August 22, 201411 yr comment_139259 GT Equipment GroupC-6 Select Shift Cruise-O-MaticLocking DifferentialConvenience Control PanelVisibility GroupLouvered HoodConsolePower Disc BrakesPower SteeringAM RadioInterior Decor GroupFront Seat HeadrestsTachometer and Trip OdometerAccessory PackagingTouch-Up PaintUndrar vad Accessory packaging är för något
August 22, 201411 yr comment_139274 "This option was specifically for export models. It included items that would be hard to find overseas like replacement light bulbs and fuses. This falls in-line with the listings in our registry as well as only export DSO's have this option listed." Källa: Boss registry
August 23, 201411 yr comment_139275 Själv har jag en 1968 Mustang Spint Packaging BLite info om detta!http://www.allclassicmustang.com/1968MustangParts.htmlPs hur går det med bilen då! får du den som du vill?
August 25, 201411 yr Author comment_139311 Japp Snorre ! Börjat pilla lite, satt på shelby 68 huvpinnar och sido scoopbytte diffen till en Detroit locker samma utväxling nu väntar jag på baklucka och baklamporTack för info Ivar
