June 5, 20169 yr Author comment_151374 On 2016-05-05 at 10:07, Daan said: Hej, CYE 360 Tack på förhand //Dan (-) VERSION PACKAGES 17 X 8" PAINTED ALUM W/MACH RIM 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4R33-5310-DA LEFT FRONT COIL 4R33-5310-DA RIGHT FRONT COIL 5R33-5560-GA LEFT REAR COIL 5R33-5560-GA RIGHT REAR COIL CAMEL VINYL COVER CDX6+ WITH SPEED SENSOR VOL CONTROL CONVERTIBLE BOOT-ROOF COVER ELECTROCHROMIC MIRROR WITH COMPASS ENGINE COVER - UNDER HOOD FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT COMFORT PACKAGE C2 FRONT FLOOR CARPET MATS FRONT SCUFF PLATES - WITH INSERT GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP HIGH PERFORMANCE AUDIO SYSTEM I/P INSERT - RIBBED ALUMINIUM LEATHER WRAP/SATIN ALUM SPOKE WHEEL LESS ACCT STRIPE-BDYSD COLOR LESS AMBIENT TEMP/SPEED PACK LESS ANTI-THEFT ALARM LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS CARGO NET - FIA LESS DAYTIME RUNNING LAMPS LESS EXTERIOR APPEARANCE PACK LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS FLOOR MATS-FIA LESS FRONT LICENSE PLATE BRACKET LESS FULL VEHICLE COVER LESS IMMERSION HEATER LESS LIGHTING PACKAGES LESS REMOTE STARTER - FIA LESS SAFETY PACKAGE LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPEED AUDIBLE WARNING DEVICE LESS TAPE STRIPES - FIA LESS TYRE INFLATION KIT MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON LOCKING FUEL CAP WITH BP LABEL NORMAL FUEL FILL OWNER HAND BOOK PACK PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SATELLITE DIGITAL BROADCAST SPARE TYRE - T185/60R17 SPORTS FRONT SEAT UNIQUE MET FINISH FOOT PEDALS PADS WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH BONNET SCOOP WITH CALIFORNIA/GREEN STATE REQ WITH CENTRE HUB ORNAMENT-FORD OVAL WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVER AIR BAG WITH DRIVERS HEATED SEAT WITH DRIVERS POWER LUMBAR SUPPORT WITH ELECTRIC REAR WINDOWS WITH ENGLISH LANGUAGE LABEL WITH FRONT FOG LAMPS WITH HALOGEN HEADLAMP WITH HEATED PASSENGER SEAT WITH INTERIOR PACK WITH LEVEL 'A' INTERIOR DECOR WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH OVERSPEED WARNING DISABLED WITH PASS 6 WAY POWER SEAT ADJUSTER WITH PASSENGER AIR BAG WITH ROLLED EXHAUST TIPS WITH SIDE IMPACT PACKAGE WITH SINGLE REAR WING SPOILER WITH UPSIZED FRONT STABILIZER BAR WITH UPSIZED REAR STABLIZER BAR DSO SPEC. ORDER CD 71 EMISSION PROCESS ID 8R3A12A650NC ENGINE TAG ID 8S836AA FUEL TANK 8R339K007AE INSTRUMENT CLUSTER ID 7R3310849GC PAINT CODE ZY RADIATOR ID 4R338005CE STEERING ASSEMBLY ID 6R333C529AB SUSPENSION FRONT ID (LEFT) 6R335310DA SUSPENSION REAR ID (LEFT) 5R335560GB TRANSMISSION TAG NO. 8R3P7000AA TRIM COLOR C TRIM TYPE K VEHICLE DESCRIPTION FORD MUSTANG 2-DR CONVERTIBLE VEHICLE TYPE T85 WHEEL COVER TRIM 4R331A096BB WHEEL ID 4R331007KA WIRING 8R3T14A005YD WIRING 8R3T14631BA WIRING 8R3T14630BA WIRING 6R3T14407ED WIRING 8R3T14401FC WIRING 8R3T14290BA WIRING COUNT 06 BODY: 2-DR.-CONVERTIBLE BODY DESCRIPTION: GT CYLINDERS: 8 ENGINE: 4.6 ENGINE TYPE: OHC MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS PLUS DRIVER AND PASSENGER SIDE AIR BAGS, CURTAINS, OR CANOPIES SERIES: ZF TYPE: PASSENGER CAR
June 5, 20169 yr Author comment_151375 On 2016-05-11 at 08:05, Silverstallion said: Hej XLE636 1ZVHT82H155142232 Tack. /Johan 17 X 8" PAINTED ALUM W/MACH RIM 2005 JOB NO.1 PROGRAM CONTROL 235/55 ZR 17 ALL SEASON TYRE 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4550 LB. GVWR 4R33 5310 FA LEFT FRONT COIL 4R33-5310-FA RIGHT FRONT COIL 50 STATE EMISSION REQUIREMENTS 5R33-5560-BA LEFT REAR COIL 5R33-5560-BA RIGHT REAR COIL CDX6+ WITH SPEED SENSOR VOL CONTROL COLOUR ACCENT INTERIOR PACK #1 FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR MATS - MONOTONE C/K GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP LEATHER WRAP/SATIN ALUM SPOKE WHEEL LESS AMBIENT TEMP/SPEED PACK LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS ENGINE OIL COOLER LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS FRONT LICENSE PLATE BRACKET LESS IMMERSION HEATER LESS MILITARY VEHICLES LESS POWER STEERING OIL COOLER LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPECIAL LANGUAGE LABEL LESS SPEED AUDIBLE WARNING DEVICE MEDIUM DUTY BATTERY MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NORMAL FUEL FILL OWNER HAND BOOK PACK PERIMETER ALARM W/INTRUDER/SENSOR PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SPARE TYRE - T185/60R17 SPORTS FRONT SEAT U.S. SALES WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVERS POWER LUMBAR SUPPORT WITH DRIVERS POWER MIRROR WITH FIXED REAR SIDE WINDOW WITH FRONT FOG LAMPS WITH HANDLING SUSPENSION WITH HEATED REAR WINDOW WITH LEVEL 'A' INTERIOR DECOR WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH ON-BOARD DIAGNOSTIC SYSTEM WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER POWER CONVEX MIRROR WITH SIDE AIR BAG - DRIVERS