Efterfråga BUILD SHEET här
On ‎2016‎-‎05‎-‎05 at 10:07, Daan said:
Hej,
CYE 360
Tack på förhand
//Dan
(-) VERSION PACKAGES
17 X 8" PAINTED ALUM W/MACH RIM
4 WHEEL ANTI-LOCK BRAKING SYSTEM
4R33-5310-DA LEFT FRONT COIL
4R33-5310-DA RIGHT FRONT COIL
5R33-5560-GA LEFT REAR COIL
5R33-5560-GA RIGHT REAR COIL
CAMEL VINYL COVER
CDX6+ WITH SPEED SENSOR VOL CONTROL
CONVERTIBLE BOOT-ROOF COVER
ELECTROCHROMIC MIRROR WITH COMPASS
ENGINE COVER - UNDER HOOD
FLATROCK ASSEMBLY PLANT - USA
FOR UNLEADED FUEL
FORD DIVISION DERIVATIVE
FRONT COMFORT PACKAGE C2
FRONT FLOOR CARPET MATS
FRONT SCUFF PLATES - WITH INSERT
GENERIC COUNTRY GROUP 1
HEADER DOME LIGHT LESS MAP LAMP
HIGH PERFORMANCE AUDIO SYSTEM
I/P INSERT - RIBBED ALUMINIUM
LEATHER WRAP/SATIN ALUM SPOKE WHEEL
LESS ACCT STRIPE-BDYSD COLOR
LESS AMBIENT TEMP/SPEED PACK
LESS ANTI-THEFT ALARM
LESS APPEARANCE GROUP
LESS B&A CONTROL CODES ISSUE 030388
LESS BODYSIDE ACCENT STRIPE
LESS CARGO NET - FIA
LESS DAYTIME RUNNING LAMPS
LESS EXTERIOR APPEARANCE PACK
LESS EXTERIOR BODY MOULDINGS
LESS FLEET
LESS FLOOR MATS-FIA
LESS FRONT LICENSE PLATE BRACKET
LESS FULL VEHICLE COVER
LESS IMMERSION HEATER
LESS LIGHTING PACKAGES
LESS REMOTE STARTER - FIA
LESS SAFETY PACKAGE
LESS SMOKERS PACKAGE
LESS SPECIAL BUILD REQUIREMENT
LESS SPEED AUDIBLE WARNING DEVICE
LESS TAPE STRIPES - FIA
LESS TYRE INFLATION KIT
MUSTANG (2005/)
NON ILLUMINATED SUNVISOR - DRIVERS
NON ILLUMINATED SUNVISOR-PASSENGER
NON LOCKING FUEL CAP WITH BP LABEL
NORMAL FUEL FILL
OWNER HAND BOOK PACK
PREMIUM MARKETING TRIM
REAR AXLE LIMITED SLIP DIFFERENTIAL
SATELLITE DIGITAL BROADCAST
SPARE TYRE - T185/60R17
SPORTS FRONT SEAT
UNIQUE MET FINISH FOOT PEDALS PADS
WITH 17" ALUMINIUM MINI SPARE WHEEL
WITH 6 GAUGE INSTUMENT CLUSTER
WITH ANTI-SPIN TRACTION SYSTEM
WITH BONNET SCOOP
WITH CALIFORNIA/GREEN STATE REQ
WITH CENTRE HUB ORNAMENT-FORD OVAL
WITH DRIVER 6 WAY PWR.SEAT ADJUSTER
WITH DRIVER AIR BAG
WITH DRIVERS HEATED SEAT
WITH DRIVERS POWER LUMBAR SUPPORT
WITH ELECTRIC REAR WINDOWS
WITH ENGLISH LANGUAGE LABEL
WITH FRONT FOG LAMPS
WITH HALOGEN HEADLAMP
WITH HEATED PASSENGER SEAT
WITH INTERIOR PACK
WITH LEVEL 'A' INTERIOR DECOR
WITH MESSAGE CENTRE
WITH MPH/KMH SPEEDOMETER
WITH NAAO RADIO FREQUENCY
WITH OVERSPEED WARNING DISABLED
WITH PASS 6 WAY POWER SEAT ADJUSTER
WITH PASSENGER AIR BAG
WITH ROLLED EXHAUST TIPS
WITH SIDE IMPACT PACKAGE
WITH SINGLE REAR WING SPOILER
WITH UPSIZED FRONT STABILIZER BAR
WITH UPSIZED REAR STABLIZER BAR
DSO SPEC. ORDER CD   71
EMISSION PROCESS ID   8R3A12A650NC
ENGINE TAG ID   8S836AA
FUEL TANK   8R339K007AE
INSTRUMENT CLUSTER ID   7R3310849GC
PAINT CODE ZY
RADIATOR ID   4R338005CE
STEERING ASSEMBLY ID   6R333C529AB
SUSPENSION FRONT ID (LEFT)   6R335310DA
SUSPENSION REAR ID (LEFT)   5R335560GB
TRANSMISSION TAG NO.   8R3P7000AA
TRIM COLOR   C
TRIM TYPE   K
VEHICLE DESCRIPTION   FORD  MUSTANG  2-DR  CONVERTIBLE
VEHICLE TYPE   T85
WHEEL COVER TRIM   4R331A096BB
WHEEL ID   4R331007KA
