(redigerad)
Här är listan för 2017. Om du vill ha mer detaljer om en viss bulle så svara nedan.
GSB G0000175 - Effective Apr 19 2018
Ambient Air Temperature (AAT) Sensor
SSM 47240 - Effective Apr 16 2018
2016-2017 Various Vehicles - SYNC 3 Navigation Map Updates
SSM 47225 - Effective Apr 10 2018
2015-2018 Mustang - Equipped With Sync 3 - Inoperative Universal Serial Bus (USB) Ports With DTC B1252:13 - Built On Or Before 1-Jan-2018
GSB G0000174 - Effective Apr 6 2018
2013-2018 Various Vehicles - Instrument Panel Cluster Mask / Lens Warranty
SSM 47211 - Effective Apr 4 2018
2016-2017 Various Vehicles - SYNC 3 - Blank Screen After Exiting Valet Mode
SSM 47200 - Effective Mar 30 2018
2015-2018 Mustang - No Horizontal Adjustment Of Front Power Seats - Power Seat Track Motor Inoperative
TSB 18-2107 - Effective Mar 30 2018
2015-2018 Mustang GT350 - Excessive Panel Gap Between Rear Bumper Cover And Rear Quarter Panels - Built On Or Before 26-Feb-2018
SSM 47201 - Effective Mar 30 2018
2008-2018 Various Ford/Lincoln/Mercury Vehicles - Replacing/Upgrading Original Equipment SYNC/Navigation System Components Is Not Supported
GSB G0000172 - Effective Mar 30 2018
2010-2018 Various Vehicles - Ear Clamp Removal Procedure
SSM 47171 - Effective Mar 21 2018
2016-2018 Various Vehicles - SYNC 3 - iPhone USB Audio Playback And App Link Functionality Issues
SSM 47170 - Effective Mar 21 2018
2017- 2018 Multiple Vehicles - Illuminated Malfunction Indicator Lamp (MIL) With Variable Cam Timing (VCT) DTCs - Diagnostic Information
SSM 47167 - Effective Mar 19 2018
2016-2017 Ford And Lincoln Vehicles Equipped With SYNC 3 - Touchscreen Unresponsive
SSM 47149 - Effective Mar 13 2018
2015-2017 Mustang - Poor Air Conditioning (A/C) Performance, Low Refrigerant Charge - Built On Or Before 2-Sep-2016
GSB G0000171 - Effective Feb 27 2018
Laminated/Tempered/Heated Glass Damage General Service Bulletin
SSM 47080 - Effective Feb 14 2018
2010-2018 Various Vehicles - Spotify Not Found Or Not Functioning On AppLink
SSM 47070 - Effective Feb 9 2018
Various Vehicles - Data Link Connector (DLC) Connection - Vehicles Equipped With Gateway Module (GWM)
TSB 18-2036 - Effective Feb 7 2018
2015-2018 Mustang Convertible - Roof Sagging At The Rear Glass
GSB G0000168 - Effective Feb 2 2018
Tire Vibration – Equipment Based Diagnostics and Requirements For Warranty Claim Submission
GSB G0000167 - Effective Jan 22 2018
Multiple Vehicles - Engine Oil White Fluorescent Dye Usage General Service Bulletin (GSB)
GSB G0000166 - Effective Jan 22 2018
Multiple Vehicles - Surface Preparation For Oil Leaks
GSB G0000165 - Effective Jan 18 2018
Multiple Vehicles - Lower End Engine Noise Diagnostic Aid - Inspecting the Oil Filter Element General Service Bulletin (GSB)
GSB G0000162 - Effective Jan 17 2018
Multiple Vehicles - Gas Engine Performance Modifications
SSM 47012 - Effective Jan 11 2018
2015-2018 F-150, Mustang, Transit - No Airflow From Climate Control Vents - Air Conditioning (A/C) Clutch Seized And/Or Stuck - Built On Or Before 01-Dec-2017
TSB 18-2006 - Effective Jan 10 2018
2017 Mustang - Dual Automatic Temperature Control (DATC) - Poor Air Conditioning (A/C) Performance
SSM 46995 - Effective Jan 3 2018
2015-2017 Mustang - Convertible Top Wear Or Damage On Outer Front Edges - Built On Or Before 1-Feb-2017