SIDE WITH SIDE AIR BAG - PASSENGER SIDE WITH SIDE IMPACT PACKAGE WITH SINGLE REAR WING SPOILER WITH SUB WOOFER SOUND SYSTEM AXLE TAG RATING TYPE V247A CLUSTER FIN ID 4R3363044D70CFSMEN DRIVE LINE SHAFT ID 4R334K145AH DSO SPEC. ORDER CD 24 EMISSION PROCESS ID 5R3A12A650ACD ENGINE TAG ID 5S837AA FUEL TANK 4R339K007BM INSTRUMENT CLUSTER ID 5R3310849GC PAINT CODE TL RADIATOR ID 4R338005CE STEERING ASSEMBLY ID 5R333200BB 4R333C529AE SUSPENSION FRONT ID (LEFT) 4R335310FB SUSPENSION REAR ID (LEFT) 5R335560BC TRANSMISSION TAG NO. 4R337003AG TRIM COLOR R TRIM TYPE K VEHICLE DESCRIPTION MUSTANG 2-DR. SEDAN COUPE GT VEHICLE TYPE T82 WHEEL ID 4R331007CD 4R331007KA WIRING 4R3T14A005EAE WIRING 4R3T14631CM WIRING 4R3T14630BL WIRING 4R3T14407BP WIRING 4R3T14401CN WIRING 4R3T14290DJ WIRING COUNT 06 BODY: 2-DR.-COUPE BODY DESCRIPTION: GT CYLINDERS: 8 ENGINE: 4.6 ENGINE TYPE: OHC MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS PLUS DRIVER AND PASSENGER SIDE AIR BAGS, CURTAINS, OR CANOPIES SERIES: ZF TYPE: PASSENGER CAR
June 5, 20169 yr Author comment_151376 On 2016-05-17 at 18:23, zingonr1 said: Hej CUG 498 Och tack på förhand. / Ingemar 2005 JOB NO.1 PROGRAM CONTROL 235/55 ZR 17 ALL SEASON TYRE 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4550 LB. GVWR 4R33-5310-CA LEFT FRONT COIL 4R33-5310-CA RIGHT FRONT COIL 50 STATE EMISSION REQUIREMENTS 5R33-5560-GA LEFT REAR COIL 5R33-5560-GA RIGHT REAR COIL 8.0 X 17" MACHINED ALUMINIUM WHEEL BLACK VINYL COVER CDX6+ WITH SPEED SENSOR VOL CONTROL CONVERTIBLE BOOT-ROOF COVER FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP HIGH PERFORMANCE AUDIO SYSTEM LEATHER WRAP/SATIN ALUM SPOKE WHEEL LESS AMBIENT TEMP/SPEED PACK LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS DAYTIME RUNNING LAMPS LESS ENGINE OIL COOLER LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS FRONT LICENSE PLATE BRACKET LESS IMMERSION HEATER LESS MILITARY VEHICLES LESS POWER STEERING OIL COOLER LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPECIAL LANGUAGE LABEL LESS SPEED AUDIBLE WARNING DEVICE LESS TRIM PACK MEDIUM DUTY BATTERY MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NORMAL FUEL FILL OWNER HAND BOOK PACK PERIMETER ALARM W/INTRUDER/SENSOR PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SPARE TYRE - T185/60R17 SPORTS FRONT SEAT U.S. SALES WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVERS POWER LUMBAR SUPPORT WITH DRIVERS POWER MIRROR WITH ELECTRIC REAR WINDOWS WITH FRONT FOG LAMPS WITH HANDLING SUSPENSION WITH HEATED REAR WINDOW WITH LEVEL 'A' INTERIOR DECOR WITH LOCKING WHEEL LUG NUT KIT WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH ON-BOARD DIAGNOSTIC SYSTEM WITH OVERSPEED WARNING DISABLED WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER POWER CONVEX MIRROR WITH SIDE AIR BAG - DRIVERS SIDE WITH SIDE AIR BAG - PASSENGER SIDE WITH SIDE IMPACT PACKAGE WITH SINGLE REAR WING SPOILER AXLE TAG RATING TYPE V247A CLUSTER FIN ID 4R3363044D70CFSMEN DRIVE LINE SHAFT ID 4R334K145AH DSO SPEC. ORDER CD 27 EMISSION PROCESS ID 5R3A12A650ACD ENGINE TAG ID 5S837AA FUEL TANK 4R339K007BN INSTRUMENT CLUSTER ID 5R3310849GC PAINT CODE TL RADIATOR ID 4R338005CE STEERING ASSEMBLY ID 5R333200BB 4R333C529AE SUSPENSION FRONT ID (LEFT) 5R335310CA SUSPENSION REAR ID (LEFT) 5R335560GB TRANSMISSION TAG NO. 4R337003AG TRIM COLOR W TRIM TYPE K VEHICLE DESCRIPTION MUSTANG 2-DR. SEDAN CONVERTIBL VEHICLE TYPE T85 WHEEL COVER TRIM 4R331A108AB WHEEL ID 4R331007JE 4R331007KA WIRING 4R3T14A005NAM WIRING 4R3T14631BM WIRING 4R3T14630BL WIRING 4R3T14407DA WIRING 4R3T14401DN WIRING 5R3T14290DA WIRING COUNT 06 BODY: 2-DR.-CONVERTIBLE BODY DESCRIPTION: GT CYLINDERS: 8 ENGINE: 4.6 ENGINE TYPE: OHC MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS PLUS DRIVER AND PASSENGER SIDE AIR BAGS, CURTAINS, OR CANOPIES SERIES: ZF TYPE: PASSENGER CAR
June 6, 20169 yr comment_151396 On 2016-03-17 at 13:28, grufman said: Skriv in ditt reg eller chassienummer här så postar jag bilens build sheet Woz 250
July 19, 20169 yr comment_152045 On 18 mars 2016 at 13:28, grufman said: Skriv in ditt reg eller chassienummer här så postar jag bilens build sheet Hej, CLN767 Tack, Johan
July 24, 20169 yr comment_152097 On 2016-03-18 at 13:28, grufman said: Skriv in ditt reg eller chassienummer här så postar jag bilens build sheet SEL664
September 8, 20168 yr comment_152852 On 2016-03-18 at 13:28, grufman said: Skriv in ditt reg eller chassienummer här så postar jag bilens build sheet Då ska vi se vad som dyker upp ??? 1ZVBP8EM8D5229952 Nyfiken i en strut?Tack på förhand Janne W
