May 10, 201311 yr comment_127168 Hej!Behöver hjälp! Vet inte riktigt vilket mått som gäller när det gäller inställning av flottörnivån, har två olika mått. Har en -65 med 289 motor samt en Autolite 2100 förgasare. Behöver måttet i mm om det går och inställningen gäller med torr/blöt förgasare.Tack på förhand /Stefan
May 10, 201311 yr comment_127171 http://www.ford-trucks.com/forums/805813-autolite-2100-float-setting-dry-vs-wet.htmlEtt snabbt sök på google gav mig detta. Texten nedan är hämtad från länken ovan :-)"The dry setting is 29/64...it says measurement is taken 'from the machined surface of the main body to the top of the free end of the float, with the float in the uppermost position.'wet is 29/32ndsAs to how to do the wet it says to run it for a half hour to get engine up to temp...they call it normalize.....say to run it @ 1200 rpm...pull the top off of it. It then says to temporarily put the air horn gskt in positionand start the truck, let it run at idle for a few minutes then shut it off. Then take the gskt off.Next it says that with engine idling use a std depth scale to measure the vertical distance from top machined surface of the carb body to level of fuel in bowl. It says any measurement must be taken at least 1/4 inch from any vertical surface. Thats all it says aside from how and where to actually bend float tab if needed. it says truck needs to be run for 3 min. after each adjustment is made. When all is hunky dorey put the top back on and so on...When I did mine, I initially put a new float in and had issues..things werent quite right as far as how things lined up...anyway, I ended up reusing my OE brass float and put back together and all is well in regards to the fuel issue I was having. On the front left ear on the side there will be a code...like a C5TF-B or similar...in 65 there was 3 different carbs used on the 4 speed trucks...The above is all from the 65 shop manual as to how to measure the fule level and so on..."
May 11, 201311 yr Author comment_127211 Ok tack men det jag inte blir klok på är att det är olika mått i olika manualer, har bla kollat i haynes och den du hänvisar till ovan och det finns minst två mått som det pratas om. 7/16=11,1mm 29/64=11,5mm +- 0,4mm "torr". Om det är någon som gjort detta så är jag evigt tacksam om ni har någon rekommendation
May 11, 201311 yr comment_127224 Utan att till 100% veta så är väl "Shop manual" Fords egna verkstadsmanual, vilket borde borga för att det är trovärdiga värden. Bara en tanke från min sida :-)
May 11, 201311 yr comment_127225 Hej. Justera nivån med att hålla upp flottören med fingret (lätt) så att nålventilen stänger. 11.1 mm är lite marigt att justera, 11mm är lättare samt 11.5mm, det är inget svårt med torrinställning, jag är säker på att du fixar det.
May 14, 201311 yr Author comment_127319 Hej och tack för era svar. Problemet är att jag inte hittar igen min förgasare och dess inställningar (om det nu inte är standardmått som gäller på alla 2100 förgasare). Nåväl jag har en förgasare som heter Motorcraft 2100 som är märkt 3ZF A. 1.21 (Venturi). Det jag undrar över är alltså vilken flottörnivå som gäller för denna förgasare i torrt och blött tillstånd (har inga problem med själva jobbet att justera den sedan).Stefan
May 15, 201311 yr comment_127354 Hej,hittade min gaml "lapp" från renoveringssatsen av en 2100. Skillnaden i flottörens nivå kan möjligen ha med vilken modell förgasaren sitter i, men om vi tänker oss att din är en 73:a (3ZF) så gäller 7/16 för ala 32100 from 70 och upp till 74 (så långt listan går). Det är ju rätt stora venturis så den kan ju komma från en truck och då är det antingen 7/16 eller 1/2" som gäller (de festa har 7/16)/Claes
May 15, 201311 yr Author comment_127389 Hej,hittade min gaml "lapp" från renoveringssatsen av en 2100. Skillnaden i flottörens nivå kan möjligen ha med vilken modell förgasaren sitter i, men om vi tänker oss att din är en 73:a (3ZF) så gäller 7/16 för ala 32100 from 70 och upp till 74 (så långt listan går). Det är ju rätt stora venturis så den kan ju komma från en truck och då är det antingen 7/16 eller 1/2" som gäller (de festa har 7/16)/ClaesTackar för detta Claes, ska gensast sätta igång och justera gasaren
