comment_2742
Vet ej om detta kan hjälpa dig?
På forumet hos www.vintage-mustang.com
http://forums.vintage-mustang.com/forums/ubbthreads.php
finns en fråga om cabbar (Does anyone know anything about convertible tops?)
med länk till Robbins Auto Top Company i Santa Monica
http://www.robbinsautotopco.com
Företaget beskiver följande:
ROBBINS TECHNICAL NOTES - How To Measure a Bow Height
Check Bow Height Measurement BEFORE removing the old Top from your customer’s car.
To measure:
1.Locate the bottom center of the existing Glass or Plastic Rear Window where it meets the inner edge of the belt molding.
2.Place a yardstick or metal ruler flat against the Rear Window so one end rests against the inner edge of the rear finish molding, and measure to the middle of the rear bow.
3.The Bow Height measurement you have taken should not vary more than 1/2 inch from the figure listed in our Catalog. If the measurement is off more than 1/2 inch, reset the rear bow to the correct height before installation or our top and rear window will not fit correctly.
Katalogen de hänvisar till finns på
http://www.robbinsautotopco.com/pdf_fil ... atalog.pdf (1.8 MB)
Måttet för Mustang 64-66 är 21 tum om jag fattat de hela rätt. Det kanske inte hjälper dig om du redan monterat av din cab.
Lycka till
Mats
cmc 1399 - 65 HT