September 18, 20168 yr Author comment_152954 On 6 juni 2016 at 22:03, u43jln said: Woz 250 17 X 8" PAINTED ALUM W/MACH RIM 2006 JOB #1 PROGRAM CONTROL 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4450 LB. GVW 4R33 5310 FA LEFT FRONT COIL 4R33-5310-FA RIGHT FRONT COIL 50 STATE EMISSION REQUIREMENTS 5R33-5560-BA LEFT REAR COIL 5R33-5560-BA RIGHT REAR COIL CDX6+ WITH SPEED SENSOR VOL CONTROL CENTER DOME LAMP W/O MAP LIGHT FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS GENERIC COUNTRY GROUP 1 I/P INSERT - RIBBED ALUMINIUM LEATHER WRAP/SATIN ALUM SPOKE WHEEL LESS ACCT STRIPE-BDYSD COLOR LESS AMBIENT TEMP/SPEED PACK LESS ANTI-THEFT ALARM LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS IMMERSION HEATER LESS MILITARY VEHICLES LESS SIDE IMPACT PACKAGE LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPECIAL LANGUAGE LABEL LESS SPEED AUDIBLE WARNING DEVICE LESS TRIM PACK MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON LOCKING FUEL CAP WITH BP LABEL NON/COLOR (ROOF) NORMAL FUEL FILL OWNER HAND BOOK PACK PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SPARE TYRE - T185/60R17 SPORTS FRONT SEAT STANDARD DUTY BATTERY U.S. SALES WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH CENTRE HUB ORNAMENT-FORD OVAL WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVER AIR BAG WITH DRIVERS POWER LUMBAR SUPPORT WITH DRIVERS POWER MIRROR WITH FIXED REAR SIDE WINDOW WITH FRONT FOG LAMPS WITH HEATED REAR WINDOW WITH LEVEL 'A' INTERIOR DECOR WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH ON-BOARD DIAGNOSTIC SYSTEM WITH OVERSPEED WARNING DISABLED WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER AIR BAG WITH PASSENGER POWER CONVEX MIRROR WITH SINGLE REAR WING SPOILER WITH SUB WOOFER SOUND SYSTEM WITH UPSIZED FRONT STABILIZER BAR WITH UPSIZED REAR STABLIZER BAR AXLE TAG RATING TYPE V247E CLUSTER FIN ID 6R3363044D70CGSMEN DRIVE LINE SHAFT ID 5R334K145AA DSO SPEC. ORDER CD 27 EMISSION PROCESS ID 6R3A12A650GB ENGINE TAG ID 6S837AA INSTRUMENT CLUSTER ID 6R3310849GD PAINT CODE G9 RADIATOR ID 4R338005CE STEERING ASSEMBLY ID 6R333200BF 6R333C529AB SUSPENSION FRONT ID (LEFT) 5R335310FA SUSPENSION REAR ID (LEFT) 5R335560BC TRANSMISSION TAG NO. 6R337003AA TRIM COLOR W TRIM TYPE K VEHICLE DESCRIPTION MUSTANG 2-DR COUPE GT VEHICLE TYPE T82 WHEEL ID 4R331007KA WIRING 6R3T14290BB WIRING COUNT 01 BODY: 2-DR.-COUPE BODY DESCRIPTION: GT CYLINDERS: 8 ENGINE: 4.6 ENGINE TYPE: OHC MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS - APPLIES TO ALL PASSENGER CARS SERIES: ZF TYPE: PASSENGER CAR
September 18, 20168 yr Author comment_152955 On 19 juli 2016 at 20:01, ahnmarker said: Hej, CLN767 Tack, Johan (+)"ARE" 2005 JOB NO.1 PROGRAM CONTROL 235/55 ZR 17 ALL SEASON TYRE 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4550 LB. GVWR 4R33 5310 GA LEFT FRONT COIL 4R33-5310-GA RIGHT FRONT COIL 50 STATE EMISSION REQUIREMENTS 5R33-5560-CA LEFT REAR COIL 5R33-5560-CA RIGHT REAR COIL 8.0 X 17" MACHINED ALUMINIUM WHEEL ARABIC LANGUAGE LABEL CDX6+ WITH SPEED SENSOR VOL CONTROL CENTER DOME LAMP W/O MAP LIGHT EXPORT FUEL FILL EXPORT SALES FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS GENERIC COUNTRY GROUP 11 LEATHER WRAP/SATIN ALUM SPOKE WHEEL LESS ANTI-THEFT ALARM LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS FRONT LICENSE PLATE BRACKET LESS IMMERSION HEATER LESS MILITARY VEHICLES LESS POWER STEERING OIL COOLER LESS TRIM PACK MEDIUM DUTY BATTERY MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON/COLOR (ROOF) OWNER HAND BOOK PACK PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SPARE TYRE - T185/60R17 SPECIAL BUILD REQUIREMENT - A SPORTS FRONT SEAT WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVERS POWER LUMBAR SUPPORT WITH DRIVERS POWER MIRROR WITH ENGINE OIL COOLER WITH FIXED REAR SIDE WINDOW WITH FRONT FOG LAMPS WITH GCC RADIO FREQUENCY WITH HANDLING SUSPENSION WITH HEATED REAR WINDOW WITH HIGH AMBIENT TEMP/SPEED PACK WITH HIGH SPEED WARNING CHIME WITH KMH/MPH SPEEDOMETER WITH LEVEL 'A' INTERIOR DECOR WITH MESSAGE CENTRE WITH ON-BOARD DIAGNOSTIC SYSTEM WITH OVERSPEED WARNING WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER POWER CONVEX MIRROR WITH SIDE AIR BAG - DRIVERS SIDE WITH SIDE AIR BAG - PASSENGER SIDE WITH SIDE IMPACT PACKAGE WITH SINGLE REAR WING SPOILER WITH SMOKERS PACKAGE WITH SUB WOOFER SOUND SYSTEM AXLE TAG RATING TYPE V237C CLUSTER FIN ID 5R3363044D70ABSMEN DRIVE LINE SHAFT ID 5R334K145AA DSO SPEC. ORDER CD 9Y EMISSION PROCESS ID 5R3A12A650AHE ENGINE TAG ID 5S836AA FUEL TANK 5R339K007AD INSTRUMENT CLUSTER ID 5R3310849HC PAINT CODE SN RADIATOR ID 4R338005CE STEERING ASSEMBLY ID 5R333200BB 5R333C529AA SUSPENSION FRONT ID (LEFT) 5R335310GA SUSPENSION REAR ID (LEFT) 5R335560CC TRANSMISSION TAG NO. 4R3P7000AC TRIM COLOR H TRIM TYPE K VEHICLE DESCRIPTION MUSTANG 2-DR COUPE GT VEHICLE TYPE T82 WHEEL COVER TRIM 4R331A108AB WHEEL ID 4R331007JE 4R331007KA WIRING 5R3T14A005EF WIRING 4R3T14407BP WIRING 4R3T14401CN WIRING 5R3T14290BA WIRING COUNT 04 BODY: 2-DR.-COUPE BODY DESCRIPTION: GT CYLINDERS: 8 ENGINE: 4.6 ENGINE TYPE: OHC MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS PLUS DRIVER AND PASSENGER SIDE AIR BAGS, CURTAINS, OR CANOPIES SERIES: ZF TYPE: PASSENGER CAR
