comment_175997
Linjerna finns på euro 2017. De kanske inte fanns på -15 och -16? Från 2017 uppdaterades det till Sync 3 (syns utanpå på GPS pucken ovanför bakrutan) och en del extrafinesser tillkom. För USA bilar kan Sync 3 kanske tillkommit tidigare.
En möjlighet är att man uppdaterat programvaran men att den tidigare hårdvaran inte klarar alla funktioner (?).
comment_175998
då har du två möjligheter
Manual Zoom
When manual zoom is on, the full area behind your vehicle does not show. Be aware of your surroundings when using the manual zoom feature.
Note: Manual zoom is only available when the transmission is in reverse (R).
Note: When manual zoom is enabled, only the centerline is shown.
Selectable settings for this feature are Zoom in (+) and Zoom out (-). Press the symbol in the camera screen to change the view. The default setting is Zoom OFF.
This feature allows you to get a closer view of an object behind your vehicle. The zoomed image keeps the bumper in the image to provide a reference. The zoom is only active while the transmission is in reverse (R). When the transmission shifts out of reverse (R), the feature automatically turns off and must be reset when it is used again.
Eller:
I had this issue a year ago. Take the car to the dealership. Software change is implemented. Problem resolved. Mine lines disappeared & the camera was in zoom mode only. I did all the things prior to dealership including , battery reconnect. Warranty issue Ford
comment_176018
Jag hade linjer i backkameran för min fd Mustang  -16.
