylinders 1-10.P0310- Misfire Detected - Cylinders 1-10.P0320- Ignition Engine Speed (PIP) Input circuit fault.P0325- A Spark Knock Occurred - Sensor Circuitry did not respond.P0326- Spark Knock has not been sensed.P0330- A Spark Knock occurred - Sensor Circuitry did not respond.P0331- Spark Knock has not been sensed.P0340- Camshaft Position Sensor circuit fault.P0350- Ignition Coil Primary circuit fault.P0351- Ignition Coil A Primary circuit fault.P0352- Ignition Coil B Primary circuit fault.P0353- Ignition Coil C Primary circuit fault.P0354- Ignition Coil D Primary circuit fault.P0355- Ignition Coil Primary circuit malfunction.P0356- Ignition Coil Primary circuit malfunction.P0357- Ignition Coil Primary circuit malfunction.P0358- Ignition Coil Primary circuit malfunction.P0359- Integrated Ignition On Plug failure.P0360- Integrated Ignition On Plug failure.P0385- Misfire Detection Sensor circuit failure.P0400- EGR Flow Faulty.P0401- Insufficient EGR Flow.P0402- EGR Flow Excessive at Idle.P0411- Secondary Air Injection System Flow Improper.P0412- Secondary Air Injection System Control Valve Faulty.P0413- Secondary Air Injection Solenoid did not change when activated.P0414- Secondary Air Injection Solenoid did not change when activated.P0416- Secondary Air Injection Solenoid did not change when activated.P0417- Secondary Air Injection Solenoid did not change when activated.P0420- Catalyst System Efficiency below Limit - Bank No 1.P0421- Catalyst System Efficiency below Limit - Bank No 1.P0430- Catalyst System Efficiency below Limit - Bank No 2.P0431- Catalyst System Efficiency below Limit - Bank No 2.P0440- Evaporative Emission Purge Control Solenoid Damaged.P0442- Leak in Evaporative System Detected.P0443- EVAP Canister Purge Control Solenoid or Valve Faulty.P0446- Evaporative Emission Control System Vent Control malfunction.P0452- Fuel Tank Pressure Signal circuit Input below minimum.P0453- Fuel Tank Pressure Signal circuit Input above maximum.P0455- Leak or Blockage Detected in Evaporative Emission Control System.P0460- Fuel Level Input circuit malfunction.P0500- Vehicle Speed Sensor fault.P0501- Vehicle Speed Sensor fault.P0503- Poor Vehicle Speed Sensor Performance.P0505- Idle Air Control Valve System fault.P0552- Power Steering Pressure Sensor Shorted to Power.P0553- Power Steering Pressure Sensor Shorted to Power.P0602- Replace PCM.P0603- PCM has Experienced Power Interrupt.P0605- PCM Read Only Memory Error.P0703- Brake On/Off Switch Input fault.P0704- Clutch Pedal Position Switch Input circuit fault.P0705- Transmission Range Sensor out of Self-Test Range or Shorted to Ground.P0707- Transmission Range Sensor circuit Low Input.P0708- Transmission Range Sensor circuit High Input.P0712- Transmission Fluid Temperature Sensor circuit Input Low.P0713- Transmission Fluid Temperature Sensor circuit Input High.P0715- Turbine Shaft Speed Sensor circuit fault.P0720- Output Shaft Speed Sensor circuit.P0721- Output Shaft Speed Sensor circuit.P0731- Improper Ratio for First Gear.P0732- Improper Ratio for Second Gear.P0733- Improper Ratio for Third Gear.P0734- Improper Ratio for Fourth Gear.P0735- Transmission problems.P0736- Improper Ratio for Reverse Gear.P0741- TCC System Improper Mechanical Performance.P0743- Torque Converter Clutch System Electrical failure.P0746- Electronic Pressure Control Solenoid Performance.P0750- Shift Solenoid No. 1 circuit.P0751- Shift Solenoid No. 1 Performance.P0755- Shift Solenoid No. 2 circuit.P0756- Shift Solenoid No. 2 Performance.P0760- Shift Solenoid No. 3 circuit.P0761- Shift Solenoid No. 3 Performance.70765- Transmission system problems.P0781- 1 to 2 Shift Error.P0782- 2 to 3 Shift Error.P0783- 3 to 4 Shift Error.P0784- 4 to 5 Shift Error.P1000- OBD-II Monitor Testing Incomplete.P1001- KOER Test Cannot Be Completed.P1039- Vehicle Speed Signal Missing or Improper.P1051- Brake Switch Signal Missing or Improper.P1100- Mass Air Flow Sensor Intermittent.P1101- Mass Air Flow Sensor out of Self-Test