Royen
Allt skrivet av Royen
  1. Jag vill dock varken ha huvlås eller någon annan huv. Så problemet kvarstår
  2. Huvpinnar är ingen lösning, det är ju liksom försent när dom kommer till användning. Vad jag fått fram så hjälper inte huv byte särskilt mycket, du kommer behöva en jävligt tung huv för att det ska fungera. Kopierar ett inlägg från ett amerikanskt forum. Den här killen verkar veta vad han pratar om. Hood pins are not a total fix. It just raises the speed at which the hood starts moving. Watch this video all the way through. It has hood pins and at the end of the run (the slow mo part) the hood has lifted about an inch or more there is so much air under there. That’s scary! And imagine how that is hurting the top speed. Check the hood out in this link: RoadandTrack.com -- Feature - Thunder Road: The Standing Mile (9/2005) I have talked to about a million people about airflow management on the S197 because I plan on going 200mph this spring. I have talked to everyone from FR500 owners to the guy who runs the Miller Mustang Cup series and I climbed all over and under the S197 that went 250mph at Boniville that was on the cover of Hot Rod last month. Bottom line is that there is way too much air getting into the engine bay and not getting out. There are about a million solutions for this. And some stuff you think would work doesn’t. Here are the things that I have done/am doing right now to keep as much air as possible out of the engine compartment (which will increase top speed dramatically too). Front end splitter. Doesn’t need to be a big race style one, even the one from Legend X or a GT500 knock off will do. The reason you want this is to get some air moving under the car. In a perfect world you would have no air under the car but we have to drive these on the street so you deal with the perameters you are working with. Put a belly pan that goes from the splitter all the way back to the rear edge of the K member. This will crate a vacuume at the rear of the engine compartment as the air under the car draws the engine compartment air out. This is the hard one. The air going in the grille needs a lot of help. First off the plastic “splitter/radiator cover is useless. A ton of air gets between it and the underside of the hood. I am currently fitting up a thin aluminum one that will seal the entire front end of the hood up so no air gets in. It will be finished off with a rubber gasket. Next is too make blocking plates so the air going through the grille either goes through the radiator or doesn’t get past the grille. You want to do the same thing for the opening under the bumper too. Basically you want to make two (I’m using aluminum) “boxes” that go from the openings to what they are cooling and sealed against it with some rubber gasket. The boxes want to “open up” in angle from the entrance to the exit at a 8 deg angle. This will create pressure in front of the Rad, A/C compressor, heat exchanger, etc. This is a lot of work. I am setting mine up so all of the ducting is attached to the bumper cover and comes off with it when removed. This will keep a massive amount of air from getting under the hood and will increase cooling. Another solution is a heat extractor type hood, but I have only found one nice one and it weighs as much as the OEM hood and would be well over a grand by the time it’s painted. It also won’t evacuate as much air as you need to. On top of that I like the sleeper look. It certainly won’t hurt, but the dollar/benefit ratio sucks. Lastly, and none of you will probably do this is to build a diffuser for the rear of the car. A good diffuser design will help to manage the air under the car and pull even more air out of the engine compartment. It also has the benefit of joining the air that goes over the top of the car and the bottom at the rear of the car which will improve the aerodynamics for the entire car and increase top speed. I’m in the process of making one out of carbon fiber right now. With the radiator cover made out of aluminum and tightly sealed to the hood in addition to a front splitter will reduce a ton of the hood movement problem. Blocking airflow at the grille and channeling it either up or under the car or through the cooling components will just about get rid of all of it. Like I said above I’m going to look at mass production o the aluminum radiator cover when I have my prototype done. If I can get them made cheap enough I will probably produce them. I could even do a limited pr-order for a batch of carbon ones. The block off plates and channels to go between the bumper and the cooling devices will be hard to produce though. There will be a ton of differing shapes needed depending on what Rad you are running, if you are FI and have a heat exchanger etc. I won’t have all of this done till the end of Feb but when I am I will post pics and my new top speed.