WIRING   8R3T14A005YD
WIRING   8R3T14631BA
WIRING   8R3T14630BA
WIRING   6R3T14407ED
WIRING   8R3T14401FC
WIRING   8R3T14290BA
WIRING COUNT   06
BODY: 2-DR.-CONVERTIBLE
BODY DESCRIPTION: GT
CYLINDERS: 8
ENGINE: 4.6
ENGINE TYPE: OHC
MAKE: FORD
MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA
PLANT: AAI: FLAT ROCK, MICHIGAN
RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS PLUS DRIVER AND PASSENGER SIDE AIR BAGS, CURTAINS, OR CANOPIES
SERIES: ZF
TYPE: PASSENGER CAR
  • Svar 113
  • Visingar 21k
  • (-) VERSION PACKAGES 18 X 9.5 ALLOY WHEEL 2007 JOB #1 PROGRAM CONTROL 4 WHEEL ANTI-LOCK BRAKING SYSTEM 50 STATE EMISSION REQUIREMENTS 7R3V-5560-KA LEFT REAR COIL 7R3V-5560-KA RIGHT REAR CO
  • AXLE TAG RATING TYPE   V255D CLUSTER FIN ID   7R3V63044D70AGSMGN DSO SPEC. ORDER CD   71 EMISSION PROCESS ID   7R3A12A650AFF ENGINE TAG ID   7S253CA FUEL TANK   7R3V9K007BF INSTRUMENT CLUS
  • (-) VERSION PACKAGES  18 X 9.5 ALLOY WHEEL  2007 JOB #2 PROGRAM CONTROL  4 WHEEL ANTI-LOCK BRAKING SYSTEM  50 STATE EMISSION REQUIREMENTS  7R3V-5560-KA LEFT REAR COIL  7R3V-5560-KA RIGHT R
On ‎2016‎-‎05‎-‎11 at 08:05, Silverstallion said:
XLE636          1ZVHT82H155142232
Tack.
/Johan
2005 JOB NO.1 PROGRAM CONTROL
235/55 ZR 17 ALL SEASON TYRE
4550 LB. GVWR
4R33 5310 FA LEFT FRONT COIL
4R33-5310-FA RIGHT FRONT COIL
5R33-5560-BA LEFT REAR COIL
5R33-5560-BA RIGHT REAR COIL
COLOUR ACCENT INTERIOR PACK #1
FOR UNLEADED FUEL
FRONT FLOOR MATS - MONOTONE C/K
LESS CONVERTIBLE ROOF COVER
LESS ENGINE OIL COOLER
LESS FLEET
LESS MILITARY VEHICLES
LESS POWER STEERING OIL COOLER
LESS SPECIAL LANGUAGE LABEL
MEDIUM DUTY BATTERY
MUSTANG (2005/)
NORMAL FUEL FILL
PERIMETER ALARM W/INTRUDER/SENSOR
SPORTS FRONT SEAT
U.S. SALES
WITH DRIVERS POWER MIRROR
WITH FIXED REAR SIDE WINDOW
WITH HANDLING SUSPENSION
WITH HEATED REAR WINDOW
WITH MESSAGE CENTRE
WITH ON-BOARD DIAGNOSTIC SYSTEM
WITH PASS 2 WAY MANUAL SEAT ADJUST
WITH PASSENGER POWER CONVEX MIRROR
WITH SIDE AIR BAG - DRIVERS SIDE
WITH SIDE AIR BAG - PASSENGER SIDE
WITH SUB WOOFER SOUND SYSTEM
AXLE TAG RATING TYPE   V247A
CLUSTER FIN ID   4R3363044D70CFSMEN
DRIVE LINE SHAFT ID   4R334K145AH
DSO SPEC. ORDER CD   24
EMISSION PROCESS ID   5R3A12A650ACD
ENGINE TAG ID   5S837AA
FUEL TANK   4R339K007BM
INSTRUMENT CLUSTER ID   5R3310849GC
PAINT CODE TL
STEERING ASSEMBLY ID   5R333200BB  4R333C529AE
SUSPENSION FRONT ID (LEFT)   4R335310FB
SUSPENSION REAR ID (LEFT)   5R335560BC
TRANSMISSION TAG NO.   4R337003AG
TRIM COLOR   R
TRIM TYPE   K
VEHICLE DESCRIPTION   MUSTANG  2-DR.  SEDAN  COUPE  GT
VEHICLE TYPE   T82
WHEEL ID   4R331007CD  4R331007KA
WIRING   4R3T14A005EAE
WIRING   4R3T14631CM
WIRING   4R3T14630BL
WIRING   4R3T14407BP
WIRING   4R3T14401CN
WIRING   4R3T14290DJ
WIRING COUNT   06
BODY: 2-DR.-COUPE
CYLINDERS: 8
ENGINE: 4.6
ENGINE TYPE: OHC
MAKE: FORD
SERIES: ZF
TYPE: PASSENGER CAR
On ‎2016‎-‎05‎-‎17 at 18:23, zingonr1 said:
CUG 498
Och tack på förhand.