Range.P1112- Intake Air Temperature Sensor Intermittent.P1116- Engine Coolant Temperature Sensor is out of Self-Test Range.P1117- Engine Coolant Temperature Sensor Intermittent.P1120- Throttle Position Sensor out of range.P1121- Throttle Position Sensor Inconsistent with Mass Air Flow Sensor.P1124- Throttle Position Sensor out of Self-Test Range.P1125- Throttle Position Sensor Intermittent.P1127- Heated Oxygen Sensor Heater not on During KOER Test.P1128- Heated Oxygen Sensor Signals reversed.P1129- Heated Oxygen Sensor Signals reversed.P1130- Lack of Upstream Heated Oxygen Sensor/Adaptive Fuel Limit/Bank 1.P1131- Lack of Upstream Heated Oxygen Sensor/Sensor Indicates Lean/Bank 1.P1132- Lack of Upstream Heated Oxygen Sensor/Sensor Indicates Rich/Bank 1.P1135- Ignition Switch Signal Missing or Improper.P1137- Lack of Downstream Heated Oxygen Sensor/Sensor Indicates Lean/Bank 1.P1138- Lack of Downstream Heated Oxygen Sensor/Sensor Indicates Rich/Bank 1.P1150- Lack of Upstream Heated Oxygen Sensor/Adaptive Fuel Limit/Bank 2.P1151- Lack of Upstream Heated Oxygen Sensor/Sensor Indicates Lean/Bank 2.P1152- Lack of Upstream Heated Oxygen Sensor/Sensor Indicates Rich/Bank 2.P1157- Lack of Downstream Heated Oxygen Sensor/Sensor Indicates Lean/Bank 2.P1158- Lack of Downstream Heated Oxygen Sensor/Sensor Indicates Rich/Bank 2.P1220- Series Throttle Control fault.P1224- Throttle Position Sensor B out of Self-Test Range.P1230- Open Power to Fuel Pump circuit.P1231- High Speed Fuel Pump Relay activated.P1232- Low Speed Fuel Pump Primary circuit failure.P1233- Fuel Pump Driver Module off-line.P1234- Fuel Pump Driver Module off-line.P1235- Fuel Pump Control out of range.P1236- Fuel Pump Control out of range.P1237- Fuel Pump Secondary circuit fault.P1238- Fuel Pump Secondary circuit fault.P1250- Lack of Power to FPRC Solenoid.P1260- Theft Detected - Engine Disabled.P1270- Engine RPM or Vehicle Speed Limiter Reached.P1288- Cylinder Head Temperature Sensor out of Self-Test Range.P1289- Cylinder Head Temperature Sensor Signal Greater Than Self-Test Range.P1290- Cylinder Head Temperature Sensor Signal Less Than Self-Test Range.P1299- Cylinder Head Temperature Sensor Detected Engine Overheating Condition.P1309- Misfire Detection Monitor not enabled.P1351- Ignition Diagnostic Monitor circuit Input fault.P1352- Ignition Coil A - Primary circuit fault.P1353- Ignition Coil B - Primary circuit fault.P1354- Ignition Coil C - Primary circuit fault.P1355- Ignition Coil D - Primary circuit fault.P1356- Loss of Ignition Diagnostic Module Input to PCM.P1358- Ignition Diagnostic Monitor Signal out of Self-Test Range.P1359- Spark Output circuit fault.P1364- Ignition Coil Primary circuit fault.P1380- VCT Solenoid Valve circuit Short or Open.P1381- Cam Timing Advance is excessive.P1383- Cam Timing Advance is excessive.P1390- Octane Adjust out of Self-Test Range.P1400- Differential Pressure Feedback Electronic Sensor circuit Low Voltage.P1401- Differential Pressure Feedback Electronic Sensor circuit High Voltage.P1403- Differential Pressure Feedback Electronic Sensor Hoses Reversed.P1405- Differential Pressure Feedback Electronic Sensor circuit Upstream Hose.P1406- Differential Pressure Feedback Electronic Sensor circuit Downstream Hose.P1407- EGR No Flow Detected.P1408- EGR Flow out of Self-Test Range.P1409- EGR Vacuum Regulator circuit malfunction.P1410- EGR Barometric Pressure Sensor VREF Voltage.P1409- Electronic Vacuum Regulator Control circuit fault.P1411- Secondary Air is not being diverted.P1413- Secondary Air Injection System Monitor circuit Low Voltage.P1414- Secondary Air Injection System Monitor circuit High Voltage.P1442- Secondary Air Injection System Monitor circuit High Voltage.P1443- Evaporative Emission Control System/Vacuum System/Purge Control Solenoid or Purge Control Valve fault.P1444- Purge Flow Sensor circuit Input Low.P1445- Purge Flow Sensor circuit Input High.P1450- Inability of Evaporative Emission Control System to Bleed Fuel