Pia Sundsvall October 4, 2016 Report October 4, 2016 On 2016-03-18 at 13:28, grufman said: Skriv in ditt reg eller chassienummer här så postar jag bilens build sheet DLG 286...Pia i Sundsvall/tack. Citera
olechr October 30, 2016 Report October 30, 2016 On 2016-03-18 at 13:28, grufman said: Skriv in ditt reg eller chassienummer här så postar jag bilens build sheet Hej! Tacksam för info ang SZD628. Citera
Tommy Iggesund December 4, 2016 Report December 4, 2016 TFH 085Skickat från min iPad med Tapatalk Citera
NilsB December 5, 2016 Report December 5, 2016 Hej,är du snäll och kollar denna bil.... tack // Nils 1ZVBP8CF5E5214024 Citera
grufman March 14, 2017 Author Report March 14, 2017 On 2016-09-22 at 21:46, nafets said: cfk487 Tack på förhand/Stefan 17 X 8" PAINTED ALUM W/MACH RIM 2005 JOB NO.1 PROGRAM CONTROL 235/55 ZR 17 ALL SEASON TYRE 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4550 LB. GVWR 4R33 5310 FA LEFT FRONT COIL 4R33-5310-FA RIGHT FRONT COIL 50 STATE EMISSION REQUIREMENTS 5R33-5560-CA LEFT REAR COIL 5R33-5560-CA RIGHT REAR COIL CDX6+ WITH SPEED SENSOR VOL CONTROL CENTER DOME LAMP W/O MAP LIGHT FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS GENERIC COUNTRY GROUP 1 HIGH PERFORMANCE AUDIO SYSTEM LEATHER WRAP/SATIN ALUM SPOKE WHEEL LESS AMBIENT TEMP/SPEED PACK LESS ANTI-THEFT ALARM LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS ENGINE OIL COOLER LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS FRONT LICENSE PLATE BRACKET LESS IMMERSION HEATER LESS MILITARY VEHICLES LESS POWER STEERING OIL COOLER LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPECIAL LANGUAGE LABEL LESS SPEED AUDIBLE WARNING DEVICE LESS TRIM PACK MEDIUM DUTY BATTERY MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON/COLOR (ROOF) NORMAL FUEL FILL OWNER HAND BOOK PACK PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SPARE TYRE - T185/60R17 SPORTS FRONT SEAT U.S. SALES WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVERS POWER LUMBAR SUPPORT WITH DRIVERS POWER MIRROR WITH FIXED REAR SIDE WINDOW WITH FRONT FOG LAMPS WITH HANDLING SUSPENSION WITH HEATED REAR WINDOW WITH LEVEL 'A' INTERIOR DECOR WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH ON-BOARD DIAGNOSTIC SYSTEM WITH OVERSPEED WARNING DISABLED WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER POWER CONVEX MIRROR WITH SIDE AIR BAG - DRIVERS SIDE WITH SIDE AIR BAG - PASSENGER SIDE WITH SIDE IMPACT PACKAGE WITH SINGLE REAR WING SPOILER AXLE TAG RATING TYPE V247C CLUSTER FIN ID 5R3363044D70ABSMEN DRIVE LINE SHAFT ID 4R334K145AH DSO SPEC. ORDER CD 41 EMISSION PROCESS ID 5R3A12A650ACD ENGINE TAG ID 5S837AA FUEL TANK 4R339K007BN INSTRUMENT CLUSTER ID 5R3310849GC PAINT CODE TL RADIATOR ID 4R338005CE STEERING ASSEMBLY ID 5R333200BB 4R333C529AE SUSPENSION FRONT ID (LEFT) 5R335310FA SUSPENSION REAR ID (LEFT) 5R335560CC TRANSMISSION TAG NO. 4R337003AG TRIM COLOR W TRIM TYPE K VEHICLE DESCRIPTION MUSTANG 2-DR COUPE GT VEHICLE TYPE T82 WHEEL ID 4R331007CD 4R331007KA WIRING 5R3T14A005FE WIRING 4R3T14631CM WIRING 4R3T14630BL WIRING 4R3T14407BP WIRING 4R3T14401DN WIRING 5R3T14290BA WIRING COUNT 06 BODY: 2-DR.-COUPE BODY DESCRIPTION: GT CYLINDERS: 8 ENGINE: 4.6 ENGINE TYPE: OHC MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS PLUS DRIVER AND PASSENGER SIDE AIR BAGS, CURTAINS, OR CANOPIES SERIES: ZF TYPE: PASSENGER CAR Citera