/ Ingemar
4550 LB. GVWR
4R33-5310-CA LEFT FRONT COIL
4R33-5310-CA RIGHT FRONT COIL
8.0 X 17" MACHINED ALUMINIUM WHEEL
BLACK VINYL COVER
FOR UNLEADED FUEL
LESS FLEET
LESS TRIM PACK
MEDIUM DUTY BATTERY
MUSTANG (2005/)
NORMAL FUEL FILL
SPORTS FRONT SEAT
U.S. SALES
WITH LOCKING WHEEL LUG NUT KIT
WITH MESSAGE CENTRE
DSO SPEC. ORDER CD   27
FUEL TANK   4R339K007BN
PAINT CODE TL
SUSPENSION FRONT ID (LEFT)   5R335310CA
TRIM COLOR   W
TRIM TYPE   K
VEHICLE DESCRIPTION   MUSTANG  2-DR.  SEDAN  CONVERTIBL
VEHICLE TYPE   T85
WHEEL COVER TRIM   4R331A108AB
WHEEL ID   4R331007JE  4R331007KA
WIRING   4R3T14A005NAM
WIRING   4R3T14631BM
WIRING   4R3T14630BL
WIRING   4R3T14407DA
WIRING   4R3T14401DN
WIRING   5R3T14290DA
WIRING COUNT   06
CYLINDERS: 8
ENGINE: 4.6
ENGINE TYPE: OHC
MAKE: FORD
SERIES: ZF
TYPE: PASSENGER CAR
On 2016-03-17 at 13:28, grufman said:
Skriv in ditt reg eller chassienummer här så postar jag bilens build sheet
Woz 250
  • 1 month later...
Hej,
CLN767
Tack,
Johan
SEL664
  • 1 month later...
Då ska vi se vad som dyker upp ???
1ZVBP8EM8D5229952
Nyfiken i en strut?Tack på förhand Janne W
On 6 juni 2016 at 22:03, u43jln said:
Woz 250
2006 JOB #1 PROGRAM CONTROL
4450 LB. GVW
CENTER DOME LAMP W/O MAP LIGHT
FOR UNLEADED FUEL
LESS FLEET
LESS SIDE IMPACT PACKAGE
LESS TRIM PACK
MUSTANG (2005/)
NON/COLOR (ROOF)
NORMAL FUEL FILL
SPORTS FRONT SEAT
STANDARD DUTY BATTERY
U.S. SALES
WITH DRIVER AIR BAG
WITH MESSAGE CENTRE
AXLE TAG RATING TYPE   V247E
CLUSTER FIN ID   6R3363044D70CGSMEN
DRIVE LINE SHAFT ID   5R334K145AA
EMISSION PROCESS ID   6R3A12A650GB
ENGINE TAG ID   6S837AA
INSTRUMENT CLUSTER ID   6R3310849GD
PAINT CODE G9
STEERING ASSEMBLY ID   6R333200BF  6R333C529AB
SUSPENSION FRONT ID (LEFT)   5R335310FA
TRANSMISSION TAG NO.   6R337003AA
TRIM COLOR   W
TRIM TYPE   K
VEHICLE DESCRIPTION   MUSTANG  2-DR  COUPE  GT
VEHICLE TYPE   T82
WHEEL ID   4R331007KA
WIRING   6R3T14290BB
WIRING COUNT   01
BODY: 2-DR.-COUPE
CYLINDERS: 8
ENGINE: 4.6
ENGINE TYPE: OHC
MAKE: FORD
RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS - APPLIES TO ALL PASSENGER CARS
SERIES: ZF
TYPE: PASSENGER CAR
On 19 juli 2016 at 20:01, ahnmarker said:
Hej,
CLN767
Tack,
Johan
(+)"ARE"
4550 LB. GVWR
4R33 5310 GA LEFT FRONT COIL
4R33-5310-GA RIGHT FRONT COIL
5R33-5560-CA LEFT REAR COIL
5R33-5560-CA RIGHT REAR COIL
ARABIC LANGUAGE LABEL
EXPORT FUEL FILL
EXPORT SALES
FOR UNLEADED FUEL
GENERIC COUNTRY GROUP 11
LESS FLEET
LESS TRIM PACK
MEDIUM DUTY BATTERY
MUSTANG (2005/)
NON/COLOR (ROOF)
SPECIAL BUILD REQUIREMENT - A
SPORTS FRONT SEAT
WITH ENGINE OIL COOLER
WITH GCC RADIO FREQUENCY
WITH HIGH AMBIENT TEMP/SPEED PACK
WITH HIGH SPEED WARNING CHIME
WITH KMH/MPH SPEEDOMETER
WITH MESSAGE CENTRE
WITH SMOKERS PACKAGE
AXLE TAG RATING TYPE   V237C
CLUSTER FIN ID   5R3363044D70ABSMEN
