grufman
Allt skrivet av grufman
  1. Lär ta max 10 min att skruva dit
  2. I den här tråden svarar vi på aktuella spörsmål gällande ford TSB. I en annan tråd kom frågan gällande TSB 07-16-7, denna fråga besvaras således här. Det finns några medföljande bilder också som inte följer med i texten. Om ngn vill läsa närmare så pm'a mig så mailar jag. ISSUE: Some 2005-2008 Mustang vehicles may exhibit an exterior door handle not flush in the closed position. This may result in a loose handle, rattle noise, hard to open, and/or door self locks when opening outside handle. (Figure 1) ACTION: The concern is caused by pre-loading/biasing the exterior door handle actuating rod, the front door latch, or both. Follow the Service Procedure steps to correct the condition. Figure 1 - Article 07-16-7 SERVICE PROCEDURE Raise the door window glass to the full up position. Remove the door trim panel. Refer to Workshop Manual (WSM), Section 501-05. Position the watershield aside. Raise the manual lock rod to the unlock position. (Figure 2) Figure 2 - Article 07-16-7 Disconnect the exterior door handle actuating rod from the front door latch assembly. Open the retaining clip and disconnect the actuating rod. (Figures 3 through 5) Figure 3 - Article 07-16-7 Figure 4 - Article 07-16-7 Figure 5 - Article 07-16-7 Reinstall the exterior door handle actuating rod back into the clip. NOTE: DO NOT PUSH PIN BACK INTO HANDLE. (FIGURE 6) Figure 6 - Article 07-16-7 Position the actuating rod into clip in a neutral or bias up position. Close the retaining clip and test the system to ensure that the exterior door handle is operating correctly. Adjust the actuating rod as necessary. NOTE: DO NOT BIAS THE ROD DOWN AND DO NOT BIAS THE FRONT DOOR LATCH. NOTE: IF EXTERIOR DOOR HANDLE IS BROKEN, OR THE METAL PIN IS PULLED OUT OF THE SPRING ON THE BACK OF THE DOOR HANDLE, THEN REPLACE THE DOOR HANDLE PER WSM, SECTION 501-14 Position back the watershield. Install the door trim panel. Refer to WSM, Section 501-05.
  3. Nepp. Det här är "technical service bulletines", inte recalls. För mustang 05 finns bara en recall, och den gäller inte oss. Däremot är TSB'er väldigt bra när det gäller att hitta kluriga fel, så vi kollar ofta där när man behöver "tips & råd". Vad är det för recall måntro? Den handlar om att en ventil i växellådan skall gå på fabriksgarantin enl lokala lagar i californien. Inget som rör oss alltså.
  4. Nepp. Det här är "technical service bulletines", inte recalls. För mustang 05 finns bara en recall, och den gäller inte oss. Däremot är TSB'er väldigt bra när det gäller att hitta kluriga fel, så vi kollar ofta där när man behöver "tips & råd".
  5. Den va ju inge spännande ju... Men det verkar som att man ska montera på några metallklumpar som ska dämpa oljudet i bakaxeln. ISSUE: Some 2005 Mustang vehicles built through 11/15/2004 may exhibit an axle whine noise. ACTION: The condition may be corrected by installing tuned dampers on the axle assembly. Refer to the installation instruction sheet included in the kit. PART NUMBER PART NAME 5R3Z-3C246-A Damper Kit
  6. Här kommer en lista på aktuella bulletiner gällande mustang 95. Detta är alltså serviceinformation som ford gett ut och som kan handla om garantiåtaganden och andra serviceproblem på den aktuella bilmodellen. Observera att detta endast är rubrikerna. om du vill läsa innehållet i en specifik TSB, maila så lägger jag ut den. 06-26-1 MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS 03-23-2 BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS 03-18-1 ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS 03-14-8 TRANSMISSION - NEW TRANSMISSION COOLER FLUSHER - SERVICE TIPS 02-17-6 LAMP - BRAKE - INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK 02-16-4 FUEL SYSTEM - FUEL PUMP "WHINING"/"BUZZING" NOISE COMES THROUGH ENTERTAINMENT OR TWO-WAY RADIO SPEAKER RADIO - ENTERTAINMENT OR TWO-WAY COMMUNICATION - "WHINING"/"BUZZING" NOISE IN SPEAKERS CAUSED BY FUEL PUMP NOISE - "WHINING"/"BUZZING" - COMES THROUGH SPEAKERS OF ENTERTAINMENT OR TWO-WAY RADIO 02-11-4 ENGINE - NEW GASKET REMOVER/CLEANER AND SERVICE TIPS FOR ALUMINUM HEADS AND BLOCKS 02-1-9 ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY 01-23-6 ENGINE COOLANT - PROPYLENE GLYCOL - FORD MOTOR COMPANY POSITION ON ENGINE COOLANTS MADE FROM PROPYLENE GLYCOL ENGINE COOLANT - PROPYLENE GLYCOL-BASED - FORD MOTOR COMPANY POSITION ON PROPYLENE GLYCOL-BASED ENGINE COOLANTS 01-21-6 ELECTRICAL - REVISED MECHANICAL HOOD LAMP SWITCH TO REPLACE OLD STYLE MERCURY HOOD LAMP SWITCH 01-10-12 WIRING - WIRE HARNESS TERMINAL REPAIR KIT AND WIRE SPLICE PROCEDURE 01-9-7 DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY 00-23-10 TRANSMISSION - FLUID IN-LINE FILTER KIT - REPEAT REPAIRS OF TRANSMISSION - SERVICE TIPS 00-21-2 HOOD - HOOD REQUIRES EXCESSIVE EFFORT TO CLOSE - SERVICE TIPS 99-22-5 CONVERTIBLE TOP - IMPROPER FIT OF CONVERTIBLE TOP BOOT 99-11-1 NOISE - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS VIBRATION - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS 99-8-15 INTERIOR TRIM - DOOR TRIM PANEL REPLACEMENT - SERVICE TIP 99-4-3 REPROGRAMMING POWERTRAIN CONTROL MODULES (PCMS) - OUT-OF-VEHICLE - EEC V VEHICLES ONLY 99-2-3 WATER LEAKS - WINDSHIELD SEALING - SERVICE TIP WINDSHIELD - SEALING - SERVICE TIP 98-5A-13 BRAKES - DISC BRAKE CALIPER SLIDE GREASE - NEW SPECIFICATION - SILICONE BRAKE CALIPER GREASE AND DIELECTRIC COMPOUND ONLY TO BE USED BRAKES - DRUM - SHOE-TO-BACKING PLATE LUBRICATION - NEW LUBRICANT MATERIAL BRAKES - PETROLEUM-BASED LUBRICANT MAY CAUSE SWELLING OF RUBBER PARTS - SERVICE TIP LUBRICANT - SILICONE DIELECTRIC COMPOUND - NEW APPLICATION - SILICONE BRAKE CALIPER GREASE AND DIELECTRIC COMPOUND 98-5A-11 BRAKES - ELIMINATION OF SANDING ROTORS AND DRUMS - SERVICE TIP 98-5A-10 BRAKES - REAR BRAKE "SQUEAK" - VEHICLES BUILT THROUGH 11/20/94 NOISE - "SQUEAKING" FROM REAR BRAKES - VEHICLES BUILT THROUGH 11/20/94 98-5A-8 BRAKES - "RUBBING" NOISE FROM UNDERNEATH VEHICLE - PARKING BRAKE CABLE CONDUIT CONTACTING DRIVESHAFT NOISE - "RUBBING" NOISE FROM UNDERNEATH VEHICLE - PARKING BRAKE CABLE CONDUIT CONTACTING DRIVESHAFT 98-5A-5 BRAKES - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT BRAKE ROTOR MACHINING - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT 98-5A-4 BRAKES - PREVENTING BRAKE VIBRATION - SERVICE TIP WHEELS - PROPER LUG TORQUE PROCEDURES - SERVICE TIP 98-26-2 FUEL - INFORMATION ON GASOLINE - TIPS TO RESOLVE VOLATILITY RELATED DRIVEABILITY CONCERNS 98-25-3 GLASS - FRONT WINDOW MAY TRAVEL BEYOND THE UPSTOP AND OUT OF THE GLASS RUN 98-24-6 ELECTRICAL - NEW TERMINAL GREASE RELEASED FOR SERVICE 98-23-10 MASS AIR FLOW (MAF) - SENSOR CONTAMINATION - SERVICE TIP 98-22-2 CLUTCH - VIBRATION/NOISE FELT IN CLUTCH PEDAL WHEN LIGHTLY TOUCHING CLUTCH PEDAL 98-20-10 EXHAUST SYSTEM - LOOSE CATALYST OR MUFFLER HEAT SHIELDS NOISE - "BUZZING" OR "RATTLING" - LOOSE CATALYST OR MUFFLER HEAT SHIELDS 98-17-18 MOULDINGS - ROCKER PANEL - LOOSE 98-12-5 AIR CONDITIONING - FILTERING REFRIGERANT AFTER A/C COMPRESSOR REPLACEMENT - SERVICE TIPS 98-10-8 TRANSMISSION - AODE/4R70W - FORWARD CLUTCH - SERVICE TIP 98-9-9 FUEL INJECTORS - NON-WARRANTY REIMBURSEMENT TESTING INFORMATION 98-8-7 VIBRATION - SHUDDER OR VIBRATION UNDER LIGHT TO MODERATE ACCELERATION ABOVE 56 KM/H (35 MPH) WHILE IN 3RD OR 4TH GEAR - VEHICLES EQUIPPED WITH AODE OR 4R70W TRANSMISSION TRANSMISSION - AODE - 4R70W - SHUDDER OR VIBRATION UNDER LIGHT TO MODERATE ACCELERATION ABOVE 56 KM/H (35 MPH) WHILE IN 3RD OR 4TH GEAR 98-7-4 LEAKS - OIL - AVAILABILITY OF NEW SILICONE GASKET AND SEALANT 98-5-2 TIRE - TIRE COMPANY TELEPHONE NUMBERS FOR CUSTOMER ASSISTANCE 97-25-5 BLOWER MOTOR - "CHIRPING" OR "SQUEAKING" FROM BLOWER MOTOR AT LOW SPEEDS NOISE - "CHIRPING" OR "SQUEAKING" FROM BLOWER MOTOR AT LOW SPEEDS 97-24-13 REMOTE KEYLESS ENTRY (RKE) - DIAGNOSTIC SERVICE TIPS 97-24-1 LEAKS WATER - DURING HEAVY RAIN AND/OR WHEN GOING THROUGH CAR WASH - CONVERTIBLE TOP VEHICLES ONLY 97-22-1 DELTA PRESSURE FEEDBACK EGR (DPFE) - DIAGNOSTIC TIPS 97-19-13 TRANSMISSION - AODE - EXTENSION HOUSING BUSHING "WALKOUT"/SPIN - VEHICLES BUILT THROUGH 7/30/95 97-19-11 COOLING SYSTEM - "ON-VEHICLE" HEATER CORE PRESSURE TEST REQUIRED FOR WARRANTY CLAIM 97-19-4 BRAKES - BRAKE AND ROTOR SERVICE TIPS 97-17-2 REAR VIEW MIRROR - NEW PROCEDURE FOR PREFERRED REATTACHMENT METHOD 97-17-1 BODY - SHEET MOLDING COMPOSITE (SMC) - HOOD/FENDER/DECKLID/LIFTGATE - SMALL COSMETIC DAMAGE REPAIR SERVICE TIP 97-16-7 