Tank.P1451- Lack of Response From Passive Anti-Theft System Module - Engine Disabled.P1452- Inability of Evaporative Emission Control System to Bleed Fuel Tank.P1455- Substantial Leak or Blockage in Evaporative Emission Control System.P1460- Wide Open Throttle Air Conditioning Cutoff circuit malfunction.P1461- Air Conditioning Pressure Sensor circuit Low Input.P1462- Air Conditioning Pressure Sensor circuit high Input.P1463- Air Conditioning Pressure Sensor Insufficient Pressure change.P1464- ACCS to PCM High During Self-Test.P1469- Low Air Conditioning Cycling Period.P1473- Fan Secondary High with Fans Off.P1474- Low Fan Control Primary circuit.P1479- High Fan Control Primary circuit.P1480- Fan Secondary Low with Low Fans On.P1481- Fan Secondary Low with High Fans On.P1483- Power to Cooling Fan Exceeded Normal Draw.P1484- Variable Load Control Module Pin 1 Open.P1500- Vehicle Speed Sensor Intermittent.P1501- Programmable Speedometer & Odometer Module/Vehicle Speed Sensor Intermittent circuit-failure.P1502- Invalid or Missing Vehicle Speed Message or Brake Data.P1504- Intake Air Control circuit malfunction.P1505- Idle Air Control System at Adaptive Clip.P1506- Idle Air Control Over Speed Error.P1507- Idle Air Control Under Speed Error.P1512- Intake Manifold Runner Control Stuck Closed.P1513- Intake Manifold Runner Control Stuck Closed.P1516- Intake Manifold Runner Control Input Error.P1517- Intake Manifold Runner Control Input Error.P1518- Intake Manifold Runner Control fault - Stuck Open.P1519- Intake Manifold Runner Control Stuck Open.P1520- Intake Manifold Runner Control circuit fault.P1519- Intake Manifold Runner Control fault - Stuck Closed.P1520- Intake Manifold Runner Control fault.P1530- Open or Short to A/C Compressor Clutch circuit.P1537- Intake Manifold Runner Control Stuck Open.P1538- Intake Manifold Runner Control Stuck Open.P1539- Power to A/C Compressor Clutch circuit Exceeded Normal Current Draw.P1549- Intake Manifold Temperature Valve Vacuum Actuator Connection.P1550- Power Steering Pressure Sensor out of Self-Test Range.P1605- PCM Keep Alive Memory Test Error.P1625- Voltage to Vehicle Load Control Module Fan circuit not detected.P1626- Voltage to Vehicle Load Control Module circuit not detected.P1650- Power Steering Pressure Switch out of Self-Test Range.P1651- Power Steering Pressure Switch Input fault.P1700- Transmission system problems.P1701- Reverse Engagement Error.P1702- Transmission system problems.P1703- Brake On/Off Switch out of Self-Test Range.P1704- Transmission system problems.P1705- Manual Lever Position Sensor out of Self-Test Range.P1709- Park or Neutral Position Switch out of Self-Test Range.P1710- Transmission system problems.P1711- Transmission Fluid Temperature Sensor out of Self-Test Range.P1713- Thru P1728 Transmission system problems.P1729- 4x4 Low Switch Error.P1740- Transmission system problems.P1741- Torque Converter Clutch Control Error.P1742- Torque Converter Clutch Solenoid Faulty.P1743- Torque Converter Clutch Solenoid Faulty.P1744- Torque Converter Clutch System Stuck in Off Position.P1745- Transmission system problems.P1746- Electronic Pressure Control Solenoid - Open circuit.P1747- Electronic Pressure Control Solenoid - Short circuit.P1749- Electronic Pressure Control Solenoid Failed Low.P1751- Shift Solenoid No. 1 Performance.P1754- Coast Clutch Solenoid circuit malfunction.P1756- Shift Solenoid No. 2 Performance.P1760- Transmission system problems.P1761- Shift Solenoid No. 3 Performance.P1762- Transmission system problems.P1767- Transmission system problems.P1780- Transmission Control Switch circuit is out of Self-Test Range.P1781- 4x4 Low Switch is out of Self-Test Range.P1783- Transmission Over-Temperature Condition.P1784- Transmission system problems.P1785- Transmission system problems.P1786- Transmission system problems.P1787- Transmission system problems.P1788- Transmission system problems.P1789- Transmission system problems.P1900- Transmission system problems. Citera