DSO SPEC. ORDER CD   9Y
EMISSION PROCESS ID   5R3A12A650AHE
ENGINE TAG ID   5S836AA
FUEL TANK   5R339K007AD
INSTRUMENT CLUSTER ID   5R3310849HC
PAINT CODE SN
STEERING ASSEMBLY ID   5R333200BB  5R333C529AA
SUSPENSION FRONT ID (LEFT)   5R335310GA
SUSPENSION REAR ID (LEFT)   5R335560CC
TRANSMISSION TAG NO.   4R3P7000AC
TRIM COLOR   H
TRIM TYPE   K
VEHICLE TYPE   T82
WIRING   5R3T14A005EF
WIRING   4R3T14407BP
WIRING   4R3T14401CN
WIRING   5R3T14290BA
WIRING COUNT   04
BODY: 2-DR.-COUPE
CYLINDERS: 8
ENGINE: 4.6
ENGINE TYPE: OHC
MAKE: FORD
SERIES: ZF
TYPE: PASSENGER CAR
On 24 juli 2016 at 23:30, LYA said:
SEL664
4550 LB. GVWR
FOR UNLEADED FUEL
LESS FLEET
LESS TRIM PACK
MEDIUM DUTY BATTERY
MUSTANG (2005/)
NON/COLOR (ROOF)
NORMAL FUEL FILL
SPORTS FRONT SEAT
U.S. SALES
WITH MESSAGE CENTRE
DSO SPEC. ORDER CD   56
ENGINE TAG ID   5S691AA
PAINT CODE TK
TRIM COLOR   W
TRIM TYPE   K
VEHICLE TYPE   T82
WIRING   4R3T14A005FAE
WIRING   4R3T14631CM
WIRING   4R3T14630BL
WIRING   4R3T14407BP
WIRING   4R3T14401DN
WIRING   4R3T14290BL
WIRING COUNT   06
BODY: 2-DR.-COUPE
CYLINDERS: 8
ENGINE: 4.6
ENGINE TYPE: OHC
MAKE: FORD
SERIES: ZF
TYPE: PASSENGER CAR
On 2 september 2016 at 10:47, Henrixon said:
BDR 315
/Peter
18X8.5"POL CAST ALUM BRT MACH WHEEL
4450 LB. GVW
CENTRE HUB ORN - PONY LOGO/SPINNER
FOR UNLEADED FUEL
LESS FLEET
LESS TRIM PACK
MUSTANG (2005/)
NON/COLOR (ROOF)
NORMAL FUEL FILL
SPORTS FRONT SEAT
U.S. SALES
WITH DRIVER AIR BAG
WITH MESSAGE CENTRE
DSO SPEC. ORDER CD   72
PAINT CODE D6
STEERING ASSEMBLY ID   6R333200CL  6R333C529AB
TRIM COLOR   W
TRIM TYPE   K
VEHICLE TYPE   T82
WHEEL COVER TRIM   5R3J1A096BA
WHEEL ID   4R331007KA  6R3J1007DA
WIRING   6R3T14290BB
WIRING COUNT   01
BODY: 2-DR.-COUPE
CYLINDERS: 8
ENGINE: 4.6
ENGINE TYPE: OHC
MAKE: FORD
SERIES: ZF
TYPE: PASSENGER CAR
1ZVBP8EM8D5229952
17" X 5 MINI STEEL SPARE WHEEL
2013 JOB #1 PROGRAM CONTROL
7 X 17" PAINTED ALUMINIUM WHEEL
ANALOGUE AUDIO BROADCAST
BLACK VINYL COVER
BR33-5560-A* LEFT REAR COIL SPRING
BR33-5560-A* RIGHT REAR COIL SPRING
DOOR ENTRY R/CONT UNIT - 2 KEYS
DRIVER BLACK POWER MIRROR
FLEET
FOR UNLEADED FUEL
FREQUENCY - 315MHZ
FRONT DOOR SILL PROTECTION - BLACK
FRONT LICENSE PLATE HOLDER DELUXE
HIGH INTENSITY DISCHARGE HEADLAMP
I/P INSERT - BLACK
LEATHER STEERING WHEEL
LESS BODY TU-TONE PAINT
LESS BONNET SCOOP
LESS CAMERA
LESS CONVENIENCE GROUP
LESS DIFFERENTIAL COOLER COVER
LESS DRIVER SEAT LUMBAR SUPPORT
LESS ENGINE COOLING SYSTEM
LESS EXHAUST TIPS
LESS FLOOR MATS-FIA
LESS FRONT FOG LAMPS
LESS FRONT LIP SPOILER - FIA
LESS FUEL LABEL
LESS GARAGE DOOR OPENER
LESS INTERIOR PACK
LESS MEDIA/ENTERTAINMENT PACKAGE
LESS OPTIONAL EQUIPMENT PACK
LESS PERFORMANCE PACK
LESS PREMIUM BRAKES
LESS REAR MUDFLAPS
LESS REVERSE PROXIMITY SENSOR
LESS SAFETY PACKAGE
