grufman
Allt skrivet av grufman
  1. AXLE TAG RATING TYPE V255D CLUSTER FIN ID 7R3V63044D70AGSMGN DSO SPEC. ORDER CD 71 EMISSION PROCESS ID 7R3A12A650AFF ENGINE TAG ID 7S253CA FUEL TANK 7R3V9K007BF INSTRUMENT CLUSTER ID 7R3V10849AC PAINT CODE U3 RADIATOR ID 7R3V8009BC STEERING ASSEMBLY ID 7R3V3200DD 6R333C529AB SUSPENSION REAR ID (LEFT) 7R3V5560KB TRANSMISSION TAG NO. 7R3V7003AJ TRIM COLOR W TRIM TYPE G VEHICLE DESCRIPTION FORD MUSTANG 2-DR SHELBY CONVE VEHICLE TYPE T89 WHEEL COVER TRIM 2M5V1A096AB WIRING 7R3V14A005SL WIRING 5R3T14631BA WIRING 6R3T14407ED WIRING 7R3T14401DF WIRING 7R3V14290EE WIRING COUNT 05
  2. (-) VERSION PACKAGES 18 X 9.5 ALLOY WHEEL 2007 JOB #1 PROGRAM CONTROL 4 WHEEL ANTI-LOCK BRAKING SYSTEM 50 STATE EMISSION REQUIREMENTS 7R3V-5560-KA LEFT REAR COIL 7R3V-5560-KA RIGHT REAR COIL ACCENT STRIPE - TUNGSTEN ANALOGUE AUDIO BROADCAST BLACK CLOTH COVER CDX6+ WITH SPEED SENSOR VOL CONTROL CENTRE HUB - VERSION A CONVERTIBLE BOOT-ROOF COVER ELECTROCHROMIC MIRROR WITH COMPASS FLATROCK ASSEMBLY PLANT - USA FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS FRONT LICENSE PLATE HOLDER DELUXE GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP I/P INSERT - TITANIUM FINISH INTERIOR UPGRADE PACKAGE B LESS AMBIENT TEMP/SPEED PACK LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BONNET SCOOP LESS CARGO NET - FIA LESS CONVENIENCE GROUP LESS DAYTIME RUNNING LAMPS LESS EXHAUST TIPS LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS FLOOR MATS-FIA LESS FUEL FILLER DOOR - FIA LESS FULL VEHICLE COVER LESS IMMERSION HEATER LESS REMOTE STARTER - FIA LESS SMOKERS PACKAGE LESS SPARE TYRE LESS SPARE WHEEL LESS SPECIAL BUILD REQUIREMENT LESS SPEED AUDIBLE WARNING DEVICE LESS TAPE STRIPES - FIA LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT MEDIUM DUTY BATTERY MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON LOCKING FUEL CAP WITH BP LABEL NORMAL FUEL FILL OWNER HAND BOOK PACK PERIMETER ALARM W/INTRUDER/SENSOR REAR AXLE LIMITED SLIP DIFFERENTIAL SPORTS FRONT SEAT STEERING WHEEL - 3 SPOKE LEATHER SVT RACING STRIPES U.S. SALES UNIQUE MET FINISH FOOT PEDALS PADS WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVER AIR BAG WITH DRIVERS POWER LUMBAR SUPPORT WITH ELECTRIC REAR WINDOWS WITH ENGLISH LANGUAGE LABEL WITH FLUSH SPOILER WITH INTERIOR PACK 2 WITH LOCKING WHEEL LUG NUT KIT WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH OVERSPEED WARNING DISABLED WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER AIR BAG WITH SIDE IMPACT PACKAGE WITH SUB WOOFER SOUND SYSTEM WITH SVE FRONT FOG LAMPS/AUX I/P WITH TYRE INFLATION KIT WITH UPSIZED FRONT STABILIZER BAR WITH UPSIZED REAR STABLIZER BAR
  3. Snabbinfo: I passagerarstolen sitter ett mycket avancerat system som avgör om airbagen skall vara avstängd, detonera med halvfart eller helfart. Om en lätt person sitter i passagerarstolen så stängs systemet av och lampan om avstängd passairbag tänds.
