Hittade denne lenken;
http://www.mustangspecs.com/years/67.shtml
Production Numbers:
Standard Convertible: 38,751
Convertible w/Bench Seats: 1,209
Luxury Convertible: 4,848
Standard Coupe: 325,853
Coupe w/Bench Seats: 8,190
Luxury Coupe: 22,228
Standard Fastback: 53,651
Luxury Fastback: 17,391
Total: 472,121
Body Styles: Coupe, Convertible, Fastback
Construction: Unibody Chasis
Available Engines:
200cid 6cyl 1V 120hp
289cid 2V V-8 200hp
289cid 4V V-8 225hp
289cid 4V V-8 271hp
390cid 4V V-8 320hp
Available Exterior Colors
Acapulco Blue Arcadian Blue
Brittany Blue Burnt Amber
Candy Apple Red Clearwater Aqua
Dark Moss Green Diamond Blue
Diamond Green Dusk Rose
Frost Turquoise Lime Gold
Nightmist Blue Pebble Beige
Raven Black Sauterne Gold
Silver Frost Springtime Yellow
Vintage Burgundy Wimbeldon White
Anniversary Gold Aspen Gold
Blue Bonnet Bright Red
Columbine Blue Lavender
Playboy Pink Timberline Green
Vehicle Identification Numbers
Engine Codes
200cid 1V 6cyl 120hp U
289cid 2V V-8 200hp C
289cid 4V V-8 225hp A
289cid 4V V-8 271hp K
390cid 4V V-8 320hp S
7 - Last digit of model year
F - Assembly plant (F-Dearborn, R-San Jose T-Metuchen)
01 - Body code (01-Coupe, 03-Convertible, 02-Fastback)
C - Engine Code
100001 - Consecutive unit number
Example: 7F01C100001
Dimensions (1967 Fastback 302)
Wheelbase: 108 in.
Overall length: 183.6 in.
Width: 70.9 in.
Height: 51.8 in.
Shoulder room: 53.4 in.
Rear seat hip room: 40 in.
Door opening width: 42.2 in.
Floor to ground height: 9.7 in.
Capacities (1967 Fastback 302)
Luggage space, cu. ft.: 5.1
Fuel tank: 17.0 gal.
Crankcase: 4.0 qt.
Radiator coolant: 20.5 qt.
Wheels and Tires (1967 Fastback 302)
Wheel size: 14 x 6 JK
Optional size available: 14 x 5.5 JK
Bolt no./Circle diameter: 5/4.5 in.
Recommended inflation: 28/28 psi
Capacity rating, total lbs.: 4,950
1967 Mustang Weight ('67 Fastback 302)
Curb weight: 3,400 lbs.
Weight distribution, % f/r: 58,42
1967 Mustang Prices Retail
2dr Hardtop, 65A $2,461.46
Convertible, 76A 2,698.14
2+2 Fastback, 63A 2,592.17
289ci 200hp V-8 105.63
289ci 225hp V-8 158.48
289ci 271hp V-8 (with GT Equipment Group Only) 433.55
390ci 320hp V-8 263.71
Cruise-O-Matic automatic transmission, 6cyl 188.18
Cruise O-Matic automatic transmission, 200 or 225hp V-8 197.89
Cruise O-Matic automatic transmission, 271 or 320hp 220.17
4-speed manual transmission, 200 & 225hp V-8 184.02
4-speed manual transmission, 271 & 320hp V-8 233.18
Heavy-duty 3-speed manual, required with 320hp V-8 79.20
Power front disc brakes 64.77
Power steering 84.47
Power convertible top 52.95
GT Equipment Group (with V-8s only) 205.05
Limited slip differential 41.60
Styled steel wheels (2+2 only) 93.84
Styled steel wheels, all others 115.11
Competition handling package (with GT Equip. only) 388.53
Tinted windshield and window 30.25
Convenience Control Panel 39.50
Fingertip speed control (requires V-8 & Cruise-O-Matic) 71.30
Remote control outside mirror (std. 2+2) 9.58
Convertible safety glass rear window 32.44
SelectAire air conditioning 356.09
AM push-button radio 57.51
AM/FM push-button radio 133.65
Stereosonic tape system (AM radio required) 128.49
2+2 folding rear seat and access door (Sport Deck option) 64.77
Full width front seat (NA 2+2) 24.42
Tilt-away steering wheel 59.93
Rear deck luggage rack (2+2) 32.44
Comfortweave vinyl trim (NA convertible) 24.53
Center console (requires radio) 50.41
Deluxe steering wheel 31.52
Exterior decor group 38.86
Lower back panel grille 19.48
Interior Decor Group (convertible) 94.36
Interior Decor Group (all others) 108.06
Two-tone paint (lower back grille) 12.95
Accent paint stripe 13.90
Vinyl-covered roof (hardtop) 74.36
Wheel covers (std. 2+2) 21.34
Men det beror også på vilken karosstyp.
Les her; http://www.fomoco.com/forummain/thread.asp?ID=2811
Den mest ovanliga option for 67 var Fingertip speed control. (Cruise controll). Bare 55 bilar fikk den!
Hilsen
John
