Corvette July 29, 2016 Report July 29, 2016 Köp amerikanska så slipper du såga sönder originalen [emoji6] Skickat från min iPhone med Tapatalk Citera
Martin Bäckström August 9, 2016 Report August 9, 2016 Corvette: Jag fattar inte svaret,, tycker du att man bör köpa kompletta USA lysen som innehåller LED:s från fabrik istf att värma och dela de lampor som finns? Finns någon kabel framdragen för att koppla in spänning på lamporna? Martin 1 Citera
Nugatti August 16, 2016 Report August 16, 2016 On 8/9/2016 at 15:16, Martin Bäckström said: Corvette: Jag fattar inte svaret,, tycker du att man bör köpa kompletta USA lysen som innehåller LED:s från fabrik istf att värma och dela de lampor som finns? Finns någon kabel framdragen för att koppla in spänning på lamporna? Martin Jag undrar också detta. Fattar at dom är DOT godkända och inte EU godkända. Men är det annars samma tillkoppling? Kanskje behövs det en omprogrammering? http://www.americanmuscle.com/ford-headlight-pair-2015.html Citera
zolife September 9, 2016 Report September 9, 2016 Hi, this issue is also buzzing me. Why those led lamps are not working on the EU version?! I've found and article which says this: "Don't meet EU regulations, sadly. So they had to be nixed. Something about aspect angle and height which was outside tolerances, nothing Ford could do, it's a mandate from the EU that they must be permanently switched off." But if you import the car form the US it is fine i guess... so hopefully there is some solution. I've asked the service and they said the lamps are in the headlight module but it is disabled by the software. I'm not sure about it because I didn't get a straight answer, they said they have to look after it first. So I'm not sure if you order a new headlamp from the US it will solve this problem. There is a polish company who modding the light system but they're way much more expensive that the US version and I'm not sure those modifications are legal in the EU. http://hd-customs.pl/american-muscle/am-lights/am-lights-mustang-2015/ It would be really good to have someones experience about this theme, what is the best way to go. Citera
Foose September 10, 2016 Report September 10, 2016 Det finns inga ledlampor i eu lamporna, det finns heller ingen strömmatning till dem så det fungerar inte om man köper ett par amerikanska lyktor, dessutom är begagnade amerikanska lyktor väldigt dyra. Vill man ha tribars finns det i princip två vägar att lösa det på, det ena är att skicka dem till polen och få dem modifierade och det andra är att öppna dem själv och montera exempelvis dioder från diod dynamics. Man behöver dock fixa lite med kablarna för att det ska fungera, original har våra bilar DRL via en lampa i dimljuset, på kvällen släcks den och halvljuset tänds, man får fundera hur de ska lysa och mustangen är ganska enkel när det gäller elen så det går att lösa. Mitt tips är dock att köra på Polen, då kan man även få blinkers i tribar och annat kul. Det hade jag valt om jag skulle göra denna modifikation. Och inget av det jag skrivit ovan är godkänt. Citera
Martin Bäckström November 8, 2016 Report November 8, 2016 http://www.cjponyparts.com/switchback-daytime-running-light-led-sequential-board-kit-asia-eu-spec-2015-2017/p/DRLLED10/ Switchback Daytime Running Light LED Sequential Board Kit Asia/EU-Spec 2015-2017 Som synes har dessa DRL lampor kommit för EU specade bilar. Eftersom de visar vitt framåt, och använder den vanliga blinkersen så kanske, kanske de är lite lagliga? Snyggt, eller hur? Martin 2 Citera
Henrik_B November 8, 2016 Report November 8, 2016 (redigerad) Enligt andra trådar här ska det ju vara lagligt med dynamiska blinkers om själva blinktiden är mindre än två sekunder. Ändrade %s av %s (%s) Citera
Junkers November 8, 2016 Report November 8, 2016 Det olagliga är väl att DRL lyser för kraftigt åt sidan. Citera
zolife November 8, 2016 Report November 8, 2016 well, I'm wondering how serious is this legal issue... will the police stop me or just get a notification when the car get the first official inspection? :) I guess there are ways to modify the light intensity if it is too strong and with combine with the original DRL light in the foglights they can not say anything about it... I hope at least. I really miss this features from the EU mustang and seriously thinking to get this package, but haven't found any information about the installation yet. I can put the lamps in but I'm afraid from the wiring unless if they have a good instruction for it. Citera
badass December 18, 2016 Report December 18, 2016 jag får mitt kit ifrån diode dynamics nästa vecka som jag tänkte installera själv. har öppnat lyktor förut och limmat igen och det har aldrig varit några problem innan. man får med en dosa till diode dynamics så man kan kontrollera hur det ska lysa utifrån den och kitet behöver i sig bara lite ström för att funka. Citera
Norwall December 23, 2016 Report December 23, 2016 Jag har monterat ett kit från Diode Dynamics. .... Det är inte riktigt lika lätt som det verkar i videon. Det tar ett bra tag att ta sig in i lamporna men att montera led-listerna är inga bekymmer. Har inte krånglat med att koppla blinkers eller dylikt än, mest på grund av lathet... Vi får se till nästa sommar om det är åtgärdat. Citera
Tomas &Annika August 18, 2019 Report August 18, 2019 On 2016-12-18 at 14:30, badass said: jag får mitt kit ifrån diode dynamics nästa vecka som jag tänkte installera själv. har öppnat lyktor förut och limmat igen och det har aldrig varit några problem innan. man får med en dosa till diode dynamics så man kan kontrollera hur det ska lysa utifrån den och kitet behöver i sig bara lite ström för att funka. Har du några tips för att ta sig in i strålkastarna ? Jag har sett både varmluftpistol och dom som som lägger i ugnen 250 grade 10-15 min , Citera
Gunnar Flyberg August 22, 2019 Report August 22, 2019 Fick tipset av Anders i Emmaboda. Fanns på ebay och tog någon vecka innan de kom. Kostade 22 pund. Kommer från England så ingen tull eller moms. Lite knöligt att få dit dem (först måste kontakten dras utåt, sedan vrider man själva lamphållaren moturs). Första lampan tog nog en halvtimma, den andra tio minuter... Man får ta bort tre plasthållare på varje sida, men man behöver inte ta bort hjulet - bara vrida det fullt åt sidan. Här är länken: https://www.ebay.co.uk/itm/P13W-CREE-LED-Ford-Mustang-Daytime-Running-Lights-Bulbs-Canbus-DRL-Xenon/253741372927?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D57477%26meid%3D61ab7dd98ab54bbabffe4acdc107d82e%26pid%3D100005%26rk%3D4%26rkt%3D12%26sd%3D253249329494%26itm%3D253741372927%26pg%3D2047675&_trksid=p2047675.c100005.m1851#vi-ilComp Citera
PelleC August 22, 2019 Report August 22, 2019 Vill ni ha snygga DRL och inte sätta dit stavar, så rekommenderar jag Fords egna dimljus DRL som ser ut som "angel eyes" ringar! Jag har dessa på min bil och är helnöjd. Citera
Junkers August 22, 2019 Report August 22, 2019 Äh byt till 2018+ Bytte ju bara för lamporna... eller inte Citera