  4. ja, då har du ett större vacuumläck någonstans. kan vara svårt att hitta om det inte hörs. Slangar brukar höras, insugspackningar brukar inte höras. Absolut enklaste sättet att hitta en vacumläcka är med hjälp av en scanner och gasol 1) Anslut scannern i diagnosuttaget, ta fram parameterdata SHRTTRIM 1 och 2. Dom skall ligga på runt 0%, men kan i ditt fall, om du har läck, kanske ligga på 10-20%. 2) Ta fram slangen från gasolflaskan och vrid på ett lagom flöde. 3) "Begjut" olika delar med gasolen, insugspackningar, slangar, nipplar, ställen där det kan läcka. När SHRTTRIM 1 och 2 sjunker drastiskt, kanske till -20% så har du hittat läckan. 4) Stäng av gasflödet och bekräfta att parametern återgår till sitt ursprungliga läge, testa sedan igen och verifiera att shrttrim sjunker när du har gasol Lycka till
  5. 17 X 8" PAINTED ALUM W/MACH RIM 2006 JOB #1 PROGRAM CONTROL 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4550 LB. GVWR 4R33-5310-DA LEFT FRONT COIL 4R33-5310-DA RIGHT FRONT COIL 50 STATE EMISSION REQUIREMENTS 5R33-5560-FA LEFT REAR COIL 5R33-5560-FA RIGHT REAR COIL BASIC TYPE STEERING WHEEL CAMEL VINYL COVER CDX6+ WITH SPEED SENSOR VOL CONTROL FLATROCK ASSEMBLY PLANT - USA FLEET FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP I/P INSERT - BLACK LESS ACCT STRIPE-BDYSD COLOR LESS AMBIENT TEMP/SPEED PACK LESS ANTI-THEFT ALARM LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS EXTERIOR BODY MOULDINGS LESS IMMERSION HEATER LESS MESSAGE CENTRE LESS MILITARY VEHICLES LESS SIDE IMPACT PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPECIAL LANGUAGE LABEL LESS SPEED AUDIBLE WARNING DEVICE LESS TRIM PACK MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON LOCKING FUEL CAP WITH BP LABEL NORMAL FUEL FILL OWNER HAND BOOK PACK REAR AXLE LIMITED SLIP DIFFERENTIAL SPARE TYRE - T185/60R17 SPORTS FRONT SEAT STANDARD DUTY BATTERY U.S. SALES WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 4 GAUGE INSTRUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH BASE INTERIOR DECOR WITH CENTRE HUB ORNAMENT-FORD OVAL WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVER AIR BAG WITH DRIVERS POWER LUMBAR SUPPORT WITH DRIVERS POWER MIRROR WITH ELECTRIC REAR WINDOWS WITH FRONT FOG LAMPS WITH HEATED REAR WINDOW WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH ON-BOARD DIAGNOSTIC SYSTEM WITH OVERSPEED WARNING DISABLED WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER AIR BAG WITH PASSENGER POWER CONVEX MIRROR WITH SINGLE REAR WING SPOILER WITH SMOKERS PACKAGE WITH SUB WOOFER SOUND SYSTEM WITH UPSIZED FRONT STABILIZER BAR WITH UPSIZED REAR STABLIZER BAR
  6. om du har originallarm så sitter det i skuffen vänster sida bak. Du får lätta på klädseln bak till vänster så ska det sitta en datamodul där. Om du har den modulen så har du originallarm i bilen. Det är rätt ovanligt kan jag tillägga.
  7. (-) VERSION PACKAGES 18 X 8" WIDE SPOKE PNTD ALUM WHEEL BR33-5560-D* LEFT REAR COIL SPRING BR33-5560-D* RIGHT REAR COIL SPRING CENTER DOME LAMP W/O MAP LIGHT DRIVERS C/K POWER MIRROR ELECT PREM AM/FM STRO/DISC/CLOCK ELECTRO MIRROR WITH COMPASS AND MIC ENGINE COVER - UNDER HOOD FLATROCK ASSEMBLY PLANT - USA FLEET FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS FRONT SCUFF PLATES - ILLUMINATED GENERIC COUNTRY GROUP 1 I/P INSERT - METALLIC FINISH LEATHER WRAP WITH REDUNDANT CONTROL LESS ACCT STRIPE-BDYSD COLOR LESS ANTI-THEFT ALARM LESS APPEARANCE GROUP LESS BODYSIDE ACCENT STRIPE LESS CAMERA LESS CONVENIENCE GROUP LESS CONVERTIBLE ROOF COVER LESS DECKLID PANEL - FIA LESS FLOOR MATS-FIA LESS FRONT LICENSE PLATE BRACKET LESS FRONT LIP SPOILER - FIA LESS FUEL LABEL LESS FULL VEHICLE COVER LESS HOOD SCOOP - FIA LESS IMMERSION HEATER LESS INTERIOR PACK LESS PERFORMANCE PACK LESS PREMIUM BRAKES LESS REAR MUDFLAPS LESS REMOTE