zolife
Allt skrivet av zolife
  1. Sidan support sa att det passar inte för EU modellen. Kanske dom var bara osäker :)
  2. zolife replied to RaceRed's topic in Mustang 2015+
    well, I'm wondering how serious is this legal issue... will the police stop me or just get a notification when the car get the first official inspection? :) I guess there are ways to modify the light intensity if it is too strong and with combine with the original DRL light in the foglights they can not say anything about it... I hope at least. I really miss this features from the EU mustang and seriously thinking to get this package, but haven't found any information about the installation yet. I can put the lamps in but I'm afraid from the wiring unless if they have a good instruction for it.
  3. Hej, Den ser verkligen fin ut. Jag funderar också på att byta den till GT 350R ratt, men sidans support sa att det inte är kompatibel med EU modellen. http://www.americanmuscle.com/ford-performance-gt350r-steering-wheel-kit-1516.html Har du haft problem med att installera den? Så vitt jag vet är 350 och 350R samma. Var beställde du din?
  4. hej, varifrån order ni avgassystemet för den nya mustangen? Fins det not bra ställe i sverige eller från USA? dom har verkligen bred sortiment but jag vet inte vad ska det kosta efter tull och frakt. Jag antar the installation är inte komplicerat om man har en verkstad, so behöver ingen expert för det.
  5. wow.. nice site! Thanks. I could also find my car (as mustang ;)) first time after the reg number. They have a nice collection for the 20'' wheel as well... but after checking the price different between the 275 and 295 probably smarter to keep the original 275 because the price almost double in between :P it will do.. and more burnout, drifting ;)
  6. #Nugatti: Thanks for the info... it looks those deal af already off unfortunately. But I've looked around a bit and it cost around 24k sek to buy a whole new set of decent wheel + tire with sensors in the local tire shops. Actually it is quite hard to find a proper rim for the mustang because its system, especially 19 inch size ( in sweden at least). So I've decided to change only the tire on my 19' GT wheels and go for a new summer set that should be 20'' instead. Looks much cooler I think :) Also thinking to have a wider tire for the back like 295 instead of the original 275... I don't know it is a good idea or not, but feels like the GT can easily handle it. Does anyone imported tires from the US? seems like they have better deals especially for the mustang even if we add the extra cost.
  7. #Nugatti: How did you solve the shipping to sweden with that german shop? I've just ask them and they said no shipping to sweden ?!?! What is the magic word I have to say? :)
  8. nice! :) Where did you get those? was it hard to install? it would be even better if we can make those tri-bar LEDs working in the headlight just like the US version have.
  9. zolife replied to RaceRed's topic in Mustang 2015+
    Hi, this issue is also buzzing me. Why those led lamps are not working on the EU version?! I've found and article which says this: "Don't meet EU regulations, sadly. So they had to be nixed. Something about aspect angle and height which was outside tolerances, nothing Ford could do, it's a mandate from the EU that they must be permanently switched off." But if you import the car form the US it is fine i guess... so hopefully there is some solution. I've asked the service and they said the lamps are in the headlight module but it is disabled by the software. I'm not sure about it because I didn't get a straight answer, they said they have to look after it first. So I'm not sure if you order a new headlamp from the US it will solve this problem. There is a polish company who modding the light system but they're way much more expensive that the US version and I'm not sure those modifications are legal in the EU. http://hd-customs.pl/american-muscle/am-lights/am-lights-mustang-2015/ It would be really good to have someones experience about this theme, what is the best way to go.
  10. #FastMagnus: Do you have any suggestion? :) I would be really happy to pimp up the light system in some way to make it closer to the US version, or above :D It is also quite frustrating that the tri-bar LED lamp in the front light is not used DTRLs like the US version have. I have read it was permanently disabled in the EU version by some regulation, despite it is one of the most recognizable part of the new mustang. https://www.carthrottle.com/post/5-subtle-design-differences-between-us-and-euspec-ford-mustangs/ If you import the car than it is okay I guess but if you buy it in the EU you don't have it. It is supposed to be just a software update but they couldn't say if for sure in the service. Does anyone have experience how to turn on these led lines in the front lamp??
  11. I had the same oppinion about the standard lights as Magnus, can use a bit upgrade to make the whole car cooler. Did order this switchback turn signal lamps from USA but when I wanted to istall them I had to realise the EU mustang light system is absolutly differnt from the US modell. It not just works diferently but even the lamp setup in the car is diferent. I couldn't follow the US tutorials for the install and couldn't find any EU variation for it. Personally I think the US version of the light system looks better, for which lamp lit up and when... it is sad I couldn't find information about this before I made my order. It would be nice to tweak it if there is a way to do it. I also have ordered a sequential tail light from the same place, but I had a same luck with it. The conenctor is diffenrt on the US model than the EU. So these stuff are working only the US models unfortunately.