grufman March 14, 2017 Author Report March 14, 2017 On 2016-10-03 at 14:26, Pia Sundsvall said: DLG 286 (-) VERSION PACKAGES 8.5 X 19" PAINTED ALUMINIUM WHEEL BLACK CLOTH COVER BR33-5560-E* LEFT REAR COIL SPRING BR33-5560-E* RIGHT REAR COIL SPRING CENTRE HUB ORN - PONY LOGO/SPINNER CONVERTIBLE BOOT-ROOF COVER DRIVERS C/K POWER MIRROR ELECT PREM AM/FM STRO/DISC/CLOCK ELECTRO MIRROR WITH COMPASS AND MIC ENGINE COVER - UNDER HOOD FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR CARPET MATS FRONT SCUFF PLATES - ILLUMINATED GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP HIGH INTENSITY DISCHARGE HEADLAMP I/P INSERT - DARK ALUMINIUM LEATHER WRAP WITH REDUNDANT CONTROL LESS ACCT STRIPE-BDYSD COLOR LESS APPEARANCE GROUP LESS BODYSIDE ACCENT STRIPE LESS CAMERA LESS CONVENIENCE GROUP LESS DAYTIME RUNNING LAMPS LESS DECKLID PANEL - FIA LESS FLEET LESS FRONT LICENSE PLATE BRACKET LESS FRONT LIP SPOILER - FIA LESS FULL VEHICLE COVER LESS GARAGE DOOR OPENER LESS HOOD SCOOP - FIA LESS IMMERSION HEATER LESS PERFORMANCE PACK LESS PREMIUM BRAKES LESS REAR MUDFLAPS LESS REMOTE STARTER - FIA LESS SIDE SCOOP - FIA LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPEED AUDIBLE WARNING DEVICE LESS SPOILER - FIA LESS SUN ROOF LESS TAPE STRIPES - FIA LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT LESS TYRE INFLATION KIT LESS WINDOW LOUVERS - FIA LIGHTING PACKAGE LEVEL A MUSTANG (2005/) NORMAL FUEL FILL OWNER HAND BOOK PACK PASSENGER POWER MIRROR PERIMETER ALARM W/INTRUDER/SENSOR PREMIUM MARKETING TRIM SATELLITE DIGITAL BROADCAST SIDE AIR BAG - 1ST ROW ONLY SPARE TYRE - T185/55R18 SPORTS FRONT SEAT UNIQUE MET FINISH FOOT PEDALS PADS WITH 18" ALUMINIUM MINI SPARE WHEEL WITH 49 STATE/NON GREEN STATE REQ WITH 6 GAUGE INSTUMENT CLUSTER WITH AUTOMATIC HEADLAMP CONTROL WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVERS POWER LUMBAR SUPPORT WITH ELECTRIC REAR WINDOWS WITH ENGLISH LANGUAGE LABEL WITH FRONT FOG LAMPS WITH INTERIOR PACK WITH LEATHER HANDBRAKE GRIP WITH LEVEL 'A' INTERIOR DECOR WITH LOCKING WHEEL LUG NUT KIT WITH MEDIA GATEWAY MODULE WITH MEDIA GATEWAY PACKAGE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH PASS 2 WAY MANUAL SEAT ADJUST WITH ROLLED EXHAUST TIPS WITH SAFETY/SECURE PACKAGE WITH SINGLE REAR WING SPOILER WITH SUB WOOFER SOUND SYSTEM WITH UPSIZED FRONT STABLIZER BAR 3 WITH UPSIZED REAR STABLIZER BAR ALTERNATOR ID BR3T10300LA CLUSTER FIN ID BR3310849EE DSO SPEC. ORDER CD 48 EMISSION PROCESS ID BR3A12A650AFH ENGINE TAG ID 1G398AA FUEL TANK BR339K007AE INSTRUMENT CLUSTER ID BR3310849EE PAINT CODE UX RADIATOR ID BR338005AA STEERING ASSEMBLY ID 6R333C529AC SUSPENSION FRONT ID (LEFT) BR335310GB SUSPENSION REAR ID (LEFT) BR335560EB TRANSMISSION TAG NO. BR3P7000BA TRIM COLOR Q TRIM TYPE 5 VEHICLE DESCRIPTION FORD MUSTANG CONVERTIBLE GT VEHICLE TYPE P8F WHEEL COVER TRIM 5R3J1A096BA WHEEL ID AR331007EB BR331007AB WIRING BR3T14A005NF WIRING BR3T14631DA WIRING BR3T14630BA WIRING BR3T14407AA WIRING BR3T14401GF WIRING BR3T14290JF WIRING COUNT 06 BODY: 2-DR. SEDAN BODY DESCRIPTION: GT CONVERTIBLE CYLINDERS: 8 ENGINE: 5.0 ENGINE TYPE: GASOLINE MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) - VALID FOR F/CMVSS 500 LOW SPEED VEHICLES ONLY SERIES: GT TYPE: PASSENGER CAR Citera
grufman March 14, 2017 Author Report March 14, 2017 On 2016-10-30 at 22:03, olechr said: Hej! Tacksam för info ang SZD628. (-) VERSION PACKAGES 2013 JOB #1 PROGRAM CONTROL 8.5 X 19" PAINTED ALUMINIUM WHEEL BLACK CLOTH COVER BR33-5560-E* LEFT REAR COIL SPRING BR33-5560-E* RIGHT REAR COIL SPRING CENTRE HUB ORN - HORSE AND BAR DOOR ENTRY R/CONT UNIT - 2 KEYS DRIVERS C/K POWER MIRROR ELECT PREM AM/FM STRO/DISC/CLOCK ELECTROCHROMIC MIRROR WITH COMPASS ENGINE COVER - UNDER HOOD FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FREQUENCY - 315MHZ FRONT FLOOR CARPET MATS FRONT FOG LAMPS-LED FRONT LICENSE PLATE HOLDER DELUXE FRONT SCUFF PLATES - ILLUMINATED GENERIC COUNTRY GROUP 3 GROUP MARKET #3 HEADER DOME LIGHT LESS MAP LAMP HIGH INTENSITY DISCHARGE HEADLAMP HIGH PERFORMANCE AUDIO SYSTEM I/P INSERT - DARK ALUMINIUM INSTRMNT CLUST-UNIQUE FEAT/GRAPHICS LEATHER WRAP WITH REDUNDANT CONTROL LESS ACCT STRIPE-BDYSD COLOR LESS APPEARANCE GROUP LESS BODY TU-TONE PAINT LESS BODYSIDE ACCENT STRIPE LESS CAMERA LESS CONVENIENCE GROUP LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS DIFFERENTIAL COOLER COVER LESS ENGINE COOLING SYSTEM LESS FLEET LESS FLOOR MATS-FIA LESS FRONT LIP SPOILER - FIA LESS FUEL LABEL LESS FULL VEHICLE COVER LESS GARAGE DOOR OPENER LESS IMMERSION HEATER LESS OPTIONAL EQUIPMENT PACK LESS PERFORMANCE PACK LESS PREMIUM BRAKES LESS REMOTE STARTER - FIA LESS REVERSE PROXIMITY SENSOR LESS SIDE SCOOP - FIA LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPECIAL EQUIPMENT PACKAGE LESS SPEED AUDIBLE WARNING DEVICE LESS SPOILER - FIA LESS SUN ROOF LESS TAPE STRIPES - FIA LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT LESS TYRE INFLATION KIT LESS WINDOW LOUVERS - FIA LIGHTING PACKAGE LEVEL A MUSTANG (2005/) NATURAL GRAIN (A-L) NORMAL FUEL FILL PASSENGER POWER MIRROR PERIMETER ALARM W/INTRUDER/SENSOR PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SATELLITE DIGITAL BROADCAST SIDE AIR BAG - 1ST ROW ONLY SPARE TYRE - T185/55R18 SPORTS FRONT SEAT TYRE INFLATION MONITOR UNIQUE MET FINISH FOOT PEDALS PADS WITH 18" ALUMINIUM MINI SPARE WHEEL WITH 49 STATE/NON GREEN STATE REQ WITH AUTOMATIC HEADLAMP CONTROL WITH BONNET SCOOP WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVERS POWER LUMBAR SUPPORT WITH ELECTRIC REAR WINDOWS WITH FRONT 4 WAY HEADREST WITH FRONT SIDE AIR BAG RESTRAINT WITH INTERIOR PACK WITH KMH/MPH SPEEDOMETER WITH LEATHER HANDBRAKE GRIP WITH LEVEL 'A' INTERIOR DECOR WITH LOCKING WHEEL LUG NUT KIT WITH MEDIA GATEWAY MODULE WITH MEDIA GATEWAY PACKAGE WITH NAAO RADIO FREQUENCY WITH PASS 2 WAY MANUAL SEAT ADJUST WITH REAR SPLASH GUARDS - DELUXE WITH ROLLED EXHAUST TIPS WITH SINGLE REAR WING SPOILER WITH SPANISH LANGUAGE LABEL WITH SPANISH OWNER HANDBOOK ALTERNATOR ID BR3T10300LA AXLE TAG RATING TYPE S203C DRIVE LINE SHAFT ID BR334K145CA DSO SPEC. ORDER CD M1 EMISSION PROCESS ID DR3A12A650ND ENGINE TAG ID DG398AA FUEL TANK CR339K007AC INSTRUMENT CLUSTER ID DR3310849FG PAINT CODE UA RADIATOR ID BR338005AA STEERING ASSEMBLY ID 6R333C529AC SUSPENSION FRONT ID (LEFT) BR335310GB SUSPENSION REAR ID (LEFT) BR335560EB TRANSMISSION TAG NO. BR3P7000BA TRIM COLOR P TRIM TYPE 5 VEHICLE DESCRIPTION FORD MUSTANG CONVERTIBLE GT VEHICLE TYPE P8F WHEEL COVER TRIM BR331A096BA WHEEL ID BR331007AB DR331007EA WIRING BR3T14407AAB WIRING DR3T14A005XD WIRING DR3T14631DC WIRING DR3T14630BC WIRING DR3T14401JE WIRING DR3T14290JC WIRING COUNT 06 BODY: 2-DR. SEDAN BODY DESCRIPTION: GT CONVERTIBLE CYLINDERS: 8 ENGINE: 5.0 ENGINE TYPE: GASOLINE - PREMIUM FUEL MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) - VALID FOR F/CMVSS 500 LOW SPEED VEHICLES ONLY SERIES: GT TYPE: PASSENGER CAR Citera