STARTER - FIA LESS REVERSE PROXIMITY SENSOR LESS SAFETY PACKAGE LESS SIDE SCOOP - FIA LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPECIAL EQUIPMENT PACKAGE LESS SPEED AUDIBLE WARNING DEVICE LESS SPOILER - FIA LESS SUN ROOF LESS TAPE STRIPES - FIA LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT LESS TYRE INFLATION KIT LESS WINDOW LOUVERS - FIA LIGHTING PACKAGE LEVEL A MUSTANG (2005/) OWNER HAND BOOK PACK PASSENGER POWER MIRROR PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SATELLITE DIGITAL BROADCAST SIDE AIR BAG - 1ST ROW ONLY SPARE TYRE - T185/55R18 SPORTS FRONT SEAT UNIQUE MET FINISH FOOT PEDALS PADS WITH 18" ALUMINIUM MINI SPARE WHEEL WITH 49 STATE/NON GREEN STATE REQ WITH 6 GAUGE INSTUMENT CLUSTER WITH AUTOMATIC HEADLAMP CONTROL WITH BODY COLOURED ROOF WITH CENTRE HUB ORNAMENT-FORD OVAL WITH DAYTIME RUNNING LAMPS WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVERS POWER LUMBAR SUPPORT WITH ENGLISH LANGUAGE LABEL WITH FIXED REAR SIDE WINDOW WITH FRONT 2 WAY HEADREST WITH FRONT FOG LAMPS WITH HALOGEN HEADLAMP WITH LEATHER HANDBRAKE GRIP WITH LEVEL 'A' INTERIOR DECOR WITH MEDIA GATEWAY MODULE WITH MEDIA GATEWAY PACKAGE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH PASS 2 WAY MANUAL SEAT ADJUST WITH ROLLED EXHAUST TIPS WITH SINGLE REAR WING SPOILER WITH SUB WOOFER SOUND SYSTEM WITH UNIVERSAL GARAGE DOOR OPENER
  8. (-) VERSION PACKAGES 18 X 9.5 ALLOY WHEEL 2007 JOB #1 PROGRAM CONTROL 4 WHEEL ANTI-LOCK BRAKING SYSTEM 50 STATE EMISSION REQUIREMENTS 7R3V-5560-LA LEFT REAR COIL 7R3V-5560-LA RIGHT REAR COIL ACCENT STRIPE - PERFORM WHITE CDX6+ WITH SPEED SENSOR VOL CONTROL CENTRE HUB - VERSION A ELECTROCHROMIC MIRROR WITH COMPASS FLATROCK ASSEMBLY PLANT - USA FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP HIGH PERFORMANCE AUDIO SYSTEM HOOD ACCENT STRIPE I/P INSERT - TITANIUM FINISH INTERIOR UPGRADE PACKAGE B LESS AMBIENT TEMP/SPEED PACK LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BONNET SCOOP LESS CARGO NET - FIA LESS CONVENIENCE GROUP LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS EXHAUST TIPS LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS FLOOR MATS-FIA LESS FRONT LICENSE PLATE BRACKET LESS FUEL FILLER DOOR - FIA LESS FULL VEHICLE COVER LESS IMMERSION HEATER LESS REMOTE STARTER - FIA LESS SMOKERS PACKAGE LESS SPARE TYRE LESS SPARE WHEEL LESS SPECIAL BUILD REQUIREMENT LESS SPEED AUDIBLE WARNING DEVICE LESS TAPE STRIPES - FIA LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT MEDIUM DUTY BATTERY MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON LOCKING FUEL CAP WITH BP LABEL NORMAL FUEL FILL OWNER HAND BOOK PACK PERIMETER ALARM W/INTRUDER/SENSOR REAR AXLE LIMITED SLIP DIFFERENTIAL SATELLITE DIGITAL BROADCAST SPORTS FRONT SEAT STEERING WHEEL - 3 SPOKE LEATHER SVT RACING STRIPES U.S. SALES UNIQUE MET FINISH FOOT PEDALS PADS WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVER AIR BAG WITH DRIVERS POWER LUMBAR SUPPORT WITH ENGLISH LANGUAGE LABEL WITH FIXED REAR SIDE WINDOW WITH FLUSH SPOILER WITH INTERIOR PACK 2 WITH LOCKING WHEEL LUG NUT KIT WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH OVERSPEED WARNING DISABLED WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER AIR BAG WITH REAR HEAVY DUTY STABILIZER BAR WITH SIDE IMPACT PACKAGE WITH SVE FRONT FOG LAMPS/AUX I/P WITH TYRE INFLATION KIT WITH UPSIZED FRONT STABLIZER BAR 2
  9. Grabbar. Ni måste läsa instruktionsboken för era bilar. Det står saker som är bra att veta där.
  10. det är så man gör, säkerställer att den rör sig. Om det sedan blir bättre så beställer man en ny. Har den blivit dålig, men funkar hjälpligt efter rengöring är den ändå slut. Rengöringen gör man för att säkerställa att man felsökt på rätt ställe, rengöringen kan aldrig reparera en tomgångsmotor. Effekten kvarstår högst någon timma.