September 18, 20168 yr Author comment_152956 On 24 juli 2016 at 23:30, LYA said: SEL664 17 X 8" PAINTED ALUM W/MACH RIM 2005 JOB NO.1 PROGRAM CONTROL 235/55 ZR 17 ALL SEASON TYRE 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4550 LB. GVWR 4R33 5310 FA LEFT FRONT COIL 4R33-5310-FA RIGHT FRONT COIL 50 STATE EMISSION REQUIREMENTS 5R33-5560-CA LEFT REAR COIL 5R33-5560-CA RIGHT REAR COIL CDX6+ WITH SPEED SENSOR VOL CONTROL CENTER DOME LAMP W/O MAP LIGHT FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS GENERIC COUNTRY GROUP 1 HIGH PERFORMANCE AUDIO SYSTEM LEATHER WRAP/SATIN ALUM SPOKE WHEEL LESS AMBIENT TEMP/SPEED PACK LESS ANTI-THEFT ALARM LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS ENGINE OIL COOLER LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS FRONT LICENSE PLATE BRACKET LESS IMMERSION HEATER LESS MILITARY VEHICLES LESS POWER STEERING OIL COOLER LESS SIDE IMPACT PACKAGE LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPECIAL LANGUAGE LABEL LESS SPEED AUDIBLE WARNING DEVICE LESS TRIM PACK MEDIUM DUTY BATTERY MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON/COLOR (ROOF) NORMAL FUEL FILL OWNER HAND BOOK PACK PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SPARE TYRE - T185/60R17 SPORTS FRONT SEAT U.S. SALES WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVERS POWER LUMBAR SUPPORT WITH DRIVERS POWER MIRROR WITH FIXED REAR SIDE WINDOW WITH FRONT FOG LAMPS WITH HANDLING SUSPENSION WITH HEATED REAR WINDOW WITH LEVEL 'A' INTERIOR DECOR WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH ON-BOARD DIAGNOSTIC SYSTEM WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER POWER CONVEX MIRROR WITH SIDE AIR BAG - DRIVERS SIDE WITH SIDE AIR BAG - PASSENGER SIDE WITH SINGLE REAR WING SPOILER AXLE TAG RATING TYPE V247A CLUSTER FIN ID 4R3363044D70CFSMEN DRIVE LINE SHAFT ID 4R334K145AH DSO SPEC. ORDER CD 56 EMISSION PROCESS ID 5R3A12A650ACD ENGINE TAG ID 5S691AA FUEL TANK 4R339K007BM INSTRUMENT CLUSTER ID 5R3310849GC PAINT CODE TK RADIATOR ID 4R338005CE STEERING ASSEMBLY ID 5R333200BB 4R333C529AE SUSPENSION FRONT ID (LEFT) 4R335310FB SUSPENSION REAR ID (LEFT) 5R335560CC TRANSMISSION TAG NO. 4R337003AG TRIM COLOR W TRIM TYPE K VEHICLE DESCRIPTION MUSTANG 2-DR. SEDAN COUPE GT VEHICLE TYPE T82 WHEEL ID 4R331007CD 4R331007KA WIRING 4R3T14A005FAE WIRING 4R3T14631CM WIRING 4R3T14630BL WIRING 4R3T14407BP WIRING 4R3T14401DN WIRING 4R3T14290BL WIRING COUNT 06 BODY: 2-DR.-COUPE BODY DESCRIPTION: GT CYLINDERS: 8 ENGINE: 4.6 ENGINE TYPE: OHC MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS - APPLIES TO ALL PASSENGER CARS SERIES: ZF TYPE: PASSENGER CAR
September 18, 20168 yr Author comment_152957 On 2 september 2016 at 10:47, Henrixon said: Hej BDR 315 /Peter 18X8.5"POL CAST ALUM BRT MACH WHEEL 2006 JOB #1 PROGRAM CONTROL 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4450 LB. GVW 4R33 5310 FA LEFT FRONT COIL 4R33-5310-FA RIGHT FRONT COIL 50 STATE EMISSION REQUIREMENTS 5R33-5560-BA LEFT REAR COIL 5R33-5560-BA RIGHT REAR COIL CDX6+ WITH SPEED SENSOR VOL CONTROL CENTER DOME LAMP W/O MAP LIGHT CENTRE HUB ORN - PONY LOGO/SPINNER FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS GENERIC COUNTRY GROUP 1 I/P INSERT - RIBBED ALUMINIUM LEATHER WRAP/SATIN ALUM SPOKE WHEEL LESS ACCT STRIPE-BDYSD COLOR LESS AMBIENT TEMP/SPEED PACK LESS ANTI-THEFT ALARM LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS IMMERSION HEATER LESS MILITARY VEHICLES LESS SIDE IMPACT PACKAGE LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPECIAL LANGUAGE LABEL LESS SPEED AUDIBLE WARNING DEVICE LESS TRIM PACK MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON LOCKING FUEL CAP WITH BP LABEL NON/COLOR (ROOF) NORMAL FUEL FILL OWNER HAND BOOK PACK PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SPARE TYRE - T185/60R17 SPORTS FRONT SEAT STANDARD DUTY BATTERY U.S. SALES WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVER AIR BAG WITH DRIVERS POWER LUMBAR SUPPORT WITH DRIVERS POWER MIRROR WITH FIXED REAR SIDE WINDOW WITH FRONT FOG LAMPS WITH HEATED REAR WINDOW WITH LEVEL 'A' INTERIOR DECOR WITH LOCKING WHEEL LUG NUT KIT WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH ON-BOARD DIAGNOSTIC SYSTEM WITH OVERSPEED WARNING DISABLED WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER AIR BAG WITH PASSENGER POWER CONVEX MIRROR WITH SINGLE REAR WING SPOILER WITH SUB WOOFER SOUND SYSTEM WITH UPSIZED FRONT STABILIZER BAR WITH UPSIZED REAR STABLIZER BAR AXLE TAG RATING TYPE V247E CLUSTER FIN ID 6R3363044D70CGSMEN DRIVE LINE SHAFT ID 5R334K145AA DSO SPEC. ORDER CD 72 EMISSION PROCESS ID 6R3A12A650GB ENGINE TAG ID 6S837AA INSTRUMENT CLUSTER ID 6R3310849GD PAINT CODE D6 RADIATOR ID 4R338005CE STEERING ASSEMBLY ID 6R333200CL 6R333C529AB SUSPENSION FRONT ID (LEFT) 5R335310FA SUSPENSION REAR ID (LEFT) 5R335560BC TRANSMISSION TAG NO. 6R337003AA TRIM COLOR W TRIM TYPE K VEHICLE DESCRIPTION MUSTANG 2-DR COUPE GT VEHICLE TYPE T82 WHEEL COVER TRIM 5R3J1A096BA WHEEL ID 4R331007KA 6R3J1007DA WIRING 6R3T14290BB WIRING COUNT 01 BODY: 2-DR.-COUPE BODY DESCRIPTION: GT CYLINDERS: 8 ENGINE: 4.6 ENGINE TYPE: OHC MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS - APPLIES TO ALL PASSENGER CARS SERIES: ZF TYPE: PASSENGER CAR
