saktown December 20, 2016 Report December 20, 2016 Hello MustangPeeps Hope it's all right that i write in English! I've just purchased a 08 Bullitt from Germany and I hate, that there is no light in the middle tail lights like the Swedish Cars. It currently does like this:https://youtu.be/NHBBv_gR_FgOuter: Positionsljus + Brake Middle: Blinker (LED bulb) Inner: Positionsljus + Fog light (only for left side of the car)I attached 2 pictures in the mails of the rear wires. If you need me to take more, let me know. I have also checked the SJB, and I can see, that there has been some work done there. If you want pictures from the SJB as well, let me know. My wish is to have 3 positionsljus and blinkers in the reverse light. I have seen the "konverteringsguide" that is uploaded here on the site and I understand it fully. Shall I just follow that guide? Or is my car different because it comes from Germany? Guess im just afraid to mess something up! I have also mailed Grufman, but would like to have feedback from others as well. Thanks a lot! Citera
saktown December 20, 2016 Author Report December 20, 2016 38 minutes ago, saktown said: My wish is to have 3 positionsljus and blinkers in the reverse light. And keep my rear fog light of course. Hope you guys can chime in :) Citera
MOS January 3, 2017 Report January 3, 2017 Hi! According to my "Konverteringsguide" ( I wrote it) you should be able to figure out how your car is modified. Compare your kable-drawing with the guide after converting of SJB. Hope it will help you. /MOS Citera
MOS January 3, 2017 Report January 3, 2017 The main thing when you convert from original to European standard is to separate brake light and position light. This seams to be done on your car so there should not be any problems I think. /MOS Citera