  11. Bernsson USA-bilar. Räcker dock inte med att demontera elektriskt. Du måste plugga kontakten från bilen, annars får du felkoder. Behövs specialverktyg. I övrigt kan dock nämnas att i stolen sitter ett synnerligen sofistikerat system för att känna av om det sitter någon i stolen eller ej. Lampan tänds när systemet är deaktiverat. Läs manualen. Där står allt du behöver veta.
  12. Vore roligt att höra lite vad folk lirar för instrument när man inte är ute och rattar med sin musse alltså. Själv lirar jag lite elbas, 5-strängad ibanez sedan typ 5-6 år tillbaka, plinkar när lusten faller på, vilket brukar bli ungefär en halvtimme per dag, inte allt för avancerat ännu dock. Nyligen skaffat en Yamaha altsax som jag tänkte försöka lära mig lira. Lektion med proffs inbokad näst vecka. Någon annan som lirar några roliga instrument? Vilka musikstilar lirar ni? Jazz, rock, blues, folk, pop?
  13. demontera och gör rent. den har fastnat
  14. grufman replied to hammarby's topic in Mustang 1994-2004
    Där ser man även bakre utloppet uppe till vänster på insugen. Dom piparna brukar spricka.
  15. grufman replied to hammarby's topic in Mustang 1994-2004
    Detta borde väl räcka som förklaring
  16. grufman replied to hammarby's topic in Mustang 1994-2004
    Från 1996-2002 användes plastinsug med främre kylkanalen i plast när man upptäckte att duponts glasfiberarmerade nylonplast inte klarade värmen bytte man främre kanalen till alu. Det löste de flesta problemen. På bilar som rullar långt är det fortfarande rätt vanligt att bakre varmvattenutloppet spricker, och det är i plast oavsett vilket du väljer. då ska du dock köra 15-20.000 mil innan det blir problem.
  17. Alternativt kolla om det finns några uppenbara vacuumläckor. säger 70% tomgångsmotot, 30% vacuumläcka.
  18. Byt tomgångsmotorn
  19. Om du är skriven i sverige får du inte framföra en utländskt reggad bil längre tid än en vecka. Bilen måste ha en giltig trafikförsäkring. sannolikt innebär det att du måste lösa en svensk försäkring. Om du har din hemvist i usa så får du köra bilen i sverige utan några större begränsningar. Kolla dock att den amerikanska försäkringen gäller här. Det enklaste kan vara att göra en tillfällig registrering om bilen ska ut ur landet sen.
  20. Om du importerar som privatperson har jag svårt att se hur man skulle kunna få tillbaka moms. Du får berätta mer
  21. Den va stilig. Snäll chef du har ???
  22. i Ford racing satsen sitter ett vanligt pappersfilter. Brukar kosta ca 300kr, och kan inte tvättas.