  3. Tänkte höra med er om ni har löst den hoppande huven på något sätt? Jag vet att den inte lossnar men det ser förbannat tråkigt ut med allt det där studsandet. Antar att det beror på luft som kommer in under huven när man ökar farten lite. Funderade på att sätta super magneter längs med huven för att se om dom kan hålla den på plats. Kanske blir för jobbigt att öppna huven sen dock. Kanske få dit några lister som hindrar luften från att ta sig in? Tips och tricks would I like yes. Läste runt lite nu och jag skippar magneterna, det är luften som måste ledas bort. Verkar vara ett djävulskt projekt så det får nog vara :/
  4. Tack för era tips o synpunkter. Att det är skit med tonade lampor har jag förstått. Men det är inte mitt bekymmer. Han får skylla sig själv. Ska undvika swedenautolights. Tack för heads up.
  5. Det ändrades vid nåt tillfälle. Original på 05 är 3.55 sedan ändrades det någon gång.
  6. Låter ju bra det där, bara o sätta in angeleyes där fram så löser det sig med parkeringen alltså, och sedan dom svarta bak och splitta kabel för blinkers. Kanon kanon, tack för infon
  7. Tjena allihop, min granne har precis köpt en 01a GT som han skulle vilja utrusta med svarta lampor runt om, dom bakre lamporna måste bytas helt, finns inget kvar av dom kan man säga. Samtidigt så måste det göras en konvertering av lamporna så att det passar här på våra svenska besiktningar. Omkopplingen för baklyktorna såg jag fanns i tråden här under så det behöver jag inte fler tips om skulle jag tro, men vad är det som behöver göras där fram? Förutom blinkers på sidorna alltså. Var har ni köpt era mörka lampor? Är det DOT märkning man ska kolla efter för att få rätt sort inför besiktningen? Något annat jag borde tänka på innan man beställer grejerna och börjar montera? Han vill helst köpa från svensk butik för att slippa med paypal osv. Tack så mycket på förhand. //R på följande sida http://www.swedenautolights.se så finns det både mörka angeleyes och mörka baklampor, är dessa godkända att använda och behöver man göra något mer med dom för att gå igenom besiktning? Parkeringsljus osv? Artnr:117666 sök på detta för angeleyes och Artnr: mustang9904baksm och detta för baklamporna.
  8. Jag skulle nog tipsa om dom andra armarna. Heter något med "lower control arms" finns många olika märken av dom men steeda är ett bra val vad jag har hört. Glöm inte att få rätt vinkel på allt också. Kanske behöver köpa justerbara fästen för at få till det? Inte säker så kolla med försäljaren. Brenspeed.com har allt du behöver och dom är väldigt duktiga / hjälpsamma. Du kan också försöka få lite mer tyngd där bak, flytta batteriet, större hjul eller kanske ett par påsar med sand kanske? Lycka till
  9. När 2011 kommer är INTE priset 200-300tkr... Beror nog på hur länge han kan vänta med att köpa en serru. Men i vilket fall så kommer priserna sjunka på dom vanliga bilarna när som nya kommer. Därför tycker jag också att vänta är en bra ide
  10. Vänta tills nya mustangen kommer, mer HK, mycket snyggare inredning på dom nya som redan har kommit, dock tråkigare yttre. Men inte för den delen fula. Köp själv från USA. Lycka till
  11. Kabeln du behöver mellan diablon o datorn kan du köpa var som helst. Ta med diablon till butiken o visa uttaget så hjälper dom dig
  12. Tjena. Är det någon som har koll på vem man ska vända sig om man vill byta utväxling? Ska gå från 3.55 till 4.10. Hade velat göra det själv men jag har för lite erfarenhet för att våga på det hela själv. Så nära Falkenberg som möjligt är ett plus. Tack på förhand
  13. Se till att få kontakt med den riktiga ägaren helt enkelt. Det är enda sättet att få det korrekt fullmakten är bara giltig om den går att få bekräftat av ägaren o dom vittnena som ska Ha bevittna underskriften. Det finns många bilar att köpa och du borde kolla på att importera bil själv. Billigare och enormt utbud.
  14. Det är knappast någon bra ide att ge personen några pengar i förväg i alla fall be honom att ta med den person som faktiskt är ägare till bilen vid köp tillfället o att den personen hat giltig leg med sig. Den personen måste ju ändå skriva på Pappret. Om du skulle köpa bilen o det sen visar sig att den riktiga ägaren inte alls ville sälja bilen så kommer personen antagligen få tbax bilen o du kommer få försöka anmäla o krävs pegarna tbax av han som sålde den. O den personen lär fförsvinna förbannat fort ur synhåll när han fått pengarna i näven. Ursäkta kluddandet. Skriver från telefonen
  15. Beror inte klonkandet på att drivlinan är två delad? Men det kanske inte är det klonkandet du menar men om det är så köp ett nytt som är i en del samt aluminium.