TRANSMISSION - AODE/4R70W - MAIN CONTROL AND CASE USAGE FOR PRIOR MODELS - SERVICE TIP 97-15-5 AIR CONDITIONING - OIL REFILL CAPACITY CHART - SERVICE TIP 97-11-11 TRANSMISSION - 4R70W - ERRATIC OR PROLONGED 1-2 SHIFT TRANSMISSION - AODE - ERRATIC OR PROLONGED 1-2 SHIFT 97-10-5 AIR CONDITIONING - COMPRESSOR FAILURE - INSUFFICIENT AMOUNT OF REFRIGERANT OIL AIR CONDITIONING - LACK OF COOLING - INSUFFICIENT AMOUNT OF REFRIGERANT OIL MAY CAUSE COMPRESSOR FAILURE 97-10-4 ENGINE COOLING FAN - MODULE COMPONENT SERVICE INFORMATION COOLING FAN - MODULE COMPONENT SERVICE INFORMATION 97-9-8 POWERTRAIN CONTROL MODULE - REPROGRAM POWERTRAIN CONTROL MODULE (PCM) - SERVICE PROCEDURES - SERVICE TIP 96-26-12 TRANSAXLE - TORQUE CONVERTER REPLACEMENT GUIDELINES AND TORQUE CONVERTER/TRANSAXLE COOLING SYSTEM CLEANING PROCEDURES - SERVICE TIP TRANSMISSION - TORQUE CONVERTER REPLACEMENT GUIDELINES AND TORQUE CONVERTER/TRANSMISSION COOLING SYSTEM CLEANING PROCEDURES - SERVICE TIP 96-26-8 BLOWER MOTOR - INTERMITTENT OR INOPERATIVE - TEMPERATURES AT OR BELOW 0 DEGREES C (32 DEGREES F) 96-25-17 TRANSMISSION - AODE - 4R70W - SHUDDER OR VIBRATION UNDER LIGHT TO MODERATE ACCELERATION ABOVE 56 KM/H (35 MPH) WHILE IN 3RD OR 4TH GEAR 96-24-9 TORQUE CONVERTER - LEAK TEST PROCEDURE - SERVICE TIP 96-24-6 WIRING - ELECTRICAL DIODE IDENTIFICATION AND SERVICE REPLACEMENTS 96-22-5 MASS AIR FLOW SENSOR - REPLACEMENT AS AN ASSEMBLY - SERVICE TIP 96-22-1 WINDSHIELD AND INTERIOR GLASS - FOG/FILM 96-20-8 AIR CONDITIONING - NEW O-RING APPLICATIONS - THICKER O-RINGS FOR SPRING LOCK FITTINGS - SERVICE TIP AIR CONDITIONING - SPRING LOCK COUPLING CLEANING PROCEDURE - SERVICE TIP 96-20-7 AIR CONDITIONING - NEW O-RING AVAILABILITY AND APPLICATIONS - SERVICE TIP 96-15-9 ACCESSORY DRIVE BELT - BELT EDGE WEAR AND/OR MISTRACKING - MISALIGNED FRONT END ACCESSORY DRIVE (FEAD) BELT - VEHICLES BUILT THROUGH 7/95 WITH 5.0L HO ENGINE ONLY 96-15-6 AIR CONDITIONING - FILTERING REFRIGERANT - SYSTEM FLUSHING - TRACER DYE - LEAK TESTING - O-RING TOOL - TSB REPUBLICATION TO INCLUDE LATEST MODEL YEAR 96-14-9 FRONT END ACCESSORY DRIVE (FEAD) "SQUEAL/HOOT" - DURING COLD START-UP AFTER COLD SOAK BELOW -18 DEGREES C (0 DEGREES F) NOISE - "SQUEAL/HOOT" FROM FRONT END ACCESSORY DRIVE (FEAD) AREA - DURING COLD START-UP AFTER COLD SOAK BELOW -18 DEGREES C (0 DEGREES F) 96-14-8 ENGINE - NOISE - "SQUEAL" NOISE COMING FROM FEAD DURING COLD START AT TEMPERATURES BELOW -7 DEGREES C (20 DEGREES F) - 4.6L VEHICLES NOISE - "SQUEAL" DURING COLD START AT TEMPERATURES BELOW -7 DEGREES C (20 DEGREES F) - FEAD IDLER PULLEY AND/OR FEAD TENSIONER ASSEMBLY - 4.6L VEHICLES 96-12-9 NOISE - "CHATTER" DURING TIGHT TURNS OR TURNS AFTER AN EXTENDED PERIOD OF HIGHWAY DRIVING - TRACTION-LOK DIFFERENTIAL - 7.5 AND 8.8 INCH RING GEAR REAR AXLES AXLE - NEW SERVICE KIT AVAILABLE FOR TRACTION-LOK DIFFERENTIAL - 7.5 AND 8.8 INCH RING GEAR AXLE - TRACTION-LOK DIFFERENTIAL - 7.5 AND 8.8 INCH RING GEAR - "CHATTER" NOISE DURING TIGHT TURNS OR TURNS AFTER AN EXTENDED PERIOD OF HIGHWAY DRIVING 96-10-7 FUEL - CALIFORNIA REFORMULATED GASOLINE (CARFG) - SERVICE TIP 96-10-6 NEW GENERATION STAR (NGS) TESTER - INCORRECT INFORMATION DISPLAYED DURING DIAGNOSTIC MONITORING TEST RESULTS - VEHICLES WITH ON-BOARD DIAGNOSTICS (OBD) II 96-4-1 CONVERTIBLE TOP - SERVICE REPLACEMENT PARTS DIFFERENT FROM ORIGINAL - SERVICE TIP 96-1-1 STEERING - POWER RACK AND PINION - REVISED TORQUE REQUIREMENT FOR INSTALLING NEW DESIGN TIE RODS 95-24-3 ROCKER ARM - 3.8L ENGINE - LOW PITCHED "SQUEAK", "CHIRP" OR "KNOCK" NOISE NOISE - 3.8L ENGINE - LOW PITCHED "SQUEAK", "CHIRP" OR "KNOCK" FROM ROCKER ARM 95-23-4 VIBRATION/SHUDDER - UNDER LIGHT ACCELERATION ABOVE 56 KM/H (35 MPH) IN 3RD OR 4TH GEAR TRANSMISSION - AODE/4R70W - SHUDDER/VIBRATION UNDER LIGHT ACCELERATION ABOVE 56 KM/H (35 MPH) IN 3RD OR 4TH GEAR 95-22-8 AIR BAG WARNING LAMP - INCORRECT DIAGNOSIS OF AIR BAG CODE 24 - SERVICE TIP 95-21-1 SUPPLEMENTAL RESTRAINT SYSTEM - AIR BAG MODULES - DISCOLORED OR MARRED COVERS - PAINTING RESTRICTIONS 95-18-4 AIR CONDITIONING - FORD APPROVED FLUSHING PROCEDURES - SERVICE TIP 95-18-2 COOLANT - USE OF RECYCLED ENGINE COOLANT - SERVICE TIP COOLING SYSTEM - USE OF RECYCLED ENGINE COOLANT - SERVICE TIP 95-17-3 INTERIOR