  23. (-) VERSION PACKAGES 8.5 X 19" PAINTED ALUMINIUM WHEEL BR33-5560-D* LEFT REAR COIL SPRING BR33-5560-D* RIGHT REAR COIL SPRING CENTER DOME LAMP W/O MAP LIGHT CENTRE HUB ORN - PONY LOGO/SPINNER DRIVERS C/K POWER MIRROR ELECT PREM AM/FM STRO/DISC/CLOCK ELECTRO MIRROR WITH COMPASS AND MIC ENGINE COVER - UNDER HOOD FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS FRONT SCUFF PLATES - ILLUMINATED GENERIC COUNTRY GROUP 1 I/P INSERT - METALLIC FINISH LEATHER WRAP WITH REDUNDANT CONTROL LESS ACCT STRIPE-BDYSD COLOR LESS ANTI-THEFT ALARM LESS APPEARANCE GROUP LESS BODYSIDE ACCENT STRIPE LESS CAMERA LESS CONVENIENCE GROUP LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS DECKLID PANEL - FIA LESS FLEET LESS FLOOR MATS-FIA LESS FRONT LICENSE PLATE BRACKET LESS FRONT LIP SPOILER - FIA LESS FUEL LABEL LESS FULL VEHICLE COVER LESS HOOD SCOOP - FIA LESS IMMERSION HEATER LESS INTERIOR PACK LESS PERFORMANCE PACK LESS PREMIUM BRAKES LESS REAR MUDFLAPS LESS REMOTE STARTER - FIA LESS REVERSE PROXIMITY SENSOR LESS SAFETY PACKAGE LESS SIDE SCOOP - FIA LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPECIAL EQUIPMENT PACKAGE LESS SPEED AUDIBLE WARNING DEVICE LESS SPOILER - FIA LESS SUN ROOF LESS TAPE STRIPES - FIA LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT LESS TYRE INFLATION KIT LESS WINDOW LOUVERS - FIA LIGHTING PACKAGE LEVEL A MUSTANG (2005/) NORMAL FUEL FILL OWNER HAND BOOK PACK PASSENGER POWER MIRROR PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SATELLITE DIGITAL BROADCAST SIDE AIR BAG - 1ST ROW ONLY SPARE TYRE - T185/55R18 SPORTS FRONT SEAT UNIQUE MET FINISH FOOT PEDALS PADS WITH 18" ALUMINIUM MINI SPARE WHEEL WITH 49 STATE/NON GREEN STATE REQ WITH 6 GAUGE INSTUMENT CLUSTER WITH AUTOMATIC HEADLAMP CONTROL WITH BODY COLOURED ROOF WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVERS POWER LUMBAR SUPPORT WITH ENGLISH LANGUAGE LABEL WITH FIXED REAR SIDE WINDOW WITH FRONT 2 WAY HEADREST WITH FRONT FOG LAMPS WITH HALOGEN HEADLAMP WITH LEATHER HANDBRAKE GRIP WITH LEVEL 'A' INTERIOR DECOR WITH MEDIA GATEWAY MODULE WITH MEDIA GATEWAY PACKAGE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH PASS 2 WAY MANUAL SEAT ADJUST WITH ROLLED EXHAUST TIPS WITH SINGLE REAR WING SPOILER WITH SUB WOOFER SOUND SYSTEM WITH UNIVERSAL GARAGE DOOR OPENER
  24. (-) VERSION PACKAGES 18" X 8.5 POLISHED ALUMINIUM WHEEL 2007 JOB #1 PROGRAM CONTROL 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4450 LB. GVW 4R33 5310 GA LEFT FRONT COIL 4R33-5310-GA RIGHT FRONT COIL 5R33-5560-CA LEFT REAR COIL 5R33-5560-CA RIGHT REAR COIL ANALOGUE AUDIO BROADCAST CDX6+ WITH SPEED SENSOR VOL CONTROL CENTRE HUB ORN - PONY LOGO/SPINNER FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP HIGH PERFORMANCE AUDIO SYSTEM I/P INSERT - RIBBED ALUMINIUM LEATHER WRAP/SATIN ALUM SPOKE WHEEL LESS ACCT STRIPE-BDYSD COLOR LESS AMBIENT TEMP/SPEED PACK LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS BONNET SCOOP LESS CONVENIENCE GROUP LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS EXHAUST TIPS LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS FLOOR MATS-FIA LESS FRONT LICENSE PLATE BRACKET LESS FULL VEHICLE COVER LESS IMMERSION HEATER LESS INTERIOR PACK LESS SIDE IMPACT PACKAGE LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPEED AUDIBLE WARNING DEVICE LESS TAPE STRIPES - FIA LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT LESS TYRE INFLATION KIT MEDIUM DUTY BATTERY MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON LOCKING FUEL CAP WITH BP LABEL NORMAL FUEL FILL OWNER HAND BOOK PACK PERIMETER ALARM W/INTRUDER/SENSOR PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SPARE TYRE - T185/60R17 SPORTS FRONT SEAT STANDARD FOOT PEDAL PAD DESIGN U.S. SALES WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH CALIFORNIA/GREEN STATE REQ WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVER AIR BAG WITH DRIVERS POWER LUMBAR SUPPORT WITH ENGLISH LANGUAGE LABEL WITH FIXED REAR SIDE WINDOW WITH FRONT FOG LAMPS WITH LEVEL 'A' INTERIOR DECOR WITH LOCKING WHEEL LUG NUT KIT WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH OVERSPEED WARNING DISABLED WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER AIR BAG WITH PRISMATIC MIRROR WITH SINGLE REAR WING SPOILER WITH UPSIZED FRONT STABILIZER BAR WITH UPSIZED REAR STABLIZER BAR
