comment_168295
Topplocken fick ny konstruktion runt 2008. Är inte helt hundra på när. Tidiga modeller har speciella tändstift som är rätt långa. De kan brännas fast i toppen och gå av vid demontering. Men med rätt metod är det inget problem att byta dem på en tidig musse. Vilket jag själv har, men har inte haft några problem med det 🙂
comment_168308
NOTE: 2005-2010 GT Spark Plug Removal
The Ford 3 valve modular motors utilized a unique 2 piece style spark plug which has caused issues when removing the plugs from a high mileage vehicle as they are prone to cracking. The plugs look like this:
Used 2005-2010 GT Mustang Spark Plug Set
115K miles on 2006 GT Spark Plugs
Tools required: Ratchet with various sockets, spark plug socket, torque wrench set to 33 lb-ft, 10 inch extension, PB Blaster, air compressor with blow gun attachment
Step 1: Make sure the engine is COLD. Let it sit overnight if need be. Some people argue the engine should be warm, but when it's warm the aluminum of the head expands and makes the hole the plug sits in tighter. In a cold engine situation the aluminum has not made the hole tighter and the metal threats on the plug have not expanded either.
Step 2: Remove all plugs and ignition coils to access the spark plugs. Once removed take the blow gun and blow the debris out of the holes.
Step 3: Use your torque wrench with the extension and spark plug socket and try the plugs. DO NOT TORQUE THE PLUGS OVER 33 FT LB AND GO VERY SLOWLY. DO NOT USE AN IMPACT. If it will move, move the plug about 1/8-1/4 turn and stop. With luck, one or two of the plugs will come loose completely and you can remove it.
Step 4: In the holes that still have the plugs in them, whether they were able to be partially turned or not, pour some PB Blaster, Seafoam deep creep, or some other penetrating fluid and let the plugs sit for 15-30 minutes.
Step 5: After waiting tighten the plugs back while not torquing over 33 ft lbs and then try loosening again. Repeat this process with stubborn plugs until they come out. DO NOT TRY AND FORCE A PLUG, IT WILL CRACK!
Step 6: Apply dielectric grease to top of plug and anti-seize to the threads if you want and reinstall plugs, again not torquing over 33 ft-lbs. Reinstall ignition coils and plug everything back in.
comment_168312
Tändstiftsproblemet är inte så allvarligt  kan jag tycka, trots allt väldigt få som råkar ut för det och det finns en lösning  om det händer och som jag sett finns det dessutom nya stift i ett stycke som inte delar sig.  Motorerna sitter ju i ett antal miljoner bilar. Sen är det ju alltid så med alla produkter och  även bilar, dom sista årsmodellerna av en modell har de flesta barnsjukdomar fixade på fabriken. Det finns tyvärr omvända exempel också, där man i besparingsivern försämrat saker på senare modeller. Känner dock inte till något sådant på dessa Mustanger.  Jag skulle inte vara speciellt orolig för dom tidigare heller,  sett till hur många av dom tidigare som rullar och körs utan problem så skulle jag säga att det är bra skit generellt.  Skick, service, utrustning och look efter egen smak  är mer avgörande. Allt är en prisfråga i slutänden, ju nyare , ju färre mil  och mindre slitage och åldrande. En sen 09 må vara det det bästa, men dom är få.
