June 26, 20169 yr comment_151714 Tröttnade på de gula DRL lamporna och köpte ledlampor med 4 dioder i. Resultatet? Över förväntan, liknar drl i nyare V70, ser mycket modernare ut. Ändrade %s av %s (%s)
September 9, 20169 yr comment_152873 nice! :) Where did you get those? was it hard to install? it would be even better if we can make those tri-bar LEDs working in the headlight just like the US version have.
September 10, 20169 yr Author comment_152888 19 timmar sedan, zolife said: nice! :) Where did you get those? was it hard to install? it would be even better if we can make those tri-bar LEDs working in the headlight just like the US version have. They are homemade. 70 mm led and homemade cables and brackets, just plug and play, do you want a set?