TRIM - CONSOLE - INTERFERENCE BETWEEN PARKING BRAKE HANDLE AND CONSOLE GAP HIDER 95-16-10 FLUID - NEW ROTUNDA FLUID CHANGER - SERVICE TIP 95-14-4 BALL JOINT - REPLACEMENT PROCEDURE - SERVICE TIP 95-13-2 GAUGE - TEMPERATURE - READS IN LOW RANGE - ERRATIC READINGS SERVICE PARTS - RETURN OF OBSOLETE TEMPERATURE SENDERS 95-13-1 AIR CONDITIONING - EVAPORATOR CORE - "ON-VEHICLE" LEAK TEST REQUIRED FOR WARRANTY CLAIM AIR CONDITIONING - "ON-VEHICLE" EVAPORATOR CORE LEAK TEST REQUIRED FOR WARRANTY CLAIM 95-12-1 GLASS - WINDSHIELD - URETHANE MOUNTED GLASS MATERIAL USAGE PROCEDURE - SERVICE TIP 95-9-3 RADIO - "DISTORTION" - "POOR RECEPTION" - RELATED TO THE IGNITION SYSTEM - 5.0L ENGINE NOISE - "WHINE, POP, DISTORTION OR POOR RECEPTION" IN THE RADIO - IGNITION SYSTEM RELATED - 5.0L ENGINE 95-8-4 LEAKS - AODE/4R70W - REUSABLE PAN GASKET AND FILTER TRANSMISSION - AODE/4R70W - REUSABLE PAN GASKET AND FILTER - SERVICE TIP 95-6-8 ENGINE - 5.0L - REVISED OIL PAN GASKET REPLACEMENT PROCEDURE - SERVICE TIP 95-6-2 BRAKES - ROUGHNESS CONCERN DURING BRAKE APPLICATION 95-6-1 PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION PAINT - ROUGH TEXTURE/FERROUS METAL CONTAMINATION - ACID RAIN DISCOLORATION OR ETCHING 95-5-15 TRANSMISSION - AODE/4R70W - INTERMITTENT LOSS OF TORQUE DURING OR JUST AFTER 3-4 UPSHIFT - MAY BE INTERMITTENT 95-5-14 ENGINE - OIL - REVISED OIL FILL PROCEDURES FOR 5.0L/5.8L VEHICLES - SERVICE TIP 95-5-12 AIR CONDITIONING - ADDING REFRIGERANT OIL - SERVICE TIP 95-3-13 TRANSMISSION - AODE/4R70W - DIAGNOSTIC TROUBLE CODES - WATER INTRUSION OF THE MLP/TR SENSOR TRANSMISSION - AODE/4R70W - POSSIBLE WATER INTRUSION INTO THE MLP/TR SENSOR CAUSING SHIFT CONCERNS AND/OR ENGAGEMENT CONCERNS TRANSMISSION - AODE/4R70W - SHIFT CONCERNS AND/OR ENGAGEMENT CONCERNS DUE TO WATER INTRUSION OF THE MLP/TR SENSOR 95-3-10 ENGINE - 5.0L - NEW TORQUE-TO-YIELD CYLINDER HEAD BOLT KIT AND NEW PROCEDURES - SERVICE TIP 95-2-4 COOLING SYSTEM - RADIATOR - NEW MANUFACTURING PROCESS ("CUTS" IN UPPER AND LOWER SUPPORTS) 95-2-2 AIR CONDITIONING - O-RING REMOVAL FROM SPRING LOCK COUPLER - SERVICE TIP 95-1-2 ACCELERATOR CABLE - DIAGNOSTIC PROCEDURE 94-26-6 AIR CONDITIONING - RELEASE OF R-134A FLUORESCENT TRACER DYE - FOR 1992 TAURUS, R-134A VEHICLES ONLY - SERVICE TIP 94-26-5 LAMPS - HEADLAMPS - REMOVAL PROCEDURE - SERVICE TIP 94-26-4 THROTTLE POSITION SENSOR (TPS) - FUNCTION AND DIAGNOSTIC TIPS RECAP - TPS APPLICATION CHART 94-26-2 AIR BAG - DIAGNOSTIC TROUBLE CODE RETRIEVAL - PROGRAMMING CHANGE 94-25-2 BRAKES - AVAILABILITY OF ON-VEHICLE CALIPER-MOUNTED BRAKE ROTOR MACHINING EQUIPMENT AND WARRANTY COVERAGE INFORMATION BRAKE ROTOR MACHINING - AVAILABILITY OF ON-VEHICLE CALIPER-MOUNTED BRAKE ROTOR MACHINING EQUIPMENT AND WARRANTY COVERAGE INFORMATION 94-23-9 AIR CONDITIONING - LITTLE OR NO COOLING - FS-10 COMPRESSORS - EXCESSIVE CLUTCH AIR GAP - ALL ENGINES EXCEPT 1.8L ESCORT/TRACER AND 3.0L, 3.2L SHO - VEHICLES BUILT THROUGH 9/19/94 94-23-5 BRAKES - FRONT DISC - "THUMPING/CLACKING" NOISE WHILE BRAKING NOISE - "THUMPING/CLACKING" WHILE BRAKING - FRONT DISC BRAKES 94-22-6 AIR CONDITIONING/HEATING - TEMPERATURE CONTROL KNOB DOES NOT REACH FULL COOL POSITION 94-20-6 AIR CONDITIONING - OIL VISIBLE AT SPRING LOCK COUPLERS - SERVICE TIP 94-17-2 REAR VIEW MIRROR - DETACHES FROM WINDSHIELD - SERVICE TIP
  7. Här kommer en lista på aktuella bulletiner gällande mustang 98. Detta är alltså serviceinformation som ford gett ut och som kan handla om garantiåtaganden och andra serviceproblem på den aktuella bilmodellen. Observera att detta endast är rubrikerna. om du vill läsa innehållet i en specifik TSB, maila så lägger jag ut den. 07-21-2 4.6L 2V, 5.4L 2V, OR 6.8L 2V - SPARK PLUG THREAD REPAIR PROCEDURE - NOT COVERED UNDER NEW VEHICLE LIMITED WARRANTY 07-1-7 MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS 06-26-1 MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS 06-21-19 HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY) 05-22-8 WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING 03-23-2 BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS 03-20-3 DRIVEABILITY - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DTC'S P0442, P0455, P0456, P0457, P1442 OR CHECK FUEL CAP LAMP ILLUMINATED