LESS SIDE SCOOP - FIA
LESS SPECIAL EQUIPMENT PACKAGE
LESS SPOILER
LESS SPOILER - FIA
LESS SUN ROOF
LESS SYNC
LESS TEMP CONTROL DRIVER SEAT
LESS TEMP CONTROL PASSENGERS SEAT
LESS WINDOW LOUVERS - FIA
MUSTANG (2005/)
NORMAL FUEL FILL
PASSENGER BLACK POWER MIRROR
SIDE AIR BAG - 1ST ROW ONLY
SPORTS FRONT SEAT
STANDARD FOOT PEDAL PAD DESIGN
TYRE INFLATION MONITOR
WITH 4 GAUGE INSTRUMENT CLUSTER
WITH AM/FM CD PLAYER
WITH BASE INTERIOR DECOR
WITH CONVENTIONAL HEADLAMP CONTROL
WITH DRIVER 4 WAY MNL.SEAT ADJUSTER
WITH FRONT 4 WAY HEADREST
WITH FRONT SIDE AIR BAG RESTRAINT
WITH PREMIUM SOUND SYSTEM
WITH PRISMATIC MIRROR
WITH SOFT FEEL HANDBRAKE GRIP
ALTERNATOR ID   BR3T10300EC
AXLE TAG RATING TYPE   S201C
DRIVE LINE SHAFT ID   BR334602AC
EMISSION PROCESS ID   DR3A12A650GE
ENGINE TAG ID   1G372CA
FUEL TANK   CR339K007AC
INSTRUMENT CLUSTER ID   DR3310849AC
PAINT CODE HP
RADIATOR ID   BR338005AA
STEERING ASSEMBLY ID   6R333C529AC
SUSPENSION FRONT ID (LEFT)   BR335310BB
SUSPENSION REAR ID (LEFT)   BR335560AB
TRANSMISSION TAG NO.   BR3P7000AA
TRIM COLOR   W
TRIM TYPE   1
VEHICLE TYPE   P8E
WHEEL ID   AR331007AB  9R331007AA
WIRING   BR3T14407AAB
WIRING   DR3T14A005LE
WIRING   DR3T14631CC
WIRING   DR3T14630AC
WIRING   DR3T14401AF
WIRING   DR3T14290AD
WIRING COUNT   06
BODY: 2-DR. SEDAN
BODY DESCRIPTION: V6 CONVERTIBLE
CYLINDERS: 6
ENGINE: 3.7
ENGINE TYPE: TI-VCT GASOLINE
MAKE: FORD
RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) - VALID FOR F/CMVSS 500 LOW SPEED VEHICLES ONLY
SERIES: V6
TYPE: PASSENGER CAR
On 8 september 2016 at 21:59, Gunnar A said:
alz 948   Tack på förhand Gunnar A
7R3V-5560-KA RIGHT REAR COIL
ACCENT STRIPE - PERFORM WHITE
BLACK CLOTH COVER
CENTRE HUB - VERSION A
I/P INSERT - TITANIUM FINISH
INTERIOR UPGRADE PACKAGE B
LESS BONNET SCOOP
LESS EXHAUST TIPS
LESS FLEET
LESS FLOOR MATS-FIA
LESS FUEL FILLER DOOR - FIA
LESS SPARE TYRE
LESS SPARE WHEEL
MEDIUM DUTY BATTERY
MUSTANG (2005/)
NORMAL FUEL FILL
SPORTS FRONT SEAT
STEERING WHEEL - 3 SPOKE LEATHER
SVT RACING STRIPES
U.S. SALES
WITH DRIVER AIR BAG
WITH FLUSH SPOILER
WITH INTERIOR PACK 2
WITH MESSAGE CENTRE
WITH SVE FRONT FOG LAMPS/AUX I/P
WITH TYRE INFLATION KIT
AXLE TAG RATING TYPE   V255J
CLUSTER FIN ID   7R3V63044D70BASMGN
DSO SPEC. ORDER CD   58
FUEL TANK   7R3V9K007BG
INSTRUMENT CLUSTER ID   7R3V10849AD
PAINT CODE D3
RADIATOR ID   7R3V8009BC
STEERING ASSEMBLY ID   7R3V3200DD  6R333C529AB
SUSPENSION REAR ID (LEFT)   7R3V5560KB
TRANSMISSION TAG NO.   7R3V7003AK
TRIM COLOR   R
TRIM TYPE   G
VEHICLE DESCRIPTION   FORD  MUSTANG  2-DR  SHELBY  CONVE
VEHICLE TYPE   T89
WHEEL COVER TRIM   2M5V1A096AB
WIRING   7R3V14A005SAB
WIRING   5R3T14631BA
WIRING   6R3T14407ED
WIRING   7R3T14401DAE
WIRING   7R3V14290EAA
WIRING COUNT   05
CYLINDERS: 8
ENGINE: 5.4
ENGINE TYPE: DOHC EFI
MAKE: FORD
TYPE: PASSENGER CAR
11 timmar sedan, Perssson said:
DFH627
/Magnus
8.5 X 19" PAINTED ALUMINIUM WHEEL
BR33-5560-C* LEFT REAR COIL SPRING
BR33-5560-C* RIGHT REAR COIL SPRING
DRIVERS C/K POWER MIRROR
ELECT PREM AM/FM STRO/DISC/CLOCK
ELECTRO MIRROR WITH COMPASS AND MIC
FOR UNLEADED FUEL
FRONT SCUFF PLATES - ILLUMINATED
I/P INSERT - METALLIC FINISH
LEATHER WRAP WITH REDUNDANT CONTROL
LESS CAMERA
LESS DECKLID PANEL - FIA
LESS FLEET
LESS HOOD SCOOP - FIA
LESS INTERIOR PACK
LESS PREMIUM BRAKES
LESS REAR MUDFLAPS
LESS SAFETY PACKAGE
LESS SPOILER - FIA
LESS SUN ROOF
LIGHTING PACKAGE LEVEL A
MUSTANG (2005/)
NON/COLOR (ROOF)
NORMAL FUEL FILL
PASSENGER POWER MIRROR
SPARE TYRE - T185/55R18
SPORTS FRONT SEAT
WITH 18" ALUMINIUM MINI SPARE WHEEL
WITH 49 STATE/NON GREEN STATE REQ
WITH AUTOMATIC HEADLAMP CONTROL
WITH LEATHER HANDBRAKE GRIP
WITH MEDIA GATEWAY MODULE
WITH MEDIA GATEWAY PACKAGE
WITH REAR HEAVY DUTY STABILIZER BAR
ALTERNATOR ID   BR3T10300KC
CLUSTER FIN ID   BR3310849EE
EMISSION PROCESS ID   BR3A12A650AHG
ENGINE TAG ID   1G397AA
FUEL TANK   BR339K007AE
INSTRUMENT CLUSTER ID   BR3310849EE
PAINT CODE HP
SUSPENSION FRONT ID (LEFT)   BR335310FB
SUSPENSION REAR ID (LEFT)   BR335560CB
TRANSMISSION TAG NO.   BR337003AF
TRIM COLOR   W
TRIM TYPE   4
VEHICLE DESCRIPTION   FORD  MUSTANG  2-DR  COUPE  GT
VEHICLE TYPE   P8C
WHEEL ID   AR331007EB  BR331007AB
WIRING   BR3T14A005CE
WIRING   BR3T14631BA
WIRING   BR3T14630BA
WIRING   BR3T14407AA
WIRING   BR3T14401GF
WIRING   BR3T14290EE
WIRING COUNT   06
BODY: 2-DR. SEDAN
BODY DESCRIPTION: GT COUPE
CYLINDERS: 8
ENGINE: 5.0
ENGINE TYPE: GASOLINE
MAKE: FORD
SERIES: GT
TYPE: PASSENGER CAR
33 minuter sedan, grufman said:
Såja. Fyll på med mer nu :-)
Tjena och tack på förhand :-)
TDU 844
/Jimmy
TDU 844
/Jimmy
4550 LB. GVWR
5R33-5560-FA LEFT REAR COIL
5R33-5560-FA RIGHT REAR COIL
BLACK VINYL COVER
FOR UNLEADED FUEL
LESS FLEET
LESS FLOOR MATS-FIA
LESS INTERIOR PACK
MUSTANG (2005/)
NORMAL FUEL FILL
SPORTS FRONT SEAT
U.S. SALES
WITH BONNET SCOOP
WITH DRIVER AIR BAG
WITH MESSAGE CENTRE
AXLE TAG RATING TYPE   V237V
CLUSTER FIN ID   7R3363044D70HASMEN
DRIVE LINE SHAFT ID   6R334K145AD
DSO SPEC. ORDER CD   52
EMISSION PROCESS ID   7R3A12A650ALC
ENGINE TAG ID   7S837BB
FUEL TANK   7R339K007AF
PAINT CODE G2
STEERING ASSEMBLY ID   7R333200CB  6R333C529AB
SUSPENSION FRONT ID (LEFT)   6R335310CA
SUSPENSION REAR ID (LEFT)   5R335560FB
TRANSMISSION TAG NO.   7R337003AC
TRIM COLOR   W
TRIM TYPE   K
VEHICLE TYPE   T85
WHEEL ID   4R331007KA
WIRING   7R3T14A005PAE
WIRING   5R3T14631BA
WIRING   6R3T14407ED
WIRING   7R3T14401CAF
WIRING   7R3T14290BA
WIRING COUNT   05
CYLINDERS: 8
ENGINE: 4.6
ENGINE TYPE: OHC
MAKE: FORD
SERIES: ZF
TYPE: PASSENGER CAR
21 minuter sedan, Farfar said:
Hei.
1FA6P8CF3F5304445
På forhånd takk.
M.v.h.   Trond
19 X 8.5 PREM PAINTED ALUM WHEEL
2 WAY REAR HEADRESTRAINT- LVL II
255/40R19 W
4720 LB. GVW
7000 RPM TACHOMETER
A/C REFRIGERANT-R134A
AIR CURTAIN RESTRNT LH
AIR CURTAIN RESTRNT RH
ALL WEATHER FLOOR MATS - FIA
BLT/D&P FRT/1&2 ROW/D/P KNE
CENTRE CONSOLE-LEVEL 2
CENTRE HUB ORN - HORSE AND BAR
CUP HOLDERS (2) - ROW 1
DUAL EXHAUST
DUAL NOTE ELECTRIC HORN - LEVEL 2
DUAL POWER HEATED EXTERIOR MIRRORS
ELECTRIC OPERATED REAR VIEW MIRROR
EQUIPMENT PACKAGE 11
EXTERIOR PAINT - SOLID
FEATURE CONTENT GROUP 1
FILTER COWL INTAKE - ODOUR
FIXED FOOT PEDALS
FOR UNLEADED FUEL
FR3C 5310 D* LEFT/FRONT COIL
FR3C 5310 D* RIGHT/FRONT COIL
FR3C-5560-A* LEFT REAR COIL
FR3C-5560-A* RIGHT REAR COIL
FREQUENCY - 902 MHZ
FRONT BUMPER-PLASTIC-PERFORMANCE
FRONT FOG LAMPS-LED
GRILLE - MOULDED IN COLOUR
GRILLE-LOWER MESH DK SLF CLR
GT SALES BADGE
HUMAN MACHINE INTERFACE 3
I/P INSERT - DARK ALUMINIUM
KEYLESS ENTRY/START - PASSIVE
KIT - TYRE REPAIR SERVICE
LESS - BTSI MANUAL OVERRIDE
LESS ACOUSTICAL WARNING SYSTEM
LESS BATTERY CABLES
LESS BLIND SPOT INFORMATION SYSTEM
LESS CONSOLE ASHTRAY
LESS COOLERS - POWERTRAIN
LESS DEPLOYABLE BONNET
LESS DIVERSITY ANTENNA
LESS FIRE EXTINGUISHER FIXINGS
LESS FLEET
LESS FRONT TOWING HOOK
LESS HEADLAMP LEVELLING
LESS ICE NOISE REDUCTION
LESS INSTRUMENT GAUGES
LESS INTERIOR PACK
LESS LICENSE PLATE BRACKET - REAR
LESS MIRROR GLASS ETCHING
LESS REAR PARKING AID
LESS SECONDARY SECURITY SYSTEM
LESS SPARE TYRE
LESS SPARE WHEEL
LESS SPECIALTY PACKAGES
LESS SUN ROOF
LESS TOOL KIT
LESS TRACK PACK
LESS TRANSMISSION OIL COOLER
LESS WARNING DISPLAY
MECHANICAL HAND OPERATED PARK BRAKE
MID AUDIO + CD + SDARS
MIDLINE SOUND SYSTEM
MINI OVERHEAD CNSL W/SUNGLASS BIN
MODULE/GPS ANTENNA
MUSTANG
NAAO MARKET DERIVATIVE
NON LOCKING CAPLESS FUEL FILL
NON LOCKING LUG NUTS
NON/COLOR (ROOF)
NORMAL FUEL FILL
POWER DOOR LOCK WITH ELEC RELEASE
POWER FRONT WINDOWS ONE TOUCH UP/DO
POWER POINT CONVERTER (230V/150W)
REAR BUMPER - PLASTIC UNPAINTED
REAR VIEW CAMERA-FIXED
S/BELT LOCKING RETRACTION - 3 POINT
SEAT BELT PRETENSIONERS DRV/PASS
SPORTS FRONT SEAT
STANDARD DUTY FRONT COIL SPRING
SYNC II
TAIL LAMPS - LED REAR
TRND MNI PRF OV MLD PBL (A-L)
WITH AIR PURIFIER SENSOR
WITH AMBIENT LIGHTING-INTERIOR
WITH AUTOMATIC HEADLAMP ON/OFF
WITH BELTMINDER