September 18, 20168 yr Author comment_152958 On 8 september 2016 at 08:34, Janne W said: Då ska vi se vad som dyker upp ??? 1ZVBP8EM8D5229952 Nyfiken i en strut?Tack på förhand Janne W (-) VERSION PACKAGES 17" X 5 MINI STEEL SPARE WHEEL 2013 JOB #1 PROGRAM CONTROL 7 X 17" PAINTED ALUMINIUM WHEEL ANALOGUE AUDIO BROADCAST BLACK VINYL COVER BR33-5560-A* LEFT REAR COIL SPRING BR33-5560-A* RIGHT REAR COIL SPRING CENTRE HUB ORN - PONY LOGO/SPINNER DOOR ENTRY R/CONT UNIT - 2 KEYS DRIVER BLACK POWER MIRROR FLATROCK ASSEMBLY PLANT - USA FLEET FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FREQUENCY - 315MHZ FRONT DOOR SILL PROTECTION - BLACK FRONT FLOOR CARPET MATS FRONT LICENSE PLATE HOLDER DELUXE GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP HIGH INTENSITY DISCHARGE HEADLAMP I/P INSERT - BLACK LEATHER STEERING WHEEL LESS ACCT STRIPE-BDYSD COLOR LESS ANTI-THEFT ALARM LESS APPEARANCE GROUP LESS BODY TU-TONE PAINT LESS BODYSIDE ACCENT STRIPE LESS BONNET SCOOP LESS CAMERA LESS CONVENIENCE GROUP LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS DIFFERENTIAL COOLER COVER LESS DRIVER SEAT LUMBAR SUPPORT LESS ENGINE COOLING SYSTEM LESS EXHAUST TIPS LESS FLOOR MATS-FIA LESS FRONT FOG LAMPS LESS FRONT LIP SPOILER - FIA LESS FUEL LABEL LESS FULL VEHICLE COVER LESS GARAGE DOOR OPENER LESS IMMERSION HEATER LESS INTERIOR PACK LESS LIGHTING PACKAGES LESS MEDIA/ENTERTAINMENT PACKAGE LESS OPTIONAL EQUIPMENT PACK LESS PERFORMANCE PACK LESS PREMIUM BRAKES LESS REAR MUDFLAPS LESS REMOTE STARTER - FIA LESS REVERSE PROXIMITY SENSOR LESS SAFETY PACKAGE LESS SIDE SCOOP - FIA LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPECIAL EQUIPMENT PACKAGE LESS SPEED AUDIBLE WARNING DEVICE LESS SPOILER LESS SPOILER - FIA LESS SUN ROOF LESS SYNC LESS TAPE STRIPES - FIA LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT LESS TYRE INFLATION KIT LESS WINDOW LOUVERS - FIA MUSTANG (2005/) NORMAL FUEL FILL OWNER HAND BOOK PACK PASSENGER BLACK POWER MIRROR REAR AXLE LIMITED SLIP DIFFERENTIAL SIDE AIR BAG - 1ST ROW ONLY SPARE TYRE - T185/60R17 SPORTS FRONT SEAT STANDARD FOOT PEDAL PAD DESIGN TYRE INFLATION MONITOR WITH 4 GAUGE INSTRUMENT CLUSTER WITH AM/FM CD PLAYER WITH BASE INTERIOR DECOR WITH CALIFORNIA/GREEN STATE REQ WITH CONVENTIONAL HEADLAMP CONTROL WITH DRIVER 4 WAY MNL.SEAT ADJUSTER WITH ELECTRIC REAR WINDOWS WITH ENGLISH LANGUAGE LABEL WITH FRONT 4 WAY HEADREST WITH FRONT SIDE AIR BAG RESTRAINT WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PREMIUM SOUND SYSTEM WITH PRISMATIC MIRROR WITH SOFT FEEL HANDBRAKE GRIP ALTERNATOR ID BR3T10300EC AXLE TAG RATING TYPE S201C DRIVE LINE SHAFT ID BR334602AC DSO SPEC. ORDER CD 72 EMISSION PROCESS ID DR3A12A650GE ENGINE TAG ID 1G372CA FUEL TANK CR339K007AC INSTRUMENT CLUSTER ID DR3310849AC PAINT CODE HP RADIATOR ID BR338005AA STEERING ASSEMBLY ID 6R333C529AC SUSPENSION FRONT ID (LEFT) BR335310BB SUSPENSION REAR ID (LEFT) BR335560AB TRANSMISSION TAG NO. BR3P7000AA TRIM COLOR W TRIM TYPE 1 VEHICLE DESCRIPTION FORD MUSTANG 2-DR CONVERTIBLE VEHICLE TYPE P8E WHEEL COVER TRIM 5R3J1A096BA WHEEL ID AR331007AB 9R331007AA WIRING BR3T14407AAB WIRING DR3T14A005LE WIRING DR3T14631CC WIRING DR3T14630AC WIRING DR3T14401AF WIRING DR3T14290AD WIRING COUNT 06 BODY: 2-DR. SEDAN BODY DESCRIPTION: V6 CONVERTIBLE CYLINDERS: 6 ENGINE: 3.7 ENGINE TYPE: TI-VCT GASOLINE MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) - VALID FOR F/CMVSS 500 LOW SPEED VEHICLES ONLY SERIES: V6 TYPE: PASSENGER CAR
September 18, 20168 yr Author comment_152959 On 8 september 2016 at 21:59, Gunnar A said: alz 948 Tack på förhand Gunnar A (-) VERSION PACKAGES 18 X 9.5 ALLOY WHEEL 2007 JOB #2 PROGRAM CONTROL 4 WHEEL ANTI-LOCK BRAKING SYSTEM 50 STATE EMISSION REQUIREMENTS 7R3V-5560-KA LEFT REAR COIL 7R3V-5560-KA RIGHT REAR COIL ACCENT STRIPE - PERFORM WHITE BLACK CLOTH COVER CDX6+ WITH SPEED SENSOR VOL CONTROL CENTRE HUB - VERSION A CONVERTIBLE BOOT-ROOF COVER ELECTROCHROMIC MIRROR WITH COMPASS FLATROCK ASSEMBLY PLANT - USA FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS FRONT LICENSE PLATE HOLDER DELUXE GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP I/P INSERT - TITANIUM FINISH INTERIOR UPGRADE PACKAGE B LESS AMBIENT TEMP/SPEED PACK LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BONNET SCOOP LESS CARGO NET - FIA LESS CONVENIENCE GROUP LESS DAYTIME RUNNING LAMPS LESS EXHAUST