WITH DTC P0457 03-18-1 ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS 03-14-8 TRANSMISSION - NEW TRANSMISSION COOLER FLUSHER - SERVICE TIPS 02-22-1 DRIVEABILITY - SURGE/ROLLING IDLE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION ENGINE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION 02-21-13 ENGINE - STRAIGHTEDGE PROCEDURE FOR CHECKING CYLINDER HEAD AND BLOCK FLATNESS 02-17-6 LAMP - BRAKE - INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK 02-16-4 FUEL SYSTEM - FUEL PUMP "WHINING"/"BUZZING" NOISE COMES THROUGH ENTERTAINMENT OR TWO-WAY RADIO SPEAKER RADIO - ENTERTAINMENT OR TWO-WAY COMMUNICATION - "WHINING"/"BUZZING" NOISE IN SPEAKERS CAUSED BY FUEL PUMP NOISE - "WHINING"/"BUZZING" - COMES THROUGH SPEAKERS OF ENTERTAINMENT OR TWO-WAY RADIO 02-11-4 ENGINE - NEW GASKET REMOVER/CLEANER AND SERVICE TIPS FOR ALUMINUM HEADS AND BLOCKS 02-2-2 COOLANT - COOLANT SEEPAGE AT INTAKE MANIFOLD CROSS-OVER - VEHICLES EQUIPPED WITH 4.6L 2V ENGINE ONLY ENGINE - 4.6L 2V - COOLANT SEEPAGE AT INTAKE MANIFOLD CROSS-OVER 02-1-9 ENGINE - ENGINE OIL - RECOMMENDED APPLICATIONS FOR SAE 5W-20 AND SAE 5W-30 MOTOR OILS - GASOLINE AND FLEXIBLE FUEL VEHICLES ONLY 01-23-6 ENGINE COOLANT - PROPYLENE GLYCOL - FORD MOTOR COMPANY POSITION ON ENGINE COOLANTS MADE FROM PROPYLENE GLYCOL ENGINE COOLANT - PROPYLENE GLYCOL-BASED - FORD MOTOR COMPANY POSITION ON PROPYLENE GLYCOL-BASED ENGINE COOLANTS 01-23-5 TRANSMISSION - T-45 MANUAL TRANSMISSION - STUCK IN REVERSE - DIFFICULT TO SHIFT INTO REVERSE - POPS OUT OF REVERSE 01-21-13 DRIVEABILITY - DIAGNOSTIC TROUBLE CODES (DTC) P0500, P1502 AND/OR U1039 CONTINENTAL MODELS ONLY - STICKING OR BINDING IGNITION LOCK CYLINDER - HIGH EFFORT WHEN TURNING IGNITION SWITCH ELECTRICAL - STICKING OR BINDING IGNITION LOCK CYLINDER - HIGH EFFORT WHEN TURNING IGNITION SWITCH 01-21-10 ENGINE - 4.6L - OIL LEAK FROM HEAD GASKET AREA - ROMEO BUILT ENGINES ONLY 01-10-12 WIRING - WIRE HARNESS TERMINAL REPAIR KIT AND WIRE SPLICE PROCEDURE 01-9-7 DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY 01-6-2 PASSIVE ANTI THEFT SYSTEM (PATS) - DIAGNOSTIC SERVICE TIPS 00-23-10 TRANSMISSION - FLUID IN-LINE FILTER KIT - REPEAT REPAIRS OF TRANSMISSION - SERVICE TIPS 00-21-2 HOOD - HOOD REQUIRES EXCESSIVE EFFORT TO CLOSE - SERVICE TIPS 00-9-7 VIBRATION/SHAKE - AT STEADY SPEED APPROXIMATELY 100 KM/H (62 MPH) - VEHICLES WITH 4.6L ENGINE AND CONVERTIBLE TOP 00-9-1 LEAK - TRANSMISSION FLUID LEAKS AT RADIATOR - VEHICLES EQUIPPED WITH AUTOMATIC TRANSMISSION AND TRANSMISSION OIL COOLER IN RADIATOR END TANK 00-4-2 VIBRATION/SHAKE - AT STEADY SPEED APPROXIMATELY 100 KM/H (62 MPH) - VEHICLES WITH 3.8L ENGINE AND CONVERTIBLE TOP 99-24-2 LOCKS - REPLACE AND/OR REPAIR ANY LOCK COMPONENT - AVAILABILITY OF INDIVIDUAL LOCKS 99-23-4 MALFUNCTION INDICATOR LAMP (MIL) - DIAGNOSTIC TROUBLE CODES (DTCS) P0442 AND P0455 - NO DRIVEABILITY CONCERNS 99-22-5 CONVERTIBLE TOP - IMPROPER FIT OF CONVERTIBLE TOP BOOT 99-20-7 COOLING SYSTEM - 3.8L - UNDETERMINED LOSS OF COOLANT COOLING SYSTEM - 4.2L - UNDETERMINED LOSS OF COOLANT ENGINE - 3.8L - ENGINE OIL CONTAMINATED WITH COOLANT ENGINE - 4.2L - ENGINE OIL CONTAMINATED WITH COOLANT 99-18-5 TRANSMISSION CONTROL INDICATOR LAMP (TCIL) - TCIL ILLUMINATED WITH DIAGNOSTIC TROUBLE CODE (DTC) P0782 STORED IN MEMORY - VEHICLES BUILT BETWEEN 3/15/1997 AND 12/31/1998 AND WITH 4R70W TRANSMISSION TRANSMISSION - 4R70W - DELAYED OR NO 2-3 UPSHIFT - VEHICLES BUILT BETWEEN 3/15/1997 AND 12/31/1998 99-11-1 NOISE - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS VIBRATION - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS 99-10-1 BODY - DUST INTRUSION INTO LUGGAGE COMPARTMENT WATER LEAK - EVIDENCE OF WATER LEAK INTO LUGGAGE COMPARTMENT NOISE - EXCESSIVE ROAD NOISE HEARD FROM REAR WHEEL AREA 99-8-15 INTERIOR TRIM - DOOR TRIM PANEL REPLACEMENT - SERVICE TIP 99-5-3 TRANSMISSION - CHECKING TRANSMISSION FLUID LEVEL COLD - SERVICE TIP 99-4-3 REPROGRAMMING POWERTRAIN CONTROL MODULES (PCMS) - OUT-OF-VEHICLE - EEC V VEHICLES ONLY 99-2-3 WATER LEAKS - WINDSHIELD SEALING - SERVICE TIP WINDSHIELD - SEALING - SERVICE TIP 98-5A-5 BRAKES - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT BRAKE ROTOR MACHINING - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT 98-26-2 FUEL - INFORMATION ON GASOLINE - TIPS TO RESOLVE VOLATILITY RELATED DRIVEABILITY CONCERNS 98-25-9 INTERIOR TRIM - REPAIRS TO VINYL COVERED SURFACES - SERVICE TIP 98-25-3 GLASS - FRONT WINDOW MAY TRAVEL BEYOND THE UPSTOP AND OUT OF THE GLASS RUN 98-24-6 ELECTRICAL - NEW TERMINAL GREASE RELEASED FOR SERVICE 98-23-12 TRANSMISSION - 4R44E - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY TRANSMISSION - 4R55E - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY TRANSMISSION - 4R70W - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY TRANSMISSION - 5R55E - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY TRANSMISSION - AX4N - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY TRANSMISSION - AX4S - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY TRANSMISSION - E4OD - DIAGNOSTIC TROUBLE CODES (DTCS) P0705, P0708, P1704 AND/OR P1705 STORED IN MEMORY 98-23-10 MASS AIR FLOW (MAF) - SENSOR CONTAMINATION - SERVICE TIP 98-22-2 CLUTCH - VIBRATION/NOISE FELT IN CLUTCH PEDAL WHEN LIGHTLY TOUCHING CLUTCH PEDAL 98-20-18 FRONT END ACCESSORY DRIVE (FEAD) BELT - BELT NOISE, DAMAGE, AND/OR BELT COMES OFF - VEHICLES WITH 4.6L ENGINE AND MANUAL TRANSMISSION 98-20-10 EXHAUST SYSTEM - LOOSE CATALYST OR MUFFLER HEAT SHIELDS NOISE - "BUZZING" OR "RATTLING" - LOOSE CATALYST OR MUFFLER HEAT SHIELDS 98-20-3 BODY - ADHESIVES NOT RECOMMENDED FOR BODY PANEL REPAIRS - SERVICE TIP 98-18-2 PAINT - EXTERIOR - WORLDWIDE RECOMMENDED PAINT MATERIALS FOR WARRANTY AND AFTER WARRANTY REPAIRS 98-17-18 MOULDINGS - ROCKER PANEL - LOOSE 98-12-5 AIR CONDITIONING - FILTERING REFRIGERANT AFTER A/C COMPRESSOR REPLACEMENT - SERVICE TIPS 98-9-9 FUEL INJECTORS - NON-WARRANTY REIMBURSEMENT TESTING INFORMATION 98-7-4 LEAKS - OIL - AVAILABILITY OF NEW SILICONE GASKET AND SEALANT 98-5-2 TIRE - TIRE COMPANY TELEPHONE NUMBERS FOR CUSTOMER ASSISTANCE 98-4-12 TRANSMISSION - 4R70W - SERVICE PROCEDURE FOR ORANGE SERVICE TAGGED TRANSMISSIONS 98-4-4 PAINT - ANTI-CHIP STONE ABRASION UNDERCOAT - SERVICE TIP 97-25A-1 EVAPORATIVE EMISSIONS SUPPLEMENT 97-24-13 REMOTE KEYLESS ENTRY (RKE) - DIAGNOSTIC SERVICE TIPS 97-21-10 TRANSMISSION - 4R70W - NEW DESIGN ENHANCEMENTS FOR 1998 VEHICLES TRANSMISSION - 4R70W - NEW ONE-WAY CLUTCH (OWC) TO SERVICE AT THE INTERMEDIATE POSITION 97-19-11 COOLING SYSTEM - "ON-VEHICLE" HEATER CORE PRESSURE TEST REQUIRED FOR WARRANTY CLAIM 97-15-5 AIR CONDITIONING - OIL REFILL CAPACITY CHART - SERVICE TIP
  8. Här kommer en lista på aktuella bulletiner gällande mustang 04. Detta är alltså serviceinformation som ford gett ut och som kan handla om garantiåtaganden och andra serviceproblem på den aktuella bilmodellen. Observera att detta endast är rubrikerna. om du vill läsa innehållet i en specifik TSB, maila så lägger jag ut den. 07-21-2 4.6L 2V, 5.4L 2V, OR 6.8L 2V - SPARK PLUG THREAD REPAIR PROCEDURE - NOT COVERED UNDER NEW VEHICLE LIMITED WARRANTY 07-16-17 SPARK KNOCK UNDER LIGHT LOAD AND ACCELERATION - 3.8L, 3.9L, AND 4.2L - SPLIT PORT INTAKE MANIFOLD RUNNER CONTROL (IMRC) 07-5-8 BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS 07-4-3 LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE 07-1-7 MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS 06-26-1 MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS 06-21-19 HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY) 06-18-16 IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES - SERVICE TIP 06-15-8 KEYPAD DIAGNOSTICS - DEALER INSTALLED ACCESSORY 06-8-5 SPEED CONTROL DIAGNOSTICS - W/O SCP 06-5-13 ENGINE MISFIRE WITH DIAGNOSTIC TROUBLE CODE (DTC) P0301, P0302, P0303, P0304, P0305, P0306, P0307, P0308, AND P0316. 06-4-9 A/C COMPRESSOR NOT OPERATIONAL / LOW FREON - SHAFT SEAL LEAKS 06-4-4 LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS 05-22-8 WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING 05-18-7 WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS 05-14-3 SQUEAK/CREAK NOISE FROM STEERING RACK WHEN TURNING 05-9-3 INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS 05-3-10 SAFETY BELT WEB STOP BUTTON SERVICE 04-26-13 1-2 SHIFT CLASH, GRIND OR HARD TO SHIFT - TR3650 5 SPEED MANUAL TRANSMISSION 04-24-5 REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR 04-21-6 EXHAUST LEAK - CRACKED OR SEPARATED RIGHT SIDE EXHAUST PIPE - 3.8L AND 3.9L ENGINES 04-19-8 MANUAL TRANSMISSION HARD TO SHIFT INTO FIRST/REVERSE FROM A STOP 04-17-4 MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - SYSTEM LEAN DIAGNOSTIC TROUBLE CODES (DTC'S) - SERVICE TIPS 04-13-4 TRANSMISSION RATTLE NOISE OR DIFFICULT TO SHIFT - TREMEC T56 6 SPEED MANUAL 04-9-6 BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION 04-5-3 CLIMATE CONTROL - RATTLE NOISE FROM INSTRUMENT PANEL VENTS - DIFFICULT TO ADJUST NOISE - CLIMATE CONTROL - RATTLE NOISE FROM INSTRUMENT PANEL VENTS - DIFFICULT TO ADJUST 03-25-6 ENGINE - ROMEO BUILT 4.6L 2V - TICK NOISE FROM ENGINE - ENGINES BUILT BEFORE 9/17/2003 03-23-2 BODY - MIRROR - EXTERIOR MIRROR GLASS AND MOTOR REPLACEMENT - SERVICE TIPS 03-22-1 BODY - NOISE - HOOD SCOOP (SHAKER) RATTLE NOISE ENGINE - NOISE - HOOD SCOOP (SHAKER) RATTLE NOISE NOISE - HOOD SCOOP (SHAKER) RATTLE NOISE 03-18-1 ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS
  9. Här kommer en lista på aktuella bulletiner gällande mustang 05. Detta är alltså serviceinformation som ford gett ut och som kan handla om garantiåtaganden och andra serviceproblem på den aktuella bilmodellen. Observera att detta endast är rubrikerna. om du vill läsa innehållet i en specifik TSB, maila så lägger jag ut den. 07-23-1 GRUNT/CREAK/SQUEAK/CHIRP NOISE FROM THE LOWER CONTROL ARM BUSHING OVER BUMPS - BUILT BEFORE 2/28/2007 07-22-8 8.8 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS 07-21-12 FUEL FILL SLOW, OR DIFFICULT TO FILL 07-20-3 CONVERTIBLE TOP - TENSION CABLE NOISE - BUILT BEFORE 12/1/2006 07-19-1 CONVERTIBLE TOP WEAR - BUILT BEFORE 10/11/2006 07-18-2 4.0L AND 4.6L COUPE - FRONT END NOISE OVER BUMPS 07-18-1 FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005 07-17-8 CONVERTIBLE SYSTEM CONCERNS 07-17-6 BUZZ/RATTLE FROM DOOR PANEL WHEN OPERATING AUDIO SYSTEM - VEHICLES BUILT BEFORE 8/2/2007 07-16-7 EXTERIOR DOOR HANDLE NOT FLUSH IN THE CLOSED POSITION 07-14-6 WATER LEAK - FRONT FLOOR AREA 07-12-3 RCM FAULT REPORTING USING DTCS AND BIT-MAPPED PARAMETER IDENTIFIERS (PIDS) - SERVICE TIPS 07-5-13 DISCHARGED BATTERIES - VEHICLES IN STORAGE/LIMITED USAGE 07-5-8 BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS 07-4-3 LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE 07-3-9 MIL ON - DTC P0456 07-1-7 MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS 06-26-2 CARPET REMOVE AND REPLACE 06-26-1 MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS 06-25-15 ALUMINUM BODY PANELS - CORROSION - SERVICE TIP 06-22-18 POWER WINDOW DIAGNOSIS 06-21-19 HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY) 06-21-7 AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES 06-19-12 DTC P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V 06-19-8 TICKING AND / OR KNOCKING NOISE / STARTUP RATTLE FROM ENGINE - 4.6L / 5.4L 3V 06-18-16 IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES - SERVICE TIP 06-17-8 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS 06-15-8 KEYPAD DIAGNOSTICS - DEALER INSTALLED ACCESSORY 06-14-3 AIR CONDITIONER COMPRESSOR CLUTCH FAILURE - REVISED COMPRESSOR CLUTCH 06-10-13 MIL P0463 OR ERRATIC FUEL GAUGE 06-9-9 HESITATION ON ACCELERATION AFTER LONG CRUISE 06-7-10 MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020 - 4.6L 3V 06-5-4 PARK BRAKE CABLE FREEZING/REAR BRAKES DRAGGING 06-4-9 A/C COMPRESSOR NOT OPERATIONAL / LOW FREON - SHAFT SEAL LEAKS 06-4-1 RATTLE/NOISE FROM THE CENTER STACK (RADIO/HEATER) OF THE INSTRUMENT PANEL OR GEARSHIFT AREA 05-22-8 WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING 05-20-2 REAR AXLE NOISE 05-19-10 LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT 05-18-10 BRAKE NOISE - VEHICLES BUILT BEFORE 3/8/2005 05-18-7 WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS 05-15-13 FRONT SIDE MARKER LAMP RETAINING TAB BREAKING 05-15-12 FUEL FILL SLOW, OR DIFFICULT TO FILL - VEHICLES BUILT BEFORE 4/26/2005 05-15-2 GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 2/21/2005 05-14-4 WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR 05-10-19 INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS 05-9-14 CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS 05-9-3 INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS 05-8-6 EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION 05-7-3 AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004 05-6-15 AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004 05-3-1 MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM) 04-26-22 MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE 04-26-16 WELD BONDING PROCEDURE 04-24-5 REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR 04-9-6 BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