WITH BLACK DOOR FRAME MOULDING
WITH BODY COLOURED EXTERIOR MIRROR
WITH BONNET SCOOP
WITH BRAKE EMERGENCY ASSIST
WITH CHROME EXHAUST PIPE EXTENSION
WITH CONVENTIONAL REAR SEAT
WITH COURTESY LIGHT DELAY
WITH DRIVER SEAT BACK MAP POCKET
WITH DRIVERS HEATED AND COOLED SEAT
WITH ELECTRIC POWER STEERING
WITH ENGINE IMMOBILIZER - INTEGRAL
WITH FIXED REAR VENT QUARTER WINDOW
WITH FRONT LICENCE PLATE BRACKET
WITH FRONT STABILIZER BAR
WITH HIGH SERIES BRAKES
WITH HIGH SERIES CLUSTER
WITH HILL LAUNCH ASSIST
WITH ILLUMINATED SUNVISOR - DRIVERS
WITH ILLUMINATED SUNVISOR-PASSENGER
WITH INDEPENDANT REAR SUSPENSION
WITH ISOFIX HARD POINT ATTACHMENT
WITH LAMINATED WINDSCREEN
WITH LEATHER/COLOUR KEYED GEAR KNOB
WITH LEVEL 2 DOOR TRIM PANEL
WITH LOAD FLOOR CARPET - THIN
WITH LUNAR CONTRAST STITCHING
WITH MANUAL SHIFT AUTO TRANS
WITH MAP READING LIGHT
WITH NAVIGATION SYSTEM
WITH PASS HEATED AND COOLED SEAT
WITH PERFORMANCE FRONT FENDERS
WITH REAR STABLIZER BAR
WITH REAR WINDOW AERIAL
WITH REMOTE ALARM SYSTEM - PATS
WITH REMOTE STARTER
WITH ROLLOVER CURTAIN AND SENSORS
WITH SECOND ROW SPLIT FOLDING SEAT
WITH SECURITY PACK
WITH SELF COLOURED REAR SPOILER
WITH SMART DRIVERS AIRBAG RESTRAINT
WITH SPEED CONTROL
WITH STANDARD DUTY TERRAIN PACK
WITH STANDARD ENGINE COOLING SYSTEM
WITH STANDARD REAR SEAT BELTS
WITH STANDARD REAR SHOCK ABSORBERS
WITH TRIP COMPUTER
WITH TYRE PRESSURE SENSORS
WITH UNIVERSAL GARAGE DOOR OPENER
WITH VARIABLE INTERMITTENT WINDSCREEN WIPER
WITH VENTILATED DISC BRAKES
ALTERNATOR ID   FR3T10300GA
DRIVE LINE SHAFT ID   FR334K145CD
DSO SPEC. ORDER CD   13
EMISSION PROCESS ID   FR3A12A650CPD
ENGINE TAG ID   FG398AA
FUEL TANK   FR3C9K007BG
INSTRUMENT CLUSTER ID   FR3310849EF
PAINT CODE UA
RADIATOR ID   FR338005BF
STEERING ASSEMBLY ID   FR3C3C529BD
SUSPENSION FRONT ID (LEFT)   FR3C5310DC
SUSPENSION REAR ID (LEFT)   FR3C18W002FF
TRANSMISSION TAG NO.   FR3P7000BB
TRIM COLOR   1
TRIM TYPE   4
VEHICLE TYPE   P8C
WHEEL COVER TRIM   FR3C1A096AB
WHEEL ID   FR3C1007CA
WIRING   FR3T14A005UC
WIRING   FR3T14631AC
WIRING   FR3T14630BC
WIRING   FR3T14401CC
WIRING   FR3T14290CD
WIRING COUNT   05
BODY: 2-DR. SEDAN
CYLINDERS: 8
ENGINE: 5.0
ENGINE TYPE: GASOLINE - PREMIUM FUEL
MAKE: FORD
MANUFACTURER: FORD MOTOR COMPANY, USA
RESTRAINT: DRIVER AND PASSENGER AIR BAGS
SERIES: GT
TYPE: PASSENGER CAR