grufman March 14, 2017 Author Report March 14, 2017 On 2016-11-27 at 17:32, u43jln said: Hej BGU 013 Tack på förhand Janne L (-) VERSION PACKAGES 2007 JOB #2 PROGRAM CONTROL 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4450 LB. GVW 4R33 5310 GA LEFT FRONT COIL 4R33-5310-GA RIGHT FRONT COIL 5R33-5560-BA LEFT REAR COIL 5R33-5560-BA RIGHT REAR COIL 8.0 X 17" MACHINED ALUMINIUM WHEEL CANADIAN SALES CDX6+ WITH SPEED SENSOR VOL CONTROL CENTRE HUB ORN - HORSE AND BAR ELECTROCHROMIC MIRROR WITH COMPASS ENGLISH NAS OWNER HANDBOOK ENGLISH/FRENCH NAS LANGUAGE LABEL FLATROCK ASSEMBLY PLANT - USA FLEET FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT COMFORT PACKAGE C2 FRONT FLOOR CARPET MATS GENERIC COUNTRY GROUP 2 HEADER DOME LIGHT LESS MAP LAMP I/P INSERT - RIBBED ALUMINIUM IMMERSION HEATER ENGINE LEATHER WRAP/SATIN ALUM SPOKE WHEEL LESS ACCT STRIPE-BDYSD COLOR LESS AMBIENT TEMP/SPEED PACK LESS APPEARANCE GROUP LESS APPEARANCE PACKAGE LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS BONNET SCOOP LESS CARGO NET - FIA LESS CONVERTIBLE ROOF COVER LESS EXHAUST TIPS LESS FLOOR MATS-FIA LESS FRONT LICENSE PLATE BRACKET LESS FUEL FILLER DOOR - FIA LESS FULL VEHICLE COVER LESS INTERIOR PACK LESS REMOTE STARTER - FIA LESS SIDE IMPACT PACKAGE LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPEED AUDIBLE WARNING DEVICE LESS TAPE STRIPES - FIA LESS TYRE INFLATION KIT MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON/COLOR (ROOF) NORMAL FUEL FILL PERIMETER ALARM W/INTRUDER/SENSOR REAR AXLE LIMITED SLIP DIFFERENTIAL SATELLITE DIGITAL BROADCAST SPARE TYRE - T185/60R17 SPORTS FRONT SEAT STANDARD DUTY BATTERY STANDARD FOOT PEDAL PAD DESIGN WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 49 STATE/NON GREEN STATE REQ WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH DAYTIME RUNNING LAMPS WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVER AIR BAG WITH DRIVERS HEATED SEAT WITH DRIVERS POWER LUMBAR SUPPORT WITH FIXED REAR SIDE WINDOW WITH FRONT FOG LAMPS WITH HEATED PASSENGER SEAT WITH KMH/MPH SPEEDOMETER WITH LEVEL 'A' INTERIOR DECOR WITH LOCKING WHEEL LUG NUT KIT WITH MESSAGE CENTRE WITH NAAO RADIO FREQUENCY WITH NARROW BODY MOULDING WITH NON LOCKING FUEL CAP WITH PASS 6 WAY POWER SEAT ADJUSTER WITH PASSENGER AIR BAG WITH SINGLE REAR WING SPOILER WITH SUB WOOFER SOUND SYSTEM WITH UPSIZED FRONT STABILIZER BAR WITH UPSIZED REAR STABLIZER BAR AXLE TAG RATING TYPE V237V CLUSTER FIN ID 7R3363044D70HASMEN DRIVE LINE SHAFT ID 6R334K145AD DSO SPEC. ORDER CD B8 EMISSION PROCESS ID 7R3A12A650ATB ENGINE TAG ID 7S836BB FUEL TANK 7R339K007AG INSTRUMENT CLUSTER ID 7R3310849HC PAINT CODE G9 RADIATOR ID 4R338005CE STEERING ASSEMBLY ID 7R333200BB 6R333C529AB SUSPENSION FRONT ID (LEFT) 6R335310GA SUSPENSION REAR ID (LEFT) 5R335560BC TRANSMISSION TAG NO. 7R3P7000AC TRIM COLOR 2 TRIM TYPE K VEHICLE DESCRIPTION FORD MUSTANG 2-DR COUPE GT VEHICLE TYPE T82 WHEEL ID 4R331007KA WIRING 7R3T14A005JAF WIRING 6R3T14407ED WIRING 7R3T14401FAF WIRING 7R3T14290DA WIRING COUNT 04 BODY: 2-DR.-COUPE BODY DESCRIPTION: GT CYLINDERS: 8 ENGINE: 4.6 ENGINE TYPE: OHC MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS - APPLIES TO ALL PASSENGER CARS SERIES: ZF TYPE: PASSENGER CAR Citera
grufman March 14, 2017 Author Report March 14, 2017 On 2016-11-29 at 15:55, Janne H said: egg857 Tack (-) VERSION PACKAGES 50 STATE EMISSION REQUIREMENTS 9.5 X 19 FR 9.5 X 20 RR PREM PNTD BLACK CLOTH COVER BR3V-5560-M* LEFT REAR COIL BR3V-5560-M* RIGHT REAR COIL CENTRE HUB - VERSION A CONVERTIBLE BOOT-ROOF COVER DRIVERS C/K POWER MIRROR ELECT PREM AM/FM STRO/DISC/CLOCK ELECTRO MIRROR WITH COMPASS AND MIC FLATROCK ASSEMBLY PLANT - USA FORD DIVISION DERIVATIVE FRONT FLOOR MATS - SILVER LOGO FRONT SCUFF PLATES - WITH INSERT GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP HIGH INTENSITY DISCHARGE HEADLAMP I/P INSERT - ALUMINIUM INTERIOR UPGRADE PACKAGE B LESS ACCT STRIPE-BDYSD COLOR LESS APPEARANCE GROUP LESS BODYSIDE ACCENT STRIPE LESS CAMERA LESS CONVENIENCE GROUP LESS DAYTIME RUNNING LAMPS LESS DECKLID PANEL - FIA LESS EXHAUST TIPS LESS FLEET LESS FRONT LICENSE PLATE BRACKET LESS FRONT LIP SPOILER - FIA LESS FULL VEHICLE COVER LESS GARAGE DOOR OPENER LESS HOOD SCOOP - FIA LESS IMMERSION HEATER LESS INTERIOR PACK LESS PREMIUM BRAKES LESS REMOTE STARTER - FIA LESS SIDE SCOOP - FIA LESS SMOKERS PACKAGE LESS SPARE TYRE LESS SPARE WHEEL LESS SPECIAL BUILD REQUIREMENT LESS SPEED AUDIBLE WARNING DEVICE LESS SPOILER - FIA LESS SUN ROOF LESS TAPE STRIPES - FIA LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT LESS WINDOW LOUVERS - FIA LIGHTING PACKAGE LEVEL A MUSTANG (2005/) NORMAL FUEL FILL OWNER HAND BOOK PACK PASSENGER POWER MIRROR PERIMETER ALARM W/INTRUDER/SENSOR REAR SPOILER WITH GURNEY FLAP SATELLITE DIGITAL BROADCAST SIDE AIR BAG - 1ST ROW ONLY SPORTS FRONT SEAT STEERING WHEEL - 3 SPOKE LEATHER UNIQUE MET FINISH FOOT PEDALS PADS WITH 6 GAUGE INSTUMENT CLUSTER WITH AUTOMATIC HEADLAMP CONTROL WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVERS POWER LUMBAR SUPPORT WITH ELECTRIC REAR WINDOWS WITH ENGLISH LANGUAGE LABEL WITH LEATHER HANDBRAKE GRIP WITH LOCKING WHEEL LUG NUT KIT WITH MEDIA GATEWAY MODULE WITH MEDIA GATEWAY PACKAGE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH PASS 2 WAY MANUAL SEAT ADJUST WITH REAR SPLASH GUARDS - DELUXE WITH SUB WOOFER SOUND SYSTEM WITH SVE FRONT FOG LAMPS/AUX I/P WITH SVT PERFORMANCE PACK WITH TYRE INFLATION KIT WITH UPSIZED FRONT STABLIZER BAR 2 WITH UPSIZED REAR STABLIZER BAR CLUSTER FIN ID BR3310849JE DSO SPEC. ORDER CD 74 EMISSION PROCESS ID BR3A12A650ADH ENGINE TAG ID BA253AA FUEL TANK BR3V9K007BA INSTRUMENT CLUSTER ID BR3310849JE PAINT CODE PQ RADIATOR ID BR3V8009AC STEERING ASSEMBLY ID 6R333C529AC SUSPENSION REAR ID (LEFT) BR3V5560MB TRIM COLOR X TRIM TYPE 6 VEHICLE DESCRIPTION FORD MUSTANG SHELBY CONVERTIB VEHICLE TYPE P8K WHEEL COVER TRIM 2M5V1A096AB WHEEL ID BR3V1007AA BR3V1007BB WIRING BR3V14A005SE WIRING BR3T14631DA WIRING BR3T14630BA WIRING BR3T14407AA WIRING BR3T14401GF WIRING BR3V14290LF WIRING COUNT 06 BODY: 2-DR. SEDAN BODY DESCRIPTION: SHELBY GT 500 CONV. CYLINDERS: 8 ENGINE: 5.4 ENGINE TYPE: GASOLINE MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) - VALID FOR F/CMVSS 500 LOW SPEED VEHICLES ONLY SERIES: GT TYPE: PASSENGER CAR Citera
grufman March 14, 2017 Author Report March 14, 2017 On 2016-12-04 at 22:07, Tommy Cavallin said: TFH 085 Skickat från min iPad med Tapatalk (-) VERSION PACKAGES 8.5 X 19" PAINTED ALUMINIUM WHEEL AM/FM STR/CD/CLK/NAVIG SYSTEM BLACK CLOTH COVER BR33-5560-E* LEFT REAR COIL SPRING BR33-5560-E* RIGHT REAR COIL SPRING CENTRE HUB ORN - PONY LOGO/SPINNER CONVERTIBLE BOOT-ROOF COVER DRIVERS C/K POWER MIRROR ELECTROCHROMIC MIRROR WITH MIC ENGINE COVER - UNDER HOOD FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT COMFORT PACKAGE C2 FRONT FLOOR CARPET MATS FRONT LICENSE PLATE HOLDER DELUXE FRONT SCUFF PLATES - ILLUMINATED GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP HIGH INTENSITY DISCHARGE HEADLAMP I/P INSERT - METALLIC FINISH LESS ACCT STRIPE-BDYSD COLOR LESS APPEARANCE GROUP LESS BODY TU-TONE PAINT LESS BODYSIDE ACCENT STRIPE LESS DAYTIME RUNNING LAMPS LESS DECKLID PANEL - FIA LESS FLEET LESS FLOOR MATS-FIA LESS FRONT LIP SPOILER - FIA LESS FUEL LABEL LESS FULL VEHICLE COVER LESS HOOD SCOOP - FIA LESS IMMERSION HEATER LESS INTERIOR PACK LESS PERFORMANCE PACK LESS PREMIUM BRAKES LESS REAR MUDFLAPS LESS REMOTE STARTER - FIA LESS SIDE SCOOP - FIA LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPECIAL EQUIPMENT PACKAGE LESS SPEED AUDIBLE WARNING DEVICE LESS SPOILER - FIA LESS SUN ROOF LESS TAPE STRIPES - FIA LESS TYRE INFLATION KIT LESS WINDOW LOUVERS - FIA LIGHTING PACKAGE LEVEL A MUSTANG (2005/) NORMAL FUEL FILL OWNER HAND BOOK PACK PASSENGER POWER MIRROR PERIMETER ALARM W/INTRUDER/SENSOR PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL REAR VIEW CAMERA-FIXED SATELLITE DIGITAL BROADCAST SIDE AIR BAG - 1ST ROW ONLY SPARE TYRE - T185/55R18 SPORTS FRONT SEAT STEER WHEEL-LEATHER ALUM SPOKE UNIQUE MET FINISH FOOT PEDALS PADS WITH 18" ALUMINIUM MINI SPARE WHEEL WITH 49 STATE/NON GREEN STATE REQ WITH 6 GAUGE INSTUMENT CLUSTER WITH AUTOMATIC HEADLAMP CONTROL WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVERS HEATED SEAT WITH DRIVERS POWER LUMBAR SUPPORT WITH ELECTRIC REAR WINDOWS WITH ENGLISH LANGUAGE LABEL WITH FRONT 4 WAY HEADREST WITH FRONT FOG LAMPS WITH HEATED PASSENGER SEAT WITH LEATHER HANDBRAKE GRIP WITH LEVEL 'A' INTERIOR DECOR WITH LOCKING WHEEL LUG NUT KIT WITH MEDIA GATEWAY MODULE WITH MEDIA GATEWAY PACKAGE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH PASS 6 WAY POWER SEAT ADJUSTER WITH REVERSE PROXIMITY SENSOR WITH ROLLED EXHAUST TIPS WITH SAFETY/SECURE PACKAGE WITH SINGLE REAR WING SPOILER WITH SUB WOOFER SOUND SYSTEM WITH UNIVERSAL GARAGE DOOR OPENER ALTERNATOR ID BR3T10300LA AXLE TAG RATING TYPE S203C DRIVE LINE SHAFT ID BR334K145CA DSO SPEC. ORDER CD 24 EMISSION PROCESS ID CR3A12A650AFB ENGINE TAG ID BG398AB FUEL TANK CR339K007AB INSTRUMENT CLUSTER ID CR3310849ED PAINT CODE UA RADIATOR ID BR338005AA STEERING ASSEMBLY ID 6R333C529AC SUSPENSION FRONT ID (LEFT) BR335310GB SUSPENSION REAR ID (LEFT) BR335560EB TRANSMISSION TAG NO. BR3P7000BA TRIM COLOR W TRIM TYPE 4 VEHICLE DESCRIPTION FORD MUSTANG CONVERTIBLE GT VEHICLE TYPE P8F WHEEL COVER TRIM 5R3J1A096BA WHEEL ID AR331007EB BR331007AB WIRING BR3T14407AAB WIRING CR3T14A005YF WIRING BR3T14631DC WIRING BR3T14630BC WIRING CR3T14401KG WIRING CR3T14290JG WIRING COUNT 06 BODY: 2-DR. SEDAN BODY DESCRIPTION: GT CONVERTIBLE CYLINDERS: 8 ENGINE: 5.0 ENGINE TYPE: GASOLINE MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) - VALID FOR F/CMVSS 500 LOW SPEED VEHICLES ONLY SERIES: GT TYPE: PASSENGER CAR 1 Citera
grufman March 14, 2017 Author Report March 14, 2017 On 2016-12-05 at 21:07, NilsB said: Hej,är du snäll och kollar denna bil.... tack // Nils 1ZVBP8CF5E5214024 (-) VERSION PACKAGES 19" X 9 PREM PAINTED LUSTER NICKEL ANALOGUE AUDIO BROADCAST BR33-5560-G* LEFT REAR COIL SPRING BR33-5560-G* RIGHT REAR COIL SPRING CENTRE HUB ORN - HORSE AND BAR DOOR ENTRY R/CONT UNIT - 2 KEYS DRIVERS C/K POWER MIRROR ELECT PREM AM/FM STRO/DISC/CLOCK ELECTRO MIRR W/RR VIEW CAM DISPLAY ENGINE COVER - UNDER HOOD EXPORT FUEL FILL FLATROCK ASSEMBLY PLANT - USA FLEET FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FREQUENCY - 315MHZ FRONT FLOOR CARPET MATS FRONT FOG LAMPS-LED FRONT LICENSE PLATE HOLDER DELUXE FRONT SCUFF PLATES - ILLUMINATED GROUP MARKET #11 HEADER DOME LIGHT LESS MAP LAMP I/P INSERT - METALLIC FINISH INSTRMNT CLUST-UNIQUE FEAT/GRAPHICS LEATHER WRAP WITH REDUNDANT CONTROL LESS ACCT STRIPE-BDYSD COLOR LESS APPEARANCE GROUP LESS BODYSIDE ACCENT STRIPE LESS CONVENIENCE GROUP LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS DIFFERENTIAL COOLER COVER LESS DRIVER SEAT LUMBAR SUPPORT LESS ENGINE COOLING SYSTEM LESS FLOOR MATS-FIA LESS FUEL LABEL LESS IMMERSION HEATER LESS INTERIOR PACK LESS OPTIONAL EQUIPMENT PACK LESS PERFORMANCE PACK LESS REMOTE STARTER LESS SMOKERS PACKAGE LESS SPARE TYRE LESS SPARE WHEEL LESS SPECIAL BUILD REQUIREMENT LESS SPEED AUDIBLE WARNING DEVICE LESS SUN ROOF LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT LIGHTING PACKAGE LEVEL A MILLED PEBBLE MUSTANG (2005/) NON/COLOR (ROOF) OWNER HAND BOOK PACK PASSENGER POWER MIRROR PERIMETER ALARM W/INTRUDER/SENSOR PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL REAR VIEW CAMERA-FIXED SIDE AIR BAG - 1ST ROW ONLY TYRE INFLATION MONITOR UNIQUE MET FINISH FOOT PEDALS PADS WITH AUTOMATIC HEADLAMP CONTROL WITH BODY COLOURED ROOF WITH BONNET SCOOP WITH CALIFORNIA/GREEN STATE REQ WITH DRIVER 4 WAY MNL.SEAT ADJUSTER WITH ENGLISH LANGUAGE LABEL WITH FIXED REAR SIDE WINDOW WITH FRONT INTEGRAL HEAD REST WITH FRONT SIDE AIR BAG RESTRAINT WITH GCC RADIO FREQUENCY WITH KMH/MPH SPEEDOMETER WITH LEATHER HANDBRAKE GRIP WITH LEVEL 'A' INTERIOR DECOR WITH LOCKING WHEEL LUG NUT KIT WITH MEDIA GATEWAY PACKAGE WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PERFORMANCE BRAKES WITH REAR SPLASH GUARDS - DELUXE WITH RECARO FRONT SEAT WITH REVERSE PROXIMITY SENSOR WITH ROLLED EXHAUST TIPS WITH SAFETY/SECURE PACKAGE WITH SINGLE REAR WING SPOILER WITH SUB WOOFER SOUND SYSTEM WITH TYRE INFLATION KIT WITH UNIVERSAL GARAGE DOOR OPENER ALTERNATOR ID BR3T10300LA AXLE TAG RATING TYPE S203C DRIVE LINE SHAFT ID BR334K145BC DSO SPEC. ORDER CD 9Y EMISSION PROCESS ID DR3A12A650PD ENGINE TAG ID DG398AA FUEL TANK CR339K007AD INSTRUMENT CLUSTER ID DR3310849FJ PAINT CODE UA RADIATOR ID BR338005AA STEERING ASSEMBLY ID 6R333C529AC SUSPENSION REAR ID (LEFT) BR335560GB TRANSMISSION TAG NO. BR3P7000BA TRIM COLOR W TRIM TYPE S VEHICLE DESCRIPTION FORD MUSTANG 2-DR COUPE GT VEHICLE TYPE P8C WHEEL COVER TRIM BR331A096BA WHEEL ID BR331007BB WIRING BR3T14407AAB WIRING DR3T14A005FH WIRING DR3T14631BE WIRING DR3T14630BE WIRING ER3T14401HA WIRING DR3T14290JF WIRING COUNT 06 BODY: 2-DR. SEDAN BODY DESCRIPTION: GT COUPE CYLINDERS: 8 ENGINE: 5.0 ENGINE TYPE: GASOLINE - PREMIUM FUEL MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) - VALID FOR F/CMVSS 500 LOW SPEED VEHICLES ONLY SERIES: GT TYPE: PASSENGER CAR Citera
grufman March 14, 2017 Author Report March 14, 2017 On 2017-03-09 at 15:28, Mustangmike said: 1ZVHT82H575230588 Tackar på förhand :-) (-) VERSION PACKAGES 17 X 8" PAINTED ALUM W/MACH RIM 2007 JOB #1 PROGRAM CONTROL 4 WHEEL ANTI-LOCK BRAKING SYSTEM 4450 LB. GVW 4R33 5310 GA LEFT FRONT COIL 4R33-5310-GA RIGHT FRONT COIL 5R33-5560-BA LEFT REAR COIL 5R33-5560-BA RIGHT REAR COIL CDX6+ WITH SPEED SENSOR VOL CONTROL ENGINE COVER - UNDER HOOD FLATROCK ASSEMBLY PLANT - USA FOR UNLEADED FUEL FORD DIVISION DERIVATIVE FRONT FLOOR MATS - MONOTONE C/K GENERIC COUNTRY GROUP 1 HEADER DOME