TIPS LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS FLOOR MATS-FIA LESS FUEL FILLER DOOR - FIA LESS FULL VEHICLE COVER LESS IMMERSION HEATER LESS REMOTE STARTER - FIA LESS SMOKERS PACKAGE LESS SPARE TYRE LESS SPARE WHEEL LESS SPECIAL BUILD REQUIREMENT LESS SPEED AUDIBLE WARNING DEVICE LESS TAPE STRIPES - FIA LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT MEDIUM DUTY BATTERY MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON LOCKING FUEL CAP WITH BP LABEL NORMAL FUEL FILL OWNER HAND BOOK PACK PERIMETER ALARM W/INTRUDER/SENSOR REAR AXLE LIMITED SLIP DIFFERENTIAL SATELLITE DIGITAL BROADCAST SPORTS FRONT SEAT STEERING WHEEL - 3 SPOKE LEATHER SVT RACING STRIPES U.S. SALES UNIQUE MET FINISH FOOT PEDALS PADS WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVER AIR BAG WITH DRIVERS POWER LUMBAR SUPPORT WITH ELECTRIC REAR WINDOWS WITH ENGLISH LANGUAGE LABEL WITH FLUSH SPOILER WITH INTERIOR PACK 2 WITH LOCKING WHEEL LUG NUT KIT WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH OVERSPEED WARNING DISABLED WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER AIR BAG WITH SIDE IMPACT PACKAGE WITH SUB WOOFER SOUND SYSTEM WITH SVE FRONT FOG LAMPS/AUX I/P WITH TYRE INFLATION KIT WITH UPSIZED FRONT STABILIZER BAR WITH UPSIZED REAR STABLIZER BAR AXLE TAG RATING TYPE V255J CLUSTER FIN ID 7R3V63044D70BASMGN DSO SPEC. ORDER CD 58 EMISSION PROCESS ID 7R3A12A650AFF ENGINE TAG ID 7S253CA FUEL TANK 7R3V9K007BG INSTRUMENT CLUSTER ID 7R3V10849AD PAINT CODE D3 RADIATOR ID 7R3V8009BC STEERING ASSEMBLY ID 7R3V3200DD 6R333C529AB SUSPENSION REAR ID (LEFT) 7R3V5560KB TRANSMISSION TAG NO. 7R3V7003AK TRIM COLOR R TRIM TYPE G VEHICLE DESCRIPTION FORD MUSTANG 2-DR SHELBY CONVE VEHICLE TYPE T89 WHEEL COVER TRIM 2M5V1A096AB WIRING 7R3V14A005SAB WIRING 5R3T14631BA WIRING 6R3T14407ED WIRING 7R3T14401DAE WIRING 7R3V14290EAA WIRING COUNT 05 CYLINDERS: 8 ENGINE: 5.4 ENGINE TYPE: DOHC EFI MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS PLUS DRIVER AND PASSENGER SIDE AIR BAGS, CURTAINS, OR CANOPIES TYPE: PASSENGER CAR
September 18, 20168 yr Author comment_152960 11 timmar sedan, Perssson said: DFH627 /Magnus (-) VERSION PACKAGES 8.5 X 19" PAINTED ALUMINIUM WHEEL BR33-5560-C* LEFT REAR COIL SPRING BR33-5560-C* RIGHT REAR COIL SPRING CENTER DOME LAMP W/O MAP LIGHT CENTRE HUB ORN - PONY LOGO/SPINNER DRIVERS C/K POWER MIRROR ELECT PREM AM/FM STRO/DISC/CLOCK ELECTRO MIRROR WITH COMPASS AND MIC ENGINE COVER - UNDER HOOD FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS FRONT SCUFF PLATES - ILLUMINATED GENERIC COUNTRY GROUP 1 I/P INSERT - METALLIC FINISH LEATHER WRAP WITH REDUNDANT CONTROL LESS ACCT STRIPE-BDYSD COLOR LESS ANTI-THEFT ALARM LESS APPEARANCE GROUP LESS BODYSIDE ACCENT STRIPE LESS CAMERA LESS CONVENIENCE GROUP LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS DECKLID PANEL - FIA LESS FLEET LESS FRONT LICENSE PLATE BRACKET LESS FRONT LIP SPOILER - FIA LESS FULL VEHICLE COVER LESS GARAGE DOOR OPENER LESS HOOD SCOOP - FIA LESS IMMERSION HEATER LESS INTERIOR PACK LESS PERFORMANCE PACK LESS PREMIUM BRAKES LESS REAR MUDFLAPS LESS REMOTE STARTER - FIA LESS SAFETY PACKAGE LESS SIDE SCOOP - FIA LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPEED AUDIBLE WARNING DEVICE LESS SPOILER - FIA LESS SUN ROOF LESS TAPE STRIPES - FIA LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT LESS TYRE INFLATION KIT LESS WINDOW LOUVERS - FIA LIGHTING PACKAGE LEVEL A MUSTANG (2005/) NON/COLOR (ROOF) NORMAL FUEL FILL OWNER HAND BOOK PACK PASSENGER POWER MIRROR PREMIUM MARKETING TRIM SATELLITE DIGITAL BROADCAST SIDE AIR BAG - 1ST ROW ONLY SPARE TYRE - T185/55R18 SPORTS FRONT SEAT UNIQUE MET FINISH FOOT PEDALS PADS WITH 18" ALUMINIUM MINI SPARE WHEEL WITH 49 STATE/NON GREEN STATE REQ WITH 6 GAUGE INSTUMENT CLUSTER WITH AUTOMATIC HEADLAMP CONTROL WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVERS POWER LUMBAR SUPPORT WITH ENGLISH LANGUAGE LABEL WITH FIXED REAR SIDE WINDOW WITH FRONT FOG LAMPS WITH HALOGEN HEADLAMP WITH LEATHER HANDBRAKE GRIP WITH LEVEL 'A' INTERIOR DECOR WITH MEDIA GATEWAY MODULE WITH MEDIA GATEWAY PACKAGE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH PASS 2 WAY MANUAL SEAT ADJUST WITH REAR HEAVY DUTY STABILIZER BAR WITH ROLLED EXHAUST TIPS WITH SINGLE REAR WING SPOILER WITH SUB WOOFER SOUND SYSTEM WITH UPSIZED FRONT STABILIZER BAR ALTERNATOR ID BR3T10300KC CLUSTER FIN ID BR3310849EE DSO SPEC. ORDER CD 24 EMISSION PROCESS ID BR3A12A650AHG ENGINE TAG ID 1G397AA FUEL TANK BR339K007AE INSTRUMENT CLUSTER ID BR3310849EE PAINT CODE HP RADIATOR ID BR338005AA STEERING ASSEMBLY ID 6R333C529AC SUSPENSION FRONT ID (LEFT) BR335310FB SUSPENSION REAR ID (LEFT) BR335560CB TRANSMISSION TAG NO. BR337003AF TRIM COLOR W TRIM TYPE 4 VEHICLE DESCRIPTION FORD MUSTANG 2-DR COUPE GT VEHICLE TYPE P8C WHEEL COVER TRIM 5R3J1A096BA WHEEL ID AR331007EB BR331007AB WIRING BR3T14A005CE WIRING BR3T14631BA WIRING BR3T14630BA WIRING BR3T14407AA WIRING BR3T14401GF WIRING BR3T14290EE WIRING COUNT 06 BODY: 2-DR. SEDAN BODY DESCRIPTION: GT COUPE CYLINDERS: 8 ENGINE: 5.0 ENGINE TYPE: GASOLINE MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) - VALID FOR F/CMVSS 500 LOW SPEED VEHICLES ONLY SERIES: GT TYPE: PASSENGER CAR
