August 9, 20169 yr comment_152389 http://www.americanmuscle.com/raxiom-switchback-turn-signal-1516.html Ovanstående LED lampor verkar ge ett betydligt bättre och starkare ljus än de lite tråkiga lampor som sitter original. Någon som har monterat och har några erfarenheter LED i de varseljus och blinkers som bilen har? Martin
August 9, 20169 yr comment_152398 Köpte en kort modell: dom första jag köpte var för långa så dom bottnade i lampan . Kommer ej ihåg effekt på dom men klar vita är dom
August 29, 20169 yr comment_152704 I had the same oppinion about the standard lights as Magnus, can use a bit upgrade to make the whole car cooler. Did order this switchback turn signal lamps from USA but when I wanted to istall them I had to realise the EU mustang light system is absolutly differnt from the US modell. It not just works diferently but even the lamp setup in the car is diferent. I couldn't follow the US tutorials for the install and couldn't find any EU variation for it. Personally I think the US version of the light system looks better, for which lamp lit up and when... it is sad I couldn't find information about this before I made my order. It would be nice to tweak it if there is a way to do it. I also have ordered a sequential tail light from the same place, but I had a same luck with it. The conenctor is diffenrt on the US model than the EU. So these stuff are working only the US models unfortunately.
September 9, 20169 yr comment_152871 #FastMagnus: Do you have any suggestion? :) I would be really happy to pimp up the light system in some way to make it closer to the US version, or above :D It is also quite frustrating that the tri-bar LED lamp in the front light is not used DTRLs like the US version have. I have read it was permanently disabled in the EU version by some regulation, despite it is one of the most recognizable part of the new mustang. https://www.carthrottle.com/post/5-subtle-design-differences-between-us-and-euspec-ford-mustangs/ If you import the car than it is okay I guess but if you buy it in the EU you don't have it. It is supposed to be just a software update but they couldn't say if for sure in the service. Does anyone have experience how to turn on these led lines in the front lamp??
September 9, 20169 yr comment_152875 I have a kit here from steeda with remote controll so you can chose your collor
