comment_165870
High Intensity Discharge (HID) bulb
  1. Remove the HID bulb access cover.
  1. NOTE: The HID bulb is retained by spring tension on all 4 sides of the bulb base.
    Remove the headlamp bulb by pulling it straight back.
    • Disconnect the electrical connector.
imagen2.dll?id=N0151615&w=580&t=JPG
All bulb types
  1. To install, reverse the removal procedure.
    • For vehicles equipped with HID headlamps, make sure the bulb cover is fully seated