LIGHT LESS MAP LAMP I/P INSERT - RIBBED ALUMINIUM LEATHER WRAP/SATIN ALUM SPOKE WHEEL LESS ACCT STRIPE-BDYSD COLOR LESS AMBIENT TEMP/SPEED PACK LESS APPEARANCE GROUP LESS B&A CONTROL CODES ISSUE 030388 LESS BODYSIDE ACCENT STRIPE LESS CONVENIENCE GROUP LESS CONVERTIBLE ROOF COVER LESS DAYTIME RUNNING LAMPS LESS EXTERIOR BODY MOULDINGS LESS FLEET LESS FLOOR MATS-FIA LESS FRONT LICENSE PLATE BRACKET LESS FULL VEHICLE COVER LESS IMMERSION HEATER LESS SMOKERS PACKAGE LESS SPECIAL BUILD REQUIREMENT LESS SPEED AUDIBLE WARNING DEVICE LESS TAPE STRIPES - FIA LESS TEMP CONTROL DRIVER SEAT LESS TEMP CONTROL PASSENGERS SEAT LESS TYRE INFLATION KIT MUSTANG (2005/) NON ILLUMINATED SUNVISOR - DRIVERS NON ILLUMINATED SUNVISOR-PASSENGER NON LOCKING FUEL CAP WITH BP LABEL NON/COLOR (ROOF) NORMAL FUEL FILL OWNER HAND BOOK PACK PERIMETER ALARM W/INTRUDER/SENSOR PREMIUM MARKETING TRIM REAR AXLE LIMITED SLIP DIFFERENTIAL SATELLITE DIGITAL BROADCAST SPARE TYRE - T185/60R17 SPORTS FRONT SEAT STANDARD DUTY BATTERY U.S. SALES UNIQUE MET FINISH FOOT PEDALS PADS WITH 17" ALUMINIUM MINI SPARE WHEEL WITH 49 STATE/NON GREEN STATE REQ WITH 6 GAUGE INSTUMENT CLUSTER WITH ANTI-SPIN TRACTION SYSTEM WITH BONNET SCOOP WITH CENTRE HUB ORNAMENT-FORD OVAL WITH DRIVER 6 WAY PWR.SEAT ADJUSTER WITH DRIVER AIR BAG WITH DRIVERS POWER LUMBAR SUPPORT WITH ENGLISH LANGUAGE LABEL WITH FIXED REAR SIDE WINDOW WITH FRONT FOG LAMPS WITH INTERIOR PACK WITH LEVEL 'A' INTERIOR DECOR WITH LOCKING WHEEL LUG NUT KIT WITH MESSAGE CENTRE WITH MPH/KMH SPEEDOMETER WITH NAAO RADIO FREQUENCY WITH OVERSPEED WARNING DISABLED WITH PASS 2 WAY MANUAL SEAT ADJUST WITH PASSENGER AIR BAG WITH PRISMATIC MIRROR WITH ROLLED EXHAUST TIPS WITH SIDE IMPACT PACKAGE WITH SINGLE REAR WING SPOILER WITH SUB WOOFER SOUND SYSTEM WITH UPSIZED FRONT STABILIZER BAR WITH UPSIZED REAR STABLIZER BAR AXLE TAG RATING TYPE V237R CLUSTER FIN ID 7R3363044D70CASMEN DRIVE LINE SHAFT ID 6R334K145AD DSO SPEC. ORDER CD 24 EMISSION PROCESS ID 7R3A12A650AKC ENGINE TAG ID 7S836BA FUEL TANK 7R339K007AE INSTRUMENT CLUSTER ID 7R3310849GA PAINT CODE TL RADIATOR ID 4R338005CE STEERING ASSEMBLY ID 7R333200BB 6R333C529AB SUSPENSION FRONT ID (LEFT) 6R335310GA SUSPENSION REAR ID (LEFT) 5R335560BC TRANSMISSION TAG NO. 7R3P7000AA TRIM COLOR D TRIM TYPE K VEHICLE DESCRIPTION FORD MUSTANG 2-DR COUPE GT VEHICLE TYPE T82 WHEEL ID 4R331007KA WIRING 7R3T14A005JL WIRING 6R3T14407ED WIRING 7R3T14401DF WIRING 6R3T14290DC WIRING COUNT 04 BODY: 2-DR.-COUPE BODY DESCRIPTION: GT CYLINDERS: 8 ENGINE: 4.6 ENGINE TYPE: OHC MAKE: FORD MANUFACTURER: AUTOMOTIVE ALLIANCE INTERNATIONAL, USA PLANT: AAI: FLAT ROCK, MICHIGAN RESTRAINT: ACTIVE BELTS (ALL DESIGNATED SEATING POSITIONS) WITH DRIVER AND PASSENGER AIR BAGS PLUS DRIVER AND PASSENGER SIDE AIR BAGS, CURTAINS, OR CANOPIES SERIES: ZF TYPE: PASSENGER CAR Citera
S Axtelius December 25, 2017 Report December 25, 2017 On 2016-03-18 at 13:28, grufman said: Skriv in ditt reg eller chassienummer här så postar jag bilens build sheet YGF 504 S Axtelius Citera
Gt musse January 9, 2018 Report January 9, 2018 1ZVFT82H355108199Tack för hjälpenJörgen Skickat från min SM-G920F via Tapatalk Citera
Kris August 2, 2018 Report August 2, 2018 Gammal tråd, men provar. Skulle vara kul att ha. RMN 205 Tackar på förhand. Med vänlig hälsning Christer Citera
Krille_Evolve August 18, 2018 Report August 18, 2018 Tack på förhand om detta fortfarande är aktivt 1ZVFT82H365195832 Citera