TSB 17-2271 - Effective Dec 25 2017
Various Vehicles - 2.0L/2.3L/2.7L EcoBoost, 5.0L, 5.2L - Engine Oil Pressure (EOP) Sensor Oil Leak
SSM 46973 - Effective Dec 11 2017
2015 - 2018 GT350 R Spring And Shock Spacer Removal Required At Pre-Delivery Inspection
SSM 46948 - Effective Nov 29 2017
2016-2017 Various Vehicles - SYNC 3 - Mobile Device Inoperative Navigation Applications
SSM 46947 - Effective Nov 29 2017
2016-2017 Ford/Lincoln – SYNC 3 – Intermittent Display Of A Vehicle Image On SYNC Screen
SSM 46930 - Effective Nov 22 2017
2016-2018 Various Ford And Lincoln Vehicles - SYNC 3 Issues With Vehicle In Transport Mode
GSB G0000156 - Effective Nov 8 2017
Passive Anti Theft System (PATS) Key Programming
SSM 46900 - Effective Nov 2 2017
2009-2018 Various Vehicles - No Start - Illuminated MIL And Diagnostic Trouble Code (DTC) P161A After Powertrain Control Module (PCM) Replacement
GSB G0000154 - Effective Oct 18 2017
Multiple Vehicles - Touch Screen Warranty GSB
GSB G0000150 - Effective Sep 27 2017
Various Vehicles - Module Programming and Reprogramming Procedures
SSM 46834 - Effective Sep 21 2017
2016-2017 Various Vehicles - SYNC 3 - Intermittent Blue Or Black Screen
SSM 46816 - Effective Sep 13 2017
Multiple Vehicle Lines - 2017 Workshop Manual Service Procedures Being Updated.
GSB G0000149 - Effective Aug 23 2017
Engine Oil Maintenance Inspection
TSB 17-0062 - Effective Aug 23 2017
2000 And Newer Ford, Lincoln And Mercury Vehicles - Aluminum Panel Corrosion
SSM 46767 - Effective Aug 17 2017
2015-2017 Mustang – 3.7L/5.0L – 6R80 - Clunk/Ping Noise When Shifting From Park To Reverse And/Or Park To Drive Engagement
SSM 46727 - Effective Jul 31 2017
Setting Correct Tire Pressure
GSB G0000145 - Effective Jul 27 2017
Various 2013 and Newer Vehicles - Splice Block General Service Bulletin (GSB)
GSB G0000144 - Effective Jul 17 2017
12 Volt Battery Charging and Testing Quick Reference Guide-
GSB G0000142 - Effective Jun 29 2017
Multiple Vehicles - Wiring Repair / Harness Replacement - Best Practices for Warranty Claiming
GSB G0000141 - Effective Jun 29 2017
Multiple Vehicles - Front Controls Interface Module (FCIM) Warrantable VS Non-warrantable Conditions General Service Bulletin (GSB)
SSM 46620 - Effective May 23 2017
2016-2017 Multiple Vehicles - 2.0L/2.3L GTDI - Illuminated Malfunction Indicator Lamp (MIL) With Diagnostic Trouble Code (DTC) P0001
SSM 46571 - Effective May 4 2017
2016-2017 Various Ford And Lincoln - SYNC 3 And Navigation – SiriusXM Traffic Listing Not Loading - Software Update
GSB G0000136 - Effective May 3 2017
Adaptive Cruise Control & Collision Warning Radar Alignment Process
SSM 46559 - Effective May 3 2017
2016-2017 Various Ford And Lincoln - SYNC 3 And Navigation – Inaccurate GPS And Travel Link Fuel Prices Not Displaying - Software Update
TSB 17-2068 - Effective Apr 18 2017
2016-2017 Various Ford/Lincoln – SYNC 3 – No Rear View Camera Image At Freezing Ambient Temperatures - Built On 01-Jul-2015 And Through 31-Dec-2016
SSM 46486 - Effective Mar 23 2017
2016-2017 Various Ford And Lincoln Vehicles - SYNC 3 Issues With Vehicle In Transport Mode
GSB G0000129 - Effective Mar 14 2017
Multiple Vehicles - Leather/Vinyl Seat Cover General Service Bulletin (GSB)
