comment_169298
Hej,
Har problem med min ena bakre sidoruta (passagerarsidan) den vill inte gå ända upp utan stannar ca 1 till 2 cm innan. Alltså får jag en liten irriterande glipa mellan den och rutan i dörren. Detta är en GT Cab årsmodell 2007, finns det någon här som vet hur man gör för att justera detta?
comment_169383
The rear quarter windows are operated by a single window switch
located at the driver door window controls. Press and pull the window
switch to open and close the windows.
• Press down and hold the switch to open.
• Pull up and hold the switch to close.
Rear power windows manual override (convertible only)
The rear quarter window switch will not operate under the following
conditions:
• Convertible top is moving
• Convertible top is not completely up or down
In the event that the rear quarter window switch does not operate when
the convertible top is completely up or down, the rear quarter windows
can be manually raised up.
The following procedure must be performed within two minutes:
1. Turn the ignition key to the off position, then turn back to the on
position.
2. Press the rear window switch down three times.
comment_169385
conditions:
position.
tackar för tipset återkommer med resultatet när jag har testat 🙂