September 18, 20168 yr comment_152970 33 minuter sedan, grufman said: Såja. Fyll på med mer nu :-) Tjena och tack på förhand :-) TDU 844 /Jimmy
September 18, 20168 yr Author comment_152978 1 hour ago, Sulan1 said: Tjena och tack på förhand :-) TDU 844 /Jimmy (-) VERSION PACKAGES 18X8.5"POL CAST ALUM BRT MACH WHEEL 2007 JOB #2 PROGRAM CONTROL 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4550 LB. GVWR 4R33-5310-CA LEFT FRONT COIL 4R33-5310-CA RIGHT FRONT COIL 5R33-5560-FA LEFT REAR COIL 5R33-5560-FA RIGHT REAR COIL ANALOGUE AUDIO BROADCAST BLACK VINYL COVER CDX6+ WITH SPEED SENSOR VOL CONTROL CENTRE HUB ORN - PONY LOGO/SPINNER CONVERTIBLE BOOT-ROOF COVER ELECTROCHROMIC MIRROR WITH COMPASS ENGINE COVER - UNDER HOOD FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT COMFORT PACKAGE C2 FRONT FLOOR CARPET MATS GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP I/P INSERT - RIBBED ALUMINIUM LEATHER WRAP/SATIN ALUM SPOKE WHEEL LESS ACCT STRIPE-BDYSD COLOR LESS AMBIENT TEMP/SPEED PACK LESS ANTI-THEFT ALARM LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS CARGO NET - FIA LESS DAYTIME RUNNING LAMPS LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS FLOOR MATS-FIA LESS FRONT LICENSE PLATE BRACKET LESS FUEL FILLER DOOR - FIA LESS FULL VEHICLE COVER LESS IMMERSION HEATER LESS INTERIOR PACK LESS REMOTE STARTER - FIA LESS SIDE IMPACT PACKAGE LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPEED AUDIBLE WARNING DEVICE LESS TAPE STRIPES - FIA LESS TYRE INFLATION KIT MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON LOCKING FUEL CAP WITH BP LABEL NORMAL FUEL FILL OWNER HAND BOOK PACK PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SPARE TYRE - T185/60R17 SPORTS FRONT SEAT STANDARD DUTY BATTERY STANDARD FOOT PEDAL PAD DESIGN U.S. SALES WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 49 STATE/NON GREEN STATE REQ WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH BONNET SCOOP WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVER AIR BAG WITH DRIVERS HEATED SEAT WITH DRIVERS POWER LUMBAR SUPPORT WITH ELECTRIC REAR WINDOWS WITH ENGLISH LANGUAGE LABEL WITH FRONT FOG LAMPS WITH HEATED PASSENGER SEAT WITH LEVEL 'A' INTERIOR DECOR WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH OVERSPEED WARNING DISABLED WITH PASS 6 WAY POWER SEAT ADJUSTER WITH PASSENGER AIR BAG WITH ROLLED EXHAUST TIPS WITH SINGLE REAR WING SPOILER WITH SUB WOOFER SOUND SYSTEM WITH UPSIZED FRONT STABILIZER BAR WITH UPSIZED REAR STABLIZER BAR AXLE TAG RATING TYPE V237V CLUSTER FIN ID 7R3363044D70HASMEN DRIVE LINE SHAFT ID 6R334K145AD DSO SPEC. ORDER CD 52 EMISSION PROCESS ID 7R3A12A650ALC ENGINE TAG ID 7S837BB FUEL TANK 7R339K007AF INSTRUMENT CLUSTER ID 7R3310849GC PAINT CODE G2 RADIATOR ID 4R338005CE STEERING ASSEMBLY ID 7R333200CB 6R333C529AB SUSPENSION FRONT ID (LEFT) 6R335310CA SUSPENSION REAR ID (LEFT) 5R335560FB TRANSMISSION TAG NO. 7R337003AC TRIM COLOR W TRIM TYPE K VEHICLE DESCRIPTION FORD MUSTANG 2-DR CONVERTIBLE VEHICLE TYPE T85 WHEEL COVER TRIM 5R3J1A096BA WHEEL ID 4R331007KA WIRING 7R3T14A005PAE WIRING 5R3T14631BA WIRING 6R3T14407ED WIRING 7R3T14401CAF WIRING 7R3T14290BA WIRING COUNT 05 BODY: 2-DR.-CONVERTIBLE BODY DESCRIPTION: GT CYLINDERS: 8 ENGINE: 4.6 ENGINE TYPE: OHC MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS - APPLIES TO ALL PASSENGER CARS SERIES: ZF TYPE: PASSENGER CAR
September 18, 20168 yr Author comment_152979 21 minuter sedan, Farfar said: Hei. 1FA6P8CF3F5304445 På forhånd takk. M.v.h. Trond (-) VERSION PACKAGES 19 X 8.5 PREM PAINTED ALUM WHEEL 2 WAY REAR HEADRESTRAINT- LVL II 255/40R19 W 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4720 LB. GVW 7000 RPM TACHOMETER A/C REFRIGERANT-R134A AIR CURTAIN RESTRNT LH AIR CURTAIN RESTRNT RH ALL WEATHER FLOOR MATS - FIA BLT/D&P FRT/1&2 ROW/D/P KNE CENTRE CONSOLE-LEVEL 2 CENTRE HUB ORN - HORSE AND BAR CUP HOLDERS (2) - ROW 1 DUAL EXHAUST DUAL NOTE ELECTRIC HORN - LEVEL 2 DUAL POWER HEATED EXTERIOR MIRRORS ELECTRIC OPERATED REAR VIEW MIRROR EQUIPMENT PACKAGE 11 EXTERIOR PAINT - SOLID FEATURE CONTENT GROUP 1 FILTER COWL INTAKE - ODOUR FIXED FOOT PEDALS FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FR3C 5310 D* LEFT/FRONT COIL FR3C 5310 D* RIGHT/FRONT COIL FR3C-5560-A* LEFT REAR COIL FR3C-5560-A* RIGHT REAR COIL FREQUENCY - 902 MHZ FRONT BUMPER-PLASTIC-PERFORMANCE FRONT FLOOR CARPET MATS FRONT FOG LAMPS-LED FRONT SCUFF PLATES - ILLUMINATED GENERIC COUNTRY GROUP 1 GRILLE - MOULDED IN COLOUR GRILLE-LOWER MESH DK SLF CLR