SSM 46451 - Effective Mar 14 2017
2009-2017 Multiple Vehicles Equipped With 6R80,6R100,6R140 Automatic Transmission - Updated Workshop Manual (WSM) Main Control Valve Body Overhaul Procedure
GSB G0000130 - Effective Mar 14 2017
Multiple Vehicles- Interior Mirror General Service Bulletin (GSB)
GSB G0000126 - Effective Mar 6 2017
Multiple Vehicles - Instrument Panel Cluster Mask / Lens Warrantable Versus Non-Warrantable Conditions
GSB G0000125 - Effective Feb 27 2017
Multiple Vehicles- Body Interior Trim and Steering Wheel Damage vs. Defect General Service Bulletin (GSB)
TSB 17-0019 - Effective Feb 24 2017
2017 Mustang - 2.3L - Illuminated Malfunction Indicator Lamp (MIL) - Diagnostic Trouble Codes (DTCs) P0456, P1450 And/Or P144C Built On Or Before 13-Jan-2017
GSB G0000123 - Effective Feb 7 2017
Multiple Vehicles- Wiper Blade Warrantable Vs. Non-Warrantable General Service Bulletin (GSB)
SSM 46353 - Effective Jan 31 2017
2013-2017 Various Vehicles - Ambient Air Temperature Sensor (AAT) Pinpoint Test Update In Workshop Manual (WSM) Section 413-01
SSM 46332 - Effective Jan 24 2017
2008-2017 Various Ford/Lincoln/Mercury Vehicles - Replacing/Upgrading Original Equipment SYNC/Navigation System Components Is Not Supported
SSM 46295 - Effective Jan 10 2017
Multiple Vehicle Lines - Revised Engine Oil Leak Diagnostic Procedure Using New White Fluorescent Dye
SSM 46173 - Effective Nov 2 2016
Some 2016-2017 GT350 Mustangs Might Exhibit Piston Rattle From Idle To 3000 RPM
SSM 46132 - Effective Oct 17 2016
2008-2017 Ford/Mercury/Lincoln - Vehicle Health Report (VHR) Generates Service Required Message
SSM 46102 - Effective Sep 30 2016
Multiple Vehicles - Safety Belt Retractor Webbing Does Not Extract From Stowed Position Or Exhibits Excessive Pressure On The Occupant During Use.
GSB G0000108 - Effective Sep 23 2016
Multiple Vehicles- Paint Defects / Damage General Service Bulletin (GSB)
GSB G0000107 - Effective Aug 23 2016
Multiple Vehicles- Grille Defects / Damage General Service Bulletin (GSB)
TSB 16-0103 - Effective Aug 10 2016
2015-2017 Mustang - Manual Transmission - No Crank - Built On Or Before 6/15/2016
SSM 45938 - Effective Jul 18 2016
2015-2017 Mustang Driveline Vibration At Highway Speeds
SSM 45903 - Effective Jun 28 2016
2015-2017 Shelby GT350 And GT350R Brake Service
GSB G0000097 - Effective May 24 2016
SYNC 3 Intermittent Blank/Black Screen Diagnostic Tips & Flowchart General Service Bulletin (GSB)
GSB G0000094 - Effective Apr 29 2016
Multiple Vehicles - No PCM/Network Communication
GSB G0000092 - Effective Apr 5 2016
Multiple Vehicles- Exterior Mirror General Service Bulletin (GSB)
GSB G0000078 - Effective Jan 29 2016
Multiple Vehicles - Environmental Fallout Paint Damage General Service Bulletin (GSB)
GSB G0000076 - Effective Jan 27 2016
Multiple Vehicles- Exterior Lighting Condensation Warranty Coverage General Service Bulletin (GSB)
GSB G0000036 - Effective Nov 16 2015
Multiple Vehicles - Wheel Concern Analysis General Service Bulletin (GSB)
GSB G0000031 - Effective Oct 14 2015
Multiple Vehicles- Tape Stripe General Service Bulletin (GSB)
GSB G0000006 - Effective Aug 25 2015
Multiple Vehicles - Cloth Seat Cover General Service Bulletin (GSB)
De här vore intressanta att läsa:
