Special Tool(s) / General Equipment
Wheel Alignment System
Adjustment
NOTICE: Suspension fasteners are critical parts that affect the performance of vital components and systems. Failure of these fasteners may result in major service expense. Use the same or equivalent parts if replacement is necessary. Do not use a replacement part of lesser quality or substitute design. Tighten fasteners as specified.
Using alignment equipment and the manufacturer's instructions, measure the front camber.
Use the General Equipment: Wheel Alignment System
Remove the wheels and tires.
Refer to: Wheel and Tire (204-04A Wheels and Tires, General Procedures).
On both sides.
Unclip and position aside the wheel speed sensor harness.
On both sides.
Remove and discard the strut-to-spindle bolts and nuts.
NOTE: Support the wheel spindle using mechanic's wire.
Note the orientation of the strut-to-spindle bolts and flag nuts, then remove and discard the bolts and flag nuts.
Using a suitable grinding tool, enlarge the strut-to-wheel spindle upper mounting hole as indicated.
Remove any burrs.
Clean and paint any exposed metal.
NOTE: Do not fully tighten the strut-to-spindle bolts and nuts until the alignment has been corrected.
NOTE: Original equipment bolts are splined, service bolts are smooth and smaller in diameter.
On both sides.
Position the wheel spindle and install the 2 new service strut-to-spindle bolts and nuts and tighten until snug.
On both sides.
Position the wheel speed sensor harness.
Install the wheels and tires.
On both sides.
Tighten the strut-to-spindle bolts and nuts.
Torque: 184 lb.ft (250 Nm)
Recheck alignment to verify camber change and adjust front toe if necessary.
Refer to: Front Toe Adjustment (204-00 Suspension System - General Information, General Procedures).
Adjustment
NOTE: Make sure that the vehicle is standing on a level surface.
Steering wheel in straight ahead position.
Using alignment equipment and the manufacturer's instructions, check the front toe setting on both sides.
On both sides.
Loosen the outer tie rod end jamb nut.
Torque: 76 lb.ft (103 Nm)
On both sides.
Position aside the steering gear boot clamp.
NOTE: Do not allow the steering gear bellows to twist when the inner tie rod is rotated.
On both sides.
Rotate the inner tie rods until the toe reading is within specifications.
Recheck the toe settings and adjust as necessary.
Adjustment
Using alignment equipment and the manufacturer's instructions, measure the rear camber.
Loosen the upper control arm inboard nut approximately 2 turns, and slide the upper control arm inboard or outboard to adjust the rear camber.
Torque: 85 lb.ft (115 Nm)
Recheck alignment to verify camber change and adjust rear toe if necessary.
Refer to: Rear Toe Adjustment (204-00 Suspension System - General Information, General Procedures).
Adjustment
Using a holding device, hold the steering wheel in the straight-ahead position.
Using alignment equipment and the manufacturer's instructions, check the rear toe setting on both sides.
NOTE: Make sure that the toe settings are not disturbed while tightening the nuts.
Loosen the toe link nut approximately one full turn.
Torque: 129 lb.ft (175 Nm)
Rotate the toe link bolt to achieve the specified toe setting.
Recheck the rear toe settings and adjust as necessary.
