hej håller på med att stripa/lackera min -70 sportroof har en sats med boss stripes vad jag kan se verkar dom vara blanka i mitt huvud borde dom vara halvmatt men det kanske finns flera varianter men min fråga mittfält huv koffert ock bakstam borde väl vara i halvmatt eller?
http://www.boss302.com/hood.htm
http://www.boss302.com/faqs.htm
Q: Does anyone have the correct paint code and manufacturer name for the black paint on the trunk and hood stripe on a 1970 BOSS 302. A1: The correct finish for 1970 BOSS 302 hood black is the textured low-gloss black, PPG/Ditzler code DDL-9381 Hi-Performance black. This paint is available in factory pack only. You can have your paint store order the DDL-9381 in factory pack quarts. The rear deck spoiler and taillight are also textured low-gloss black DDL-9381. The tail lamp bezel, however, is low-gloss black without the texture. You can use PPG/Ditzler DDL-9423 low-gloss black by paint gun or Krylon semi-flat black 1613 for correct color and finish. A2: The only company that recently made the paint was PPG/Ditzler, code DDL-9381. However, this paint has been discontinued for a few years (I tried to get this paint approximately 1 1/2 years ago for my car. The rep. from PPG told me it was no longer available). Also, the rear spoiler and louvers (if equipped) as well as the molding around the back glass and the taillight panel should be a textured low gloss black (i.e. DDL-9381). The tail lamp bezel and shaker hood scoop trim ring should be a low gloss black without texture. Your paint shop should be able to use a painter's trick called "dry shoot" when they paint to replicate the texture paint.
Massor av tips her; http://www.boss302.com/menu.htm
Mvh
JohnB
Hej. Vilken underbar sida, den har faktiskt jag missat:confused::confused::confused:, och det är f-n inte likt mig, tur att JohnB finns.
Har DU missat nåt i Mustang værden? Tror jag inte ;-)
Mvh
JohnB