GT SALES BADGE HIGH INTENSITY DISCHARGE HEADLAMP HUMAN MACHINE INTERFACE 3 I/P INSERT - DARK ALUMINIUM KEYLESS ENTRY/START - PASSIVE KIT - TYRE REPAIR SERVICE LEATHER STEERING WHEEL LESS - BTSI MANUAL OVERRIDE LESS ACCT STRIPE-BDYSD COLOR LESS ACOUSTICAL WARNING SYSTEM LESS BATTERY CABLES LESS BLIND SPOT INFORMATION SYSTEM LESS BODYSIDE ACCENT STRIPE LESS CONSOLE ASHTRAY LESS COOLERS - POWERTRAIN LESS DAYTIME RUNNING LAMPS LESS DECKLID PANEL - FIA LESS DEPLOYABLE BONNET LESS DIVERSITY ANTENNA LESS EXTERIOR APPEARANCE PACK LESS FIRE EXTINGUISHER FIXINGS LESS FLEET LESS FRONT TOWING HOOK LESS HEADLAMP LEVELLING LESS HOOD SCOOP - FIA LESS ICE NOISE REDUCTION LESS IMMERSION HEATER LESS INSTRUMENT GAUGES LESS INTERIOR PACK LESS LICENSE PLATE BRACKET - REAR LESS MIRROR GLASS ETCHING LESS PERFORMANCE PACK LESS REAR PARKING AID LESS SECONDARY SECURITY SYSTEM LESS SIDE SCOOP - FIA LESS SPARE TYRE LESS SPARE WHEEL LESS SPECIAL EQUIPMENT PACKAGE LESS SPECIALTY PACKAGES LESS SPEED AUDIBLE WARNING DEVICE LESS SUN ROOF LESS TOOL KIT LESS TRACK PACK LESS TRANSMISSION OIL COOLER LESS WARNING DISPLAY LESS WINDOW LOUVERS - FIA MECHANICAL HAND OPERATED PARK BRAKE MID AUDIO + CD + SDARS MIDLINE SOUND SYSTEM MINI OVERHEAD CNSL W/SUNGLASS BIN MODULE/GPS ANTENNA MUSTANG NAAO MARKET DERIVATIVE NON LOCKING CAPLESS FUEL FILL NON LOCKING LUG NUTS NON/COLOR (ROOF) NORMAL FUEL FILL OWNER HAND BOOK PACK PERIMETER ALARM W/INTRUDER/SENSOR POWER DOOR LOCK WITH ELEC RELEASE POWER FRONT WINDOWS ONE TOUCH UP/DO POWER POINT CONVERTER (230V/150W) PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL REAR BUMPER - PLASTIC UNPAINTED REAR VIEW CAMERA-FIXED S/BELT LOCKING RETRACTION - 3 POINT SEAT BELT PRETENSIONERS DRV/PASS SPORTS FRONT SEAT STANDARD DUTY FRONT COIL SPRING SYNC II TAIL LAMPS - LED REAR TRND MNI PRF OV MLD PBL (A-L) TYRE INFLATION MONITOR UNIQUE MET FINISH FOOT PEDALS PADS WITH AIR PURIFIER SENSOR WITH AMBIENT LIGHTING-INTERIOR WITH AUTOMATIC HEADLAMP ON/OFF WITH BELTMINDER WITH BLACK DOOR FRAME MOULDING WITH BODY COLOURED EXTERIOR MIRROR WITH BONNET SCOOP WITH BRAKE EMERGENCY ASSIST WITH CALIFORNIA/GREEN STATE REQ WITH CHROME EXHAUST PIPE EXTENSION WITH CONVENTIONAL REAR SEAT WITH COURTESY LIGHT DELAY WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVER SEAT BACK MAP POCKET WITH DRIVERS HEATED AND COOLED SEAT WITH ELECTRIC POWER STEERING WITH ENGINE IMMOBILIZER - INTEGRAL WITH ENGLISH LANGUAGE LABEL WITH FIXED REAR VENT QUARTER WINDOW WITH FRONT 4 WAY HEADREST WITH FRONT LICENCE PLATE BRACKET WITH FRONT STABILIZER BAR WITH HEATED REAR WINDOW WITH HIGH SERIES BRAKES WITH HIGH SERIES CLUSTER WITH HILL LAUNCH ASSIST WITH ILLUMINATED SUNVISOR - DRIVERS WITH ILLUMINATED SUNVISOR-PASSENGER WITH INDEPENDANT REAR SUSPENSION WITH ISOFIX HARD POINT ATTACHMENT WITH LAMINATED WINDSCREEN WITH LEATHER HANDBRAKE GRIP WITH LEATHER/COLOUR KEYED GEAR KNOB WITH LEVEL 'A' INTERIOR DECOR WITH LEVEL 2 DOOR TRIM PANEL WITH LOAD FLOOR CARPET - THIN WITH LOCKING WHEEL LUG NUT KIT WITH LUNAR CONTRAST STITCHING WITH MANUAL SHIFT AUTO TRANS WITH MAP READING LIGHT WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH NAVIGATION SYSTEM WITH PASS 6 WAY POWER SEAT ADJUSTER WITH PASS HEATED AND COOLED SEAT WITH PERFORMANCE FRONT FENDERS WITH REAR STABLIZER BAR WITH REAR WINDOW AERIAL WITH REMOTE ALARM SYSTEM - PATS WITH REMOTE STARTER WITH ROLLOVER CURTAIN AND SENSORS WITH SECOND ROW SPLIT FOLDING SEAT WITH SECURITY PACK WITH SELF COLOURED REAR SPOILER WITH SMART DRIVERS AIRBAG RESTRAINT WITH SPEED CONTROL WITH STANDARD DUTY TERRAIN PACK WITH STANDARD ENGINE COOLING SYSTEM WITH STANDARD REAR SEAT BELTS WITH STANDARD REAR SHOCK ABSORBERS WITH TRIP COMPUTER WITH TYRE PRESSURE SENSORS WITH UNIVERSAL GARAGE DOOR OPENER WITH VARIABLE INTERMITTENT WINDSCREEN WIPER WITH VENTILATED DISC BRAKES ALTERNATOR ID FR3T10300GA DRIVE LINE SHAFT ID FR334K145CD DSO SPEC. ORDER CD 13 EMISSION PROCESS ID FR3A12A650CPD ENGINE TAG ID FG398AA FUEL TANK FR3C9K007BG INSTRUMENT CLUSTER ID FR3310849EF PAINT CODE UA RADIATOR ID FR338005BF STEERING ASSEMBLY ID FR3C3C529BD SUSPENSION FRONT ID (LEFT) FR3C5310DC SUSPENSION REAR ID (LEFT) FR3C18W002FF TRANSMISSION TAG NO. FR3P7000BB TRIM COLOR 1 TRIM TYPE 4 VEHICLE DESCRIPTION FORD MUSTANG 2-DR COUPE GT VEHICLE TYPE P8C WHEEL COVER TRIM FR3C1A096AB WHEEL ID FR3C1007CA WIRING FR3T14A005UC WIRING FR3T14631AC WIRING FR3T14630BC WIRING FR3T14401CC WIRING FR3T14290CD WIRING COUNT 05 BODY: 2-DR. SEDAN BODY DESCRIPTION: GT COUPE CYLINDERS: 8 ENGINE: 5.0 ENGINE TYPE: GASOLINE - PREMIUM FUEL MAKE: FORD MANUFACTURER: FORD MOTOR COMPANY, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: DRIVER AND PASSENGER AIR BAGS SERIES: GT TYPE: PASSENGER CAR
October 3, 20168 yr comment_153199 On 2016-03-18 at 13:28, grufman said: Skriv in ditt reg eller chassienummer här så postar jag bilens build sheet DLG 286
