comment_68035
Orginalt fanns det fargkoder på mange deler til din bil. Dom var der for att monterings arbetet skulle gå snabbare. lettare for gubbarna på monteringsbandet å se farger enn att dom skulle se delnummer;-)
Titta her;
http://429mustangcougarinfo.50megs.com/lz7.jpg
http://429mustangcougarinfo.50megs.com/trunk.htm
John
comment_68058
Vilka färger ska det var på en 71?
http://429mustangcougarinfo.50megs.com/ ... ver1aa.jpg
Om du klikker på lenken ovenfor og scroller lite ned hittar du bilder og "lite" info typ nedan.
John
Space Saver Spare
This is the space saver spare tire used on 71 Mustangs equipped the 60 series size tire (it's size was F78-14). It was also used if the Mustang came equipped with a fold down rear seat with the trap door that opened into the trunk. Note the correct '71 space saver spare will have one standard 1" rubber valve stem. In the mid 70's, Ford switched to a metal stem that had a built in pressure relief valve. If you have a metal one, the tire bead can be broken down on just the stem side and the valve stem swapped for a 1" rubber one. The space saver spare is a F78-14 B.F. Goodrich. Also, note the paint markings used for factory ID. Samples original to 429 Mustangs have Lavender and Tan paint ID marks as shown in the photos above right.
Special Valve Cap
This is the rare plastic valve cap used on all Space Saver spares. The cap incorporated a small screw driver like tool in it's tip that was used to un-screw the valves inner core so that the spare could be deflated and stored faster after using it. The Space Saver spare also used a short valve stem as shown above right.
comment_68078
Vart får man fram vilka färgpukter jag ska ha i min 351C?
Det finns en massa färg kombinationer eller?
Tack för otroligt snabba svar
Om du kan beretta hvilket reservhjul du har og hvilke hjul som satt på din bil orginalt så kansje.
Om din bil har samme reservhjul som oven, skal ditt reservhjul ha samme fargmerkning.
John
comment_68648
Hej John!
Har titta närmare på däcket och det är ett BF Goodrich 7.35-14
Orginal på bilen är det F60x15 WIDE OVAL BELTED BSW TIRES/RAISED WHITE LETTERS
Hejsan
Har frågat lite rundt og fått lite svar.
Not one to try and stir things up, but I believe a Spacesaver for a 1971 Mustang should be an F78-14 not a 7.35-14. Since you are looking for correct paint daub's I would also condsider getting the correct size Spacesaver as well.
F60-15's were optional on V-8 equipped 1971 Mustang's. When the F60-15 tire option was chosen you got the Spacesaver Spare. I have had many, many F60-15 equipped 1971 Mustang's and every one of them had an F78-14 Spacesaver spare.
og
Here is a picture of the back side of a space saver marked as you listed
Two Red daubs - sloppy
Hope it helps
Båda svaren er troligvis korekta då dom kommer från mycket kunniga personer.
Så om din bil har F60-15 dekk som orginal skal du ha spacesaver F78-14 og merkning som her;
Får att veta om din bil hade F60-15 som orginal, kolla din Marti raport. Har du inte en Marti raport, kjøpar du den her;
https://www.martiauto.com/secure/vinreports.cfm
John
comment_68654
Tack för svaren. Det ska vara F60x15 WIDE OVAL BELTED BSW TIRES/RAISED WHITE LETTERS enligt min Marti Report.
Får söka efter rätt däck nu F78-14 :cry:
Men varför denna mängd av olika färger på dessa prickar :?:
Tack John och tack din info kille i Väst.