  10. Vi gjorde om utseendet, bantade sidantalet och gjorde den lite snyggare. Blev den bättre eller åkte den i soporna? Det var den orangea katalogen med den vita forden på framsidan om någon undrar. Vi vill veta - vad tyckte du?
  11. skulle inte en omdrevad bakaxel ge betydligt bättre orr vid rödljusen?
  12. grufman replied to MOS's post in a topic in Mustang 1994-2004
    skruvar på undersidan av kåporna. sen vrider man tändningslåset till tändningsläge och pillar in lilla låskulan underifrån med en smal skruvmejsel. Mekar ut låset och sen får man bort alla kåpor. Det brukar dock aldrig vara blinkersspaken som är trasig om varningsblinkersen inte funkar. Sannolikt ngt annat.
  13. kan nämna att även vi har reservdelar till bakaxlarna, brukar inte vara några stora summor
  14. det brukar vina eller morra i bakaxeln om man har lagerskador. om man har en diffbromsad bakaxel så kan det bryta i axlarna om man inte tillsatt xl3 friktionsmodifierare. tror dock inte v6 har difflåst bakaxel.
  15. grufman replied to Freddan's post in a topic in Mustang 2005-2014
    Sen när gäller detta? Iof inte så konstigt men iaf... sedan något år ungefär. vissa besiktningsmän är dock inte uppdaterade på vad som gäller, så man kanske slinker igenom där, men det är onödigt att chansa när det finns bra alternativ.
  16. grufman replied to Freddan's post in a topic in Mustang 2005-2014
    Numera går det inte att köra orangea lampor i backljusen vid regbes. inte heller inborrade p-ljus i strålkastarna fram. Tyvärr
  17. ett inlägg i en tråd postade grufman i Mustang 2005-2014
    Ville bara belysa detta igen att om man känner för att trimma sin GT med kompressor så kommer man inte bara köra sönder automatlådan (om man råkar ha en sådan). Man kommer dessutom köra sönder katalysatorerna. Vill man köra med kompressor skall man antingen ha en preppad automat eller manuell låda, och man bör byta ut sina originalkattar mot racekattar istället. Originalarna har svårt att klara trycket. Ligger på ca 17 000kr. Fler erfarenheter från er som kör kompressormatat?
  18. grufman replied to Stefan cmc 1169's post in a topic in Motorer
    Sjukt fräsht med nymålade motorer. Riktigt bra blir det :-)
  19. 18 år Man Djursholm Jobbar inte, pappa köpte shelbyn till mej ;-)
  20. såhär står det i bulletinen från ford ISSUE: Some vehicles built 11/29/2004 and prior may exhibit the wrench light on with both P2106 and P2135 diagnostic trouble codes (DTCs). ACTION: Replace the throttle position sensor (TPS) following the instruction sheet included in the TPS service kit. Reprogram the powertrain control module (PCM) to the latest calibration using WDS release B36.11 and higher, or B37.2 and higher.
  21. grufman replied to Fröberg's post in a topic in Mustang 2005-2014
    Om man måste stå ute så har ford ett originalkapell som är utformat för mustang gt. Jag har sålt ett 10-tal med mkt bra resultat. Det är ett multilagerskapell som går att låsa om jag inte missminner mig. Det andas dessutom och man riskerar då inte att det börjar rosta och bli äckligt. Bra grejjer om man måste stå ute.
  22. grufman replied to grufman's post in a topic in Mustang 1994-2004
    Låter intressant, noterar det så tar vi det vid nästa tillfälle när en musse 5.0 kommer in. Fler tips?
  23. grufman replied to grufman's post in a topic in Mustang 1994-2004
    finns redan i katalogen, som också finns för nedladdning. Mer tips?
  24. Kan tillägga att det nog är TPS-givaren som har fuxXxat sig. Rätt vanligt på 05'or. Då går bilen vääääldigt slött. Tror vi har en ny på hyllan om jag inte missminner mig. Men somsagt, efter lunch!
  25. Kom efter lunch.. innan lunch tar chefen flyglektioner (multiengine-certet är snart i hamn). :-)
