comment_154006
Hello MustangPeeps
Hope it's all right that i write in English!
I've just purchased a 08 Bullitt from Germany and I hate, that there is no light in the middle tail lights like the Swedish Cars.
It currently does like this:
https://youtu.be/NHBBv_gR_Fg
Outer: Positionsljus + Brake
Middle: Blinker (LED bulb)
Inner: Positionsljus + Fog light (only for left side of the car)
I attached 2 pictures in the mails of the rear wires. If you need me to take more, let me know. I have also checked the SJB, and I can see, that there has been some work done there. If you want pictures from the SJB as well, let me know.
My wish is to have 3 positionsljus and blinkers in the reverse light.
I have seen the "konverteringsguide" that is uploaded here on the site and I understand it fully. Shall I just follow that guide? Or is my car different because it comes from Germany?
Guess im just afraid to mess something up!
I have also mailed Grufman, but would like to have feedback from others as well.
Thanks a lot!
comment_154144
Hi!
According to my "Konverteringsguide" ( I wrote it) you should be able to figure out how your car is modified. Compare your kable-drawing with the guide after converting of SJB.
Hope it will help you.
/MOS
comment_154146
The main thing when you convert from original to European standard is to separate brake light and position light. This seams to be done on your car so there should not be any problems I think.
/MOS