  16. Royen replied to mike85's topic in Mustang 2005-2014
    Det är oftast invandrare som kör BMW överallt verkar det som, men det är ganska politiskt inkorrekt att nämna det så som du gjorde. Dock skiter jag faktiskt i vilket, jag bara leker troll. Så back to the topic och ursäkta för sne spåret.
  17. Royen replied to mike85's topic in Mustang 2005-2014
    Bra svar Fredrik Jag har inte sagt att det inte har nån relevans för mig. Jag frågade honom vad det har för relevans enligt honom. Tycker det låter lite fördomsfullt det han skrev men har jag uppfattat fel så ber jag givetvis om ursäkt. Tycker du det var något som hade förstört hela historien om det inte hade nämnts?
  18. Royen replied to mike85's topic in Mustang 2005-2014
    Vad hade det för relevans att nämna att gubben var invandrare?
  19. Plasten har faktiskt inte knäckts har jag sett nu, dock är den givetvis väldigt intryckt, och clipsen som sitter där håller in den rätt fint. Jag tror att plasten är förstörd, och i vilket fall så lär lacken vara det, så klarlacken kommer nog börja släppa snart. Var med när dom lyfte den och stog bara några meter bort men jag hörde ingenting, känner mig själv lite dum eftersom jag gick in under bilen och passade på att kolla hur underredet såg ut. Borde liksom själv ha sett det då.... Men men, självrisken ligger på fem tusen så det ska jag få dom till att betala hade jag tänkt, verkar vara lite sisådär med att dom skulle vilja göra det dock. Får se vad dom säger när jag åker förbi där nästa gång. Ska in till en Ford verkstad och få besiktning på skadorna från en oberoende part. Hoppas bara karossen under inte fått några skador för då börjar det bli riktigt tråkigt >_<
  20. Tack för hjälpen, är det någon som vet hur dessa ser ut på insidan? funderar på om dom har förstärkningar på plasten, alltså typ tvärgående plastbitar som förstärkningar, isof lär dessa blivit krossade helt. Gubbarna på däckfirman tycker inte att det är några skador att tala om eftersom att plasten borde komma ut igen när man lossar på dom clips som tryckts in. Det tycker jag inte alls att det verkar som att den kommer göra och ska därför ta in bilen på en Ford verkstad och låta dom kolla vad det blivit för skador och sedan gå genom försäkringsbolaget. Tråkigt med sånt här >_<
  21. Tjena behöver lite hjälp med att hitta namnet på plast listen som sitter nedanför dörrarna på våra bilar. Alltså typ kjolarna på sidorna. Var inne o byte däck igår och idag på besiktningen såg jag att dom hade lyft undertill på dessa plastbitarna så att dom knäckts på fyra ställen. Så nu hade jag behövt namnet på dessa så jag kan kolla vad nya kostar osv osv. Någon som kan hjälpa till med det? Tack på förhand. Puss hej
  22. Är det manuell eller automat på bilen? Verkar väl lite klent i hk om det är en manuell? Ni har inga siffror på andra mustanger som kört på samma mätutrustning?
  23. Jag kopplar från batteriet, pumpar däcken och låter bli bilen över vinter. Ett kilo förbränd bensin ger drygt 1.5 kilo vatten. Du får fan ha bilen igång länge om du ska lyckas värma upp bilen såpass att detta försvinner och inte bidrar till rostande avgasrör. I med olja innan vinterförvaring och sedan lite startgas innan du kör igång för våren. Så är min melodi, säkert någon som har något att sätta emot
  24. Programmeringen var gratis när jag köpte, eller i alla fall så nämdes det inte som en extra kostnad. Och jag är ganska säker på att jag inte gav mer än 4000 inkl allt. Detta var då inte SVT cobra klustret utan för My Colour upgrade klustret. Hade det vanliga innan. Men SVT borde väl inte vara särskilt mycket dyrare?
  25. Om ni testar att beskriva vad felet/felen är så är det nog mer troligt att ni får den hjälp ni behöver.
