comment_153413
Enkel google sökning.
Mycket snack i amerikanska forum om detta, men det är korrekt.
http://themustangsource.com/forums/f806/lug-nut-torque-2015-a-534238/
The lug nut torque on the 2015 Mustang is higher than the prior Mustangs because the size of the wheel lug bolts increased from 12 inch (12.7 mm) to 14 mm. in diameter.
The correct torque for the 14 mm wheel nuts is 150 lb.ft (204 Nm). I hope this helps. Have a great day!
