comment_9780
Hej, kollade nr på mina toppar som är C9VE-A och hittade följande:
429CJ
SCJ
Police 70-71
DOAE-H
C9VE-A
chamber 73.5
valves i 2.24/ e 1.725
SCJ/early CJ have adjustable stamped rockers with guide plates and screw-in studs.
nån som vill vara vänlig och förklara? för det är väl inga cj toppar?
Mvh Adrian
comment_9786
D0VE-A & C Heads Are One-And-The-Same.
September 6 2004 at 3:40 PM
No score for this post
Paul Kane (Login PaulKane)
from IP address 165.247.212.75
Response to Question about heads: D0VE-C vs. D0VE-A
...albeit an irrelevant engineering revision. They are interchangable.
The Thermactor emissions system was part of the smog pump's emissons control system and indeed shot air into the exhaust ports via the drilled smog bumps.
Some D0VE's have the thermactor holes drilled into the smog bumps and some do not; this is one of the reasons I prefer C9VE and C8VE heads over the D0VE heads (they are never drilled).
ScottJ may provide a link to plugging the passages; kicking down the one-time fee for access to his site is worth way more than the fee itself.
Paul
It's all